WIRELING 5 PIN CABLE VARIETY PACK (12 CABLES)
ASR00009-1
DESCRIPTION
This variety pack of Wireling cables includes:
4- 50mm 5 pin cable
4- 100mm 5 pin cable
4- 200mm 5 pin cable
Wirelings use a 5 Pin Cable in order to make our platform plug-andplay so that you can build fast without soldering or using messy
breadboards. These cables come in lengths of 50mm, 100mm, and
200mm and a variety of quantities.
These cables can be cut and used to solder other components so that
they can be easily used with all of the Wireling Platform.
Power: Two wires are used for power (3V3) and ground (GND) in
order to power the connected Wireling (of course!)
Communication: Many Wirelings use I²C, a serial communication
protocol that uses two other wires for SDA and SCL to collect
complex data like temperature readings.
Analog Pin: The fifth wire is connected to an Analog pin for
Wirelings that just need an I/O pin to function, like the Momentary
Button, and the RGB LEDs.
https://tinycircuits.com/products/wirelings‐5‐pin‐cable‐variety‐pack?_pos=2&_sid=e24ac5785&_ss=r/2‐21‐20
很抱歉,暂时无法提供与“ASR00009-1”相匹配的价格&库存,您可以联系我们找货
