Type BLC-209
Fuse Block
ANE / ANF Limiter Fuses
Specifications:
Voltage Rating: 125VAC, 80VDC
Max Current Rating: 800A
Fuse Type: ANE / ANF Limiter Fuse
Base: Phenolic Laminate, Flame Retarding
Terminals: Brass
www.optifuse.com
(619) 593-5050
Hardware Specifications
Item
1
2
3
4
Qty
4
4
2
16
Description
M8 Hex Nut
Flat washer
M8 x L50 Bolt
Phenolic Resin washer
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev C 03/2019 - Page: 1/1
Code G02-01H
很抱歉,暂时无法提供与“BLC-209”相匹配的价格&库存,您可以联系我们找货
