PMC-DS-01-SOS
PMC-DS-01-SOS
    OPTIFUSE
    5 X 20 MM - DRIVER/ SCREW,
PMC-DS-01-SOS 数据手册
Type PMC-DS-01-SOS (formerly PDC-01) Panel Mount Fuse Holder 5 x 20mm Driver / Screw www.optifuse.com (619)-593-5050 Electrical Rating: 10A, 250V AC Fuse Style: 5 x 20mm Material: Body: Nylon Terminals: Nickel-plated copper alloy; terminal, solder type, straight terminal Mounting: Nylon hex nut-rear panel Cap: Slotted Driver type, Screw type Nickel-plated copper alloy insert Terminal: Solder tab - 4.00mm / 0.156” Product Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Fuse Holders are not intended for circuit disconnect. All power should be disconnected before removing fuse. -Avoid contact of Fuse Holder with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 02/2009 - Page: 1/1 Code: J01-01D
PMC-DS-01-SOS 价格&库存
很抱歉,暂时无法提供与“PMC-DS-01-SOS”相匹配的价格&库存,您可以联系我们找货
