FMR-500MA
FMR-500MA
    OPTIFUSE
    THRU HOLE FUSE,FAST ACTING 500MA
FMR-500MA 数据手册
Type FMR Fast Acting Micro Fuse Radial Leaded – Long Leaded Designed to Meet UL/CSA Specifications www.optifuse.com (619) 593-5050 Agency Standards and Listings: Voltage: 250V Material Body: Thermoplastic UL94V0 Pin: Copper Alloy, Tin plated Element: Silver Alloy Interrupt Ratings: 50A @ 250 VAC Electrical Characteristics: Rated Current 1.0 In 2.0 In Carry 10 sec Max 50mA~10A FMR-xxA FMR-xxA-T for Loose Fuses, Bulk, in a bag for Taped Fuses, in a box Mechanical Dimensions: Inches [mm] Warning: Cartridge Catalog Number FMR-50mA FMR-60mA FMR-63mA FMR-80mA FMR-100mA FMR-125mA FMR-160mA FMR-200mA FMR-250mA FMR-300mA FMR-315mA FMR-400mA FMR-500mA FMR-600mA FMR-630mA FMR-700mA FMR-800mA FMR-1A FMR-1.25A FMR-1.5A FMR-1.6A FMR-2A FMR-2.5A FMR-3A FMR-3.15A FMR-3.5A FMR-4A FMR-5A FMR-6.3A FMR-7A FMR-8A FMR-10A Ampere Rating 50mA 60mA 63mA 80mA 100mA 125mA 160mA 200mA 250mA 300mA 315mA 400mA 500mA 600mA 630mA 700mA 800mA 1A 1.25A 1.5A 1.6A 2A 2.5A 3A 3.15A 3.5A 4A 5A 6.3A 7A 8A 10A Voltage Rating I2T 250VAC 0.0001 0.00017 0.00023 0.00037 0.0013 0.0019 0.004 0.0065 0.014 0.028 0.032 0.016 0.024 0.032 0.039 0.045 0.069 0.11 0.2 0.32 0.38 0.63 1.2 1.7 1.9 2.7 3.5 6.2 9.1 21 26 49 -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Micro Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Micro Fuse device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev I 09/2018- Page: 1/1 Code: G02-01H
FMR-500MA 价格&库存
很抱歉,暂时无法提供与“FMR-500MA”相匹配的价格&库存,您可以联系我们找货
