LPK-01B-14R-W
LPK-01B-14R-W
    OPTIFUSE
    MICRO3 FUSEHOLDER 20A-14AWG IP67
LPK-01B-14R-W 数据手册
Type LPK-01 In-Line Fuse Holder Automotive Blade Type 3 Terminal (Micro, 3-Leg) Specifications: Rating: 20A Max. 58 VDC Body Material: Nylon with Glass Fiber, Black Protective Cover: Polypropylene Contacts: Brass, Junior Power Timer IP Rating: IP 63 or IP 67 For use with Type ANK Fuse Series (3 Terminal – Micro, 3 leg - Automotive Blade) Standard Wire: UL1015, Red Color Center: 5 inches, Sides: 6 inches www.optifuse.com (619) 593-5050 Wire Size (AWG) Side Center #14 #12 Part Number LPK-01B-14R (-W) #16 LPK-01B-16R (-W) #14 Part number format Bracket attached to gang multiple fuse holders together LPK-01B-##R (-W) Where ## = Side Wire Gauge -W = IP Rating 67 (Else IP Rating is 63) Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device is intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications and dimensions subject to change without notice. Rev A 07/2018 - Page: 1/1 Code G02-01H
LPK-01B-14R-W 价格&库存
很抱歉,暂时无法提供与“LPK-01B-14R-W”相匹配的价格&库存,您可以联系我们找货
