Type BLC-16
Fuse Block
For ¼” x 1¼” (6.3 x 32mm) Fuses
Fuse Style: ¼” x 1¼” (6.3 x 32mm) Fuses
Material:
Body: Thermostate (UL Flame: 94V-0)
Fuse Clips: Copper Alloy Tinned T:0.5mm
Terminal: Copper Alloy Tinned T:0.8mm
Specifications:
Dielectric Strength for 60 seconds: 1200VAC Min
Suitable Rated Current: 25A 250V
Insulation resistance at 500V DC: 500M Min.
Temperature Rise: 30 with dummy fuse, 85 with time-delay fuse
Voltage Drop: 15mV Max.
www.optifuse.com
Part #
BLC-16-B
BLC-16-B1
BLC-16-B2
BLC-16-S
BLC-16-S1
BLC-16-S2
(619)-593-5050
# of
Terminals
Pins/Legs
no
Bent
1
Bent
2
Bent
no
Straight
1
Straight
2
Straight
Agency Standards and Listings:
Product Dimensions: Inches [mm]
Note: All specifications subject to change without notice.
Rev A 06/2007 - Page: 1/2
Code: C01-02D
Type BLC-16
Fuse Block
Warning:
www.optifuse.com
(619)-593-5050
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of Fuse Block with chemical solvent. Prolonged contact will damage the device performance.
Rev A 06/2007 - Page: 2/2
Code: C01-02D
很抱歉,暂时无法提供与“BLC-16-B”相匹配的价格&库存,您可以联系我们找货
