Type LPK-01
In-Line Fuse Holder
Automotive Blade Type
3 Terminal (Micro, 3-Leg)
Specifications:
Rating: 20A Max. 58 VDC
Body Material: Nylon with Glass Fiber, Black
Protective Cover: Polypropylene
Contacts: Brass, Junior Power Timer
IP Rating: IP 63 or IP 67
For use with Type ANK Fuse Series
(3 Terminal – Micro, 3 leg - Automotive Blade)
Standard Wire: UL1015, Red Color
Center: 5 inches, Sides: 6 inches
www.optifuse.com
(619) 593-5050
Wire Size (AWG)
Side
Center
#14
#12
Part Number
LPK-01B-14R (-W)
#16
LPK-01B-16R (-W)
#14
Part number format
Bracket attached to gang multiple fuse holders together
LPK-01B-##R (-W)
Where
## = Side Wire Gauge
-W = IP Rating 67 (Else IP Rating is 63)
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Device is intended for occasional overcurrent protection. Application for repeated overcurrent condition
and/or prolonged trip are not anticipated.
-Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance.
Note: All specifications and dimensions subject to change without notice.
Rev A 07/2018 - Page: 1/1
Code G02-01H
很抱歉,暂时无法提供与“LPK-01B-16R-W”相匹配的价格&库存,您可以联系我们找货
