LPR-05B-16R
LPR-05B-16R
    OPTIFUSE
    REG. FUSEHOLDER, 15A-16AWG RED
LPR-05B-16R 数据手册
Type LPR-05 Water-Proof In-Line Fuse Holder Automotive Blade Type www.optifuse.com Specifications: Rating: 32VDC IP Rating: IP67 Body Material: PVC For use w/ Type APR, ANR Fuse (Regular-Automotive Blade) Water-proof with Inter-Locking Cap Attached Mounting Bracket Standard Wire: #12AWG – 5” - Orange Color (Other wire sizes and colors available as special order) Wire Gauge #12 #16 (619) 593-5050 Max. Amperage 30A 15A Part number format LPR-05B-##Z Where ## = Wire Gauge (12,16 AWG) Z = Wire Color Orange or Red Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. - Not intended for submersible water applications. Note: All specifications subject to change without notice. Rev C 07/2018 - Page: 1/1 Code Y01-01H
LPR-05B-16R 价格&库存
很抱歉,暂时无法提供与“LPR-05B-16R”相匹配的价格&库存,您可以联系我们找货
