BLR-1110
BLR-1110
    OPTIFUSE
    REGULAR FUSE BLOCK, 10 POLE
BLR-1110 数据手册
Type BLR-1110 Fuse Block 10 Pole – Regular Auto Blade Specifications: Max Voltage: 32VDC Max Current Rating: 20A per Circuit Fuse Type: Regular Auto Blade – APR, ANR Series Housing and Base: PBT, Black Cover: PC, Clear Cover Inner Seal: Silicone Bottom Rubber Seal: EPDM, Black IP Rating: 56 Wires: 10, #12 AWG UL1015, (6.5”, 165mm) www.optifuse.com OptiFuse Part Number BLR-1110-12AWG BLR-1110-GROM BLR-1110-CON BLR-1110-INSERT BLR-1110-BLOCK BLR-1110 (619) 593-5050 Description Wires- 12 AWG Rubber grommet Connector # per Circuits Total circuit 2 10 20 2 10 20 2 10 20 Insert for wires and fuses Fuse block, cover & inserts, w/o above wires, connecters, grommets 1 10 10 - - 1 Full fuse block - - 1 Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 10/2018 - Page: 1/1 Code S02-01H
BLR-1110 价格&库存
很抱歉,暂时无法提供与“BLR-1110”相匹配的价格&库存,您可以联系我们找货
