FMS-R-E-800MA
FMS-R-E-800MA
    OPTIFUSE
    Radial,Box
    THRU HOLE FUSE - IEC, FAST 800MA
FMS-R-E-800MA 数据手册
Type FMS-R-E Fast Acting Micro Fuse Radial Leaded – Short Leaded Designed to Meet IEC Specifications www.optifuse.com Agency Standards and Listings: VDE 315mA~6.3A UL Recognized 315mA~6.3A PSE 1A~6.3A SEMKO 315mA~6.3A CQC 315mA~6.3A Approvals all at 250 VAC only Interrupt Ratings: VDE, cURus, SEMKO, CQC 35A or 10In whichever is greater at 250 VAC PSE - 100A 250 VAC 50A @ 125 VDC Operating Temperature: -55ºC ~ +125ºC Physical Specifications (Materials): Thermoplastic Body, UL 94-V0 Tin-Lead Plated Alloy Pins Part Number Ampere Rating FMS-R-E-315mA FMS-R-E-400mA FMS-R-E-500mA FMS-R-E-630mA FMS-R-E-800mA FMS-R-E-1A FMS-R-E-1.25A FMS-R-E-1.6A FMS-R-E-2A FMS-R-E-2.5A FMS-R-E-3.15A FMS-R-E-4A FMS-R-E-5A FMS-R-E-6.3A 315mA 400mA 500mA 630mA 800mA 1A 1.25A 1.6A 2A 2.5A 3.15A 4A 5A 6.3A (619) 593-5050 Voltage Rating I2T 250V 0.02301 0.03848 0.06059 0.08831 0.1947 0.3133 0.5169 0.9379 1.542 2.555 2.085 2.816 5.473 10.31 TIME CURRENT CURVE Electrical Characteristics: 210% 275% 400% 1000% MAX MIN MAX MIN MAX MAX 30 m 10 ms 3 s 3 ms 300 ms 20 ms Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Micro Fuse device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of Micro Fuse device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev E 02/2018 - Page: 1/1 Code: H01-01H
FMS-R-E-800MA 价格&库存
很抱歉,暂时无法提供与“FMS-R-E-800MA”相匹配的价格&库存,您可以联系我们找货
FMS-R-E-800MA
    • 1+43.54067
    • 5+26.14189
