TE0803-02-04CG-1EB
TE0803-02-04CG-1EB
    TRENZELECTRONIC
    IC MODULE ZYNQ USCALE 2GB 256MB
TE0803-02-04CG-1EB 数据手册
MPSoC Module with Xilinx Zynq UltraScale+ ZU4CG-1E, 2 GB DDR4, 256 MByte Flash  Order number: TE0803-02-04CG-1EB Product information "MPSoC Module with Xilinx Zynq UltraScale+ ZU4CG-1E, 2 GB DDR4, 256 MByte Flash" The Trenz Electronic TE0803-02-04CG-1EB is an industrial-grade MPSoC module integrating a Xilinx Zynq UltraScale+ with ZU4CG, 2 GByte DDR4 SDRAM, 256 MByte Flash memory for configuration and operation, and powerful switch-mode power supplies for all on-board voltages. A large number of configurable I/O's is provided via rugged high-speed stacking connections. All this on a tiny footprint of 5.2 x 7.6 cm at the most competitive price. These high-density integrated modules are smaller than a credit card and available in several variants. All parts are at least extended temperature range of 0°C to +85°C. The module operating temperature range depends on customer design and cooling solution. Please contact us for options. This product is not always in stock, but will be produced on customer order (on demand). Please ask for any minimum quantities. Key Features        Xilinx Zynq UltraScale+ XCZU4CG-1SFVC784E ZU4CG, 784 Pin Packages Dimension: 5.2 x 7.6 cm Plug-on module with 4 x 160 pin B2B connectors Rugged for shock and high vibration. 3 mm mounting holes for skyline heat spreader 2 GByte 64-Bit width DDR4 SDRAM       256 MByte SPI Boot Flash dual parallel 2 KBit Serial EEPROM for MAC Address 48 High-density (HD) I/O's (2 banks) User I/O o 65 x multi-use I/O's (MIO) o 156 high-performance (HP) I/O's (3 banks) o Serial transceiver: PS GTR 4; PL GTH 4 o Programmable 4-channel PLL clock generator All power supplies on board, single 3.3V power source required Evenly spread supply pins for good signal integrity. Other assembly options for cost or performance optimization plus high volume prices available on request. Recommended Software Vivado Design Suite - HLx Edition Download Vivado Design Suite HLx Editions include Partial Reconfiguration at no additional cost with the Vivado HL Design Edition and HL System Edition. In-warranty users can regenerate their licenses to gain access to this feature. Overview of all Editions of Vivado Design Suite Editions Development Support There is a base board available for this module. Latest documentation, design support files and reference designs with source files are available for download free of charge. Scope of Delivery  1 x MPSoC Module TE0803-02-04CG-1EB with Zynq UltraScale+ ZU4CG Additional Information    Manufacturer's article number: TE0803-02-04CG-1EB Trenz Electronic TE0803 Wiki Support Forum All modules produced by Trenz Electronic are developed and manufactured in Germany. https://shop.trenz‐electronic.de/en/TE0803‐02‐04CG‐1EB‐MPSoC‐Module‐with‐Xilinx‐Zynq‐UltraScale‐ZU4CG‐1E‐2‐GB‐DDR4‐256‐MByte‐Flash/12‐14‐18
TE0803-02-04CG-1EB 价格&库存
很抱歉,暂时无法提供与“TE0803-02-04CG-1EB”相匹配的价格&库存,您可以联系我们找货
