TSA-P-800MA
TSA-P-800MA
    OPTIFUSE
    GLASS FUSE-6.3X32MM, SLOW 800MA
TSA-P-800MA 数据手册
Type TSA/TSA-P 6.3 x 32mm Time-Lag Glass Tube Fuse Agency Standards and Listings: Interrupt Ratings: 200mA ~ 1A: 35A @ 250VAC 1.2A ~ 3.5A: 100A @ 250VAC 4A ~ 30A: 200A @ 250VAC 12A ~ 30A: 1,000A @ 32VAC 1A ~ 5A 100A @ 250VAC PSE/KC Operating Temperature: -55C - +125C Physical Specifications: Materials Glass Body/Nickel Plated Brass Contacts Lead Wire: Tin Plated Copper Electrical Characteristics 100% 135% 200% MIN MAX MAX 4 hr 1 hr 120s Mechanical Dimensions: Note: All specifications subject to change without notice. www.optifuse.com (619) 593-5050 T Ampere Voltage UL UR Ü Rating Rating V ● ● TSA-200mA TSA-P-200mA 200mA ● ● TSA-250mA TSA-P-250mA 250mA ● ● TSA-300mA TSA-P-300mA 300mA Cartridge Part Number Axial Lead Part Number C P K S S C A E I2T REFERENCE ● ● (A2 Sec.) 0.262 ● ● 0.415 ● ● 0.820 TSA-315mA TSA-P-315mA 315mA ● ● ● ● 0.910 TSA-350mA TSA-P-350mA 350mA ● ● ● ● 1.091 TSA-400mA TSA-P-400mA 400mA ● ● ● ● 1.550 TSA-500mA TSA-P-500mA 500mA ● ● ● ● 2.512 TSA-600mA TSA-P-600mA 600mA ● ● ● ● 3.803 TSA-630mA TSA-P-630mA 630mA ● ● ● ● 4.285 TSA-750mA TSA-P-750mA 750mA ● ● ● ● 7.705 TSA-800mA TSA-P-800mA 800mA ● ● ● ● 1.542 TSA-1A TSA-P-1A 1A ● ● ● ● ● 3.373 TSA-1.2A TSA-P-1.2A 1.2A ● ● ● ● ● 5.115 TSA-1.25A TSA-P-1.25A 1.25A ● ● ● ● ● 5.789 ● ● ● ● 10.02 11.52 250V TSA-1.5A TSA-P-1.5A 1.5A ● TSA-1.6A TSA-P-1.6A 1.6A ● ● ● ● ● TSA-2A TSA-P-2A 2A ● ● ● ● ● 7.48 TSA-2.5A TSA-P-2.5A 2.5A ● ● ● ● ● 11.43 TSA-3A TSA-P-3A 3A ● ● ● ● ● 18.71 ● ● ● ● 20.45 TSA-3.15A TSA-P-3.15A 3.15A ● TSA-3.5A TSA-P-3.5A 3.5A ● ● ● ● ● 25.55 TSA-4A TSA-P-4A 4A ● ● ● ● ● 32.96 ● ● ● ● 57.80 TSA-5A TSA-P-5A 5A ● TSA-6A TSA-P-6A 6A ● ● ● 857.2 TSA-6.3A TSA-P-6.3A 6.3A ● ● ● 928.4 TSA-7A TSA-P-7A 7A ● ● ● 981.0 TSA-8A TSA-P-8A 8A ● ● ● 999.5 ● ● 2427 TSA-10A TSA-P-10A 10A ● TSA-12A TSA-P-12A 12A ● ● 3394 TSA-13A TSA-P-13A 13A ● ● 4278 TSA-15A TSA-P-15A 15A ● ● 5561 ● 5760 ● 6872 TSA-16A TSA-P-16A 16A TSA-18A TSA-P-18A 18A TSA-20A TSA-P-20A 20A ● 7560 TSA-25A TSA-P-25A 25A ● 17663 TSA-30A TSA-P-30A 30A ● 24300 32V 250V Rev E 01/2018 - Page: 1/2 Code H01-01H Type TSA/TSA-P 6.3 x 32mm Time-Lag Glass Tube Fuse www.optifuse.com (619) 593-5050 Time Current Curve Graph Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of fuse with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev E 01/2018 - Page: 2/2 Code H01-01H
TSA-P-800MA 价格&库存
很抱歉,暂时无法提供与“TSA-P-800MA”相匹配的价格&库存,您可以联系我们找货
