DDR4 (PC4)
ECC UDIMM
VP9MUxx72x8xxx
The Viking DDR4 UDIMM memory module offers lower operating voltages, higher
module densities and faster speed categories than the prior DDR3 generation.
JEDEC DDR4 (JESD79-4) has been defined to provide higher performance, with
improved reliability and reduced power, thereby representing a significant
achievement relative to previous DRAM memory technologies.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 1 of 42
vikingtechnology.com
REVISION HISTORY
Revision
A
Release Date
3/19/17
Description of Change
Initial release modified from
PS9MUxx72x8xxx_C. Add 2666 timings and PN
Datasheet
PS9MUxx72x8xxx_VP
Revision A
Checked By (Full Name)
3/13/2017
Viking Technology
Page 2 of 42
Legal Information
Legal Information
Copyright© 2017 Sanmina Corporation. All rights reserved. The information in this document is proprietary and confidential
to Sanmina Corporation. No part of this document may be reproduced in any form or by any means or used to make any
derivative work (such as translation, transformation, or adaptation) without written permission from Sanmina. Sanmina
reserves the right to revise this documentation and to make changes in content from time to time without obligation on the
part of Sanmina to provide notification of such revision or change.
Sanmina provides this documentation without warranty, term or condition of any kind, either expressed or implied,
including, but not limited to, expressed and implied warranties of merchantability, fitness for a particular purpose, and noninfringement. While the information contained herein is believed to be accurate, such information is preliminary, and should
not be relied upon for accuracy or completeness, and no representations or warranties of accuracy or completeness are
made. In no event will Sanmina be liable for damages arising directly or indirectly from any use of or reliance upon the
information contained in this document. Sanmina may make improvements or changes in the product(s) and/or the
program(s) described in this documentation at any time.
Sanmina, Viking Technology, Viking Modular Solutions, and the Viking logo are trademarks of Sanmina Corporation. Other
company, product or service names mentioned herein may be trademarks or service marks of their respective owners.
STATEMENT OF COMPLIANCE
Viking Technology, Sanmina Corporation ("Viking") shall use commercially reasonable efforts to provide components,
parts, materials, products and processes to Customer that do not contain: (i) lead, mercury, hexavalent chromium,
polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE) above 0.1% by weight in homogeneous
material or (ii) cadmium above 0.01% by weight of homogeneous material, except as provided in any exemption(s) from
RoHS requirements (including the most current version of the "Annex" to Directive 2002/95/EC of 27 January, 2003), as
codified in the specific laws of the EU member countries. Viking strives to obtain appropriate contractual protections from
its suppliers in connection with the RoHS Directives.
All printed circuit boards (PCBs) have a flammability rating of UL94V-0.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 3 of 42
288 pin Ordering Information and Module Configuration
Viking Part Number
VP9MU127228HBHyz
VP9MU127228HBJyz1
VP9MU127228HBKyz1
VP9MU1G7228HBHyz
VP9MU1G7228HBJyz1
VP9MU1G7228HBKyz1
VP9MU1G7228JBHyz
VP9MU1G7228JBJyz1
VP9MU1G7228JBKyz1
VP9MU2G7228JBHyz
VP9MU2G7228JBJyz1
VP9MU2G7228JBKyz1
Voltage
Capacity
1.2V
1.2V
1.2V
1.2V
1.2V
1.2V
1.2V
1.2V
1.2V
1.2V
1.2V
1.2V
4GB
4GB
4GB
8GB
8GB
8GB
8GB
8GB
8GB
16GB
16GB
16GB
Module
Configuration
512Mx72
512Mx72
512Mx72
1Gx72
1Gx72
1Gx72
1Gx72
1Gx72
1Gx72
2Gx72
2Gx72
2Gx72
Device
Configuration
512Mx8 (9)
512Mx8 (9)
512Mx8 (9)
512Mx8 (18)
512Mx8 (18)
512Mx8 (18)
1024Mx8 (9)
1024Mx8 (9)
1024Mx8 (9)
1024Mx8 (18)
1024Mx8 (18)
1024Mx8 (18)
Device
Package
4Gb FBGA
4Gb FBGA
4Gb FBGA
4Gb FBGA
4Gb FBGA
4Gb FBGA
8Gb FBGA
8Gb FBGA
8Gb FBGA
8Gb FBGA
8Gb FBGA
8Gb FBGA
DIMM
Ranks
Speed
1
1
1
2
2
2
1
1
1
2
2
2
PC4-17000
PC4-19200
PC4-21300
PC4-17000
PC4-19200
PC4-21300
PC4-17000
PC4-19200
PC4-21300
PC4-17000
PC4-19200
PC4-21300
CAS Latency
CL15 (15-15-15)
CL17 (17-17-17)
CL19 (19-19-19)
CL15 (15-15-15)
CL17 (17-17-17)
CL19 (19-19-19)
CL15 (15-15-15)
CL17 (17-17-17)
CL19 (19-19-19)
CL15 (15-15-15)
CL17 (17-17-17)
CL19 (19-19-19)
Notes:
The lowercase letters y and z are wildcard characters that indicate DRAM vendor and die revisions and /or for customer specific locked
BOMs. Refer to the Viking part number coversheet for details.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 4 of 42
Features
JEDEC Standard Power Supply
o PC4: VDD = VDDQ = 1.2V± 5% (1.14V-1.26V)
o External VPP = 2.5 Volt +10%, -5%
o VDDSPD = 2.5V± 10% (2.25-2.75V)
288 pin Dual-In-Line Memory Module
Edge finger connector ramp zone to reduce insertion force
Point-to-Point topology to reduce loading
Pseudo-open drain (POD12) DQ lines
Internally generated VrefDQ
ECC recovery from command and parity errors
On-chip CA Parity detection for the command/address bus
Programmable CAS Latency: 13,15,16
Programmable CAS Write Latency (CWL).
Programmable Additive Latency (Posted CAS)
Per DRAM addressability is supported
Data Bus Inversion support for x8 devices
Selectable Fixed burst chop (BC4) of 4 and burst length
(BL8) of 8 on-the-fly (OTF) via the mode register set (MRS)
8n prefetch with 2 or 4 selectable bank groups: 16
banks (4 bank groups x 4 banks per bank group)
Separate activation, read, write, refresh operations for
each bank group
7 mode registers
Dynamic On-Die-Termination (ODT) and ODT Park for
improved signal integrity.
Self Refresh and several Power Down Modes
DLL-off mode for power savings
System Level Timing Calibration Support via Write
Leveling and Multi Purpose Register (MPR) Read Pattern
Serial Presence Detect with EEPROM
Two On-DIMM Thermal Sensors
Asynchronous Reset
Bidirectional Differentially Buffered Data Strobes(DQS)
UDIMM dimensions per JEDEC MO-309 maximum limits
RoHS Compliant
DDR4 SPEED BIN Nomenclature
Module Standard
DDR4-14900
DDR4-17000
1
DDR4-19200
1
DDR4-21300
1
DDR4-25600
SDRAM Standard
DDR4-1866
DDR4-2133
DDR4-2400
DDR4-2667
DDR4-3200
Clock
933 MHz
1066 MHz
1200 MHz
1333 MHz
1600 MHz
Notes:
1. Contact Viking for availability date
DDR4 Timing Summary
MT/s
tCK
(ns)
CAS
Latency
(tCK)
tRCD (ns)
tRP (ns)
tRAS (ns)
tRC (ns)
CL-tRCDtRP
DDR4-1866
1.071
13
13.92
13.92
34
47.92
13-13-13
DDR4-2133
0.93
15
14.06
14.06
33
47.05
15-15-15
DDR4-2400
0.83
17
14.16
14.16
32
46.16
17-17-17
DDR4-2666
0.75
22
14.25
14.25
32
46.25
19-19-19
Notes:
CL = CAS Latency, tRCD = Activate –to-Command Time, tRP = Precharge Time. Refer to Speed Bin tables for details.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 5 of 42
Addressing
4GB(1Rx8)
512Mx8 DRAM
8GB(1Rx8)
1024Mx8 DRAM
16GB(2Rx8)
1024Mx8 DRAM
4
4
4
BG Address
BG0~BG1
BG0~BG1
BG0~BG1
Bank Address in a
BG
BA0~BA1
BA0~BA1
BA0~BA1
Row Address
A0~A14
64K:A0~A15
64K:A0~A15
Column Address
A0~ A9
A0~ A9
A0~ A9
512B
512B
512B
4K
8K
8K
# of Bank Groups
Bank Address
Page size
Refresh Count
Note:
Micron datasheet specified 512B / 1KB as page size with “Die revision dependant”.
In Hynix and Samsung Datasheet specfies 512B for x4 Device.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 6 of 42
DDR4 288-pin UDIMM Pin Wiring Assignments/Configurations
Pin#
Description
Pin#
Description
Pin#
Description
Pin#
Description
Pin#
Description
Pin#
Description
196
DQS8_c
102
DQ38
246
VSS
1
12V3, NC
145
12V3, NC
52
DQS17_c,
TDQS17_c
2
VSS
146
VREFCA
53
VSS
197
DQS8_t
103
VSS
247
DQ39
3
DQ4
147
VSS
54
CB6, NC
198
VSS
104
DQ34
248
VSS
4
VSS
148
DQ5
55
VSS
199
CB7, NC
105
VSS
249
DQ35
5
DQ0
149
VSS
56
CB2, NC
200
VSS
106
DQ44
250
VSS
6
150
DQ1
57
VSS
201
CB3, NC
107
VSS
251
DQ45
151
VSS
58
RESET_n
202
VSS
108
DQ40
252
VSS
8
VSS
DQS9_t, DM0_n,
DBI0_n,
TDQS9_t
DQS9_c,
TDQS9_c
152
DQS0_c
59
VDD
203
CKE1
109
253
DQ41
9
VSS
153
DQS0_t
60
CKE0
204
VDD
110
254
VSS
10
DQ6
154
VSS
61
VDD
205
RFU
111
VSS
DQS14_t,
DM5_n,
DBI5_n,
TDQS14_t
DQS14_c,
TDQS14_c
255
DQS5_c
11
VSS
155
DQ7
62
ACT_n
206
VDD
112
VSS
256
DQS5_t
12
DQ2
156
VSS
63
BG0
207
BG1
113
DQ46
257
VSS
13
VSS
157
DQ3
64
VDD
208
ALERT_n
114
VSS
258
DQ47
14
DQ12
158
VSS
65
A12
209
VDD
115
DQ42
259
VSS
15
VSS
159
DQ13
66
A9
210
A11
116
VSS
260
DQ43
16
DQ8
160
VSS
67
VDD
211
A7
117
DQ52
261
VSS
17
161
DQ9
68
A8
212
VDD
118
VSS
262
DQ53
162
VSS
69
A6
213
A5
119
DQ48
263
VSS
19
VSS
DQS10_t,
DM1_n, DBI1_n,
TDQS10_t
DQS10_c,
TDQS10_c
163
DQS1_c
70
VDD
214
A4
120
264
DQ49
VSS
164
DQS1_t
71
A3
215
VDD
121
265
VSS
21
DQ14
165
VSS
72
A1
216
A2
122
VSS
DQS15_t,
DM6_n,
DBI6_n,
TDQS15_t
DQS15_c,
TDQS15_c
266
DQS6_c
22
VSS
166
DQ15
73
VDD
217
VDD
123
VSS
267
DQS6_t
23
DQ10
167
VSS
74
CK0_t
218
CK1_t
124
DQ54
268
VSS
24
VSS
168
DQ11
75
CK0_c
219
CK1_c
125
VSS
269
DQ55
25
DQ20
169
VSS
76
VDD
220
VDD
126
DQ50
270
VSS
26
VSS
170
DQ21
77
VTT
221
VTT
127
VSS
271
DQ51
27
DQ16
171
VSS
78
EVENT_n
222
PARITY
128
DQ60
272
VSS
28
172
DQ17
79
A0
223
VDD
129
VSS
273
DQ61
29
VSS
DQS11_t,
DM2_n, DBI2_n,
TDQS11_t
173
VSS
80
VDD
224
BA1
130
DQ56
274
VSS
30
DQS11_c,
174
DQS2_c
81
BA0
225
A10_AP
131
VSS
275
DQ57
7
18
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 7 of 42
Pin#
Description
Pin#
Description
Pin#
Description
Pin#
Description
Pin#
Description
Pin#
Description
276
VSS
277
DQS7_c
TDQS11_c
31
VSS
175
DQS2_t
82
RAS_n/A16
226
VDD
132
32
DQ22
176
VSS
83
VDD
227
RFU
133
DQS16_t,
DM7_n,
DBI7_n,
TDQS16_t
DQS16_c,
TDQS16_c
33
VSS
177
DQ23
84
S0_n
228
WE_n/A14
134
VSS
278
DQS7_t
34
DQ18
178
VSS
85
VDD
229
VDD
135
DQ62
279
VSS
35
VSS
179
DQ19
86
CAS_n/A15
230
SAVE_n, NC2
136
VSS
280
DQ63
36
DQ28
180
VSS
87
ODT0
231
VDD
137
DQ58
281
VSS
37
VSS
181
DQ29
88
VDD
232
A13
138
VSS
282
DQ59
38
DQ24
182
VSS
89
S1_n
233
VDD
139
SA0
283
VSS
39
183
DQ25
90
VDD
234
A17, NC
140
SA1
284
VDDSPD
184
VSS
91
ODT1
235
C[2], NC
141
SCL
285
SDA
41
VSS
DQS12_t,
DM3_n, DBI3_n,
TDQS12_t
DQS12_c,
TDQS12_c
185
DQS3_c
92
VDD
236
VDD
142
VPP
286
VPP
42
VSS
186
DQS3_t
93
S2_n, C[0]
237
S3_n, C[1]
143
VPP
287
VPP
43
DQ30
187
VSS
94
VSS
238
SA2, RFU
144
RFU
288
VPP
44
VSS
188
DQ31
95
DQ36
239
VSS
45
DQ26
189
VSS
96
VSS
240
DQ37
46
VSS
190
DQ27
97
DQ32
241
VSS
47
CB4, NC
191
VSS
98
242
DQ33
48
VSS
192
CB5, NC
99
243
VSS
49
CB0, NC
193
VSS
100
VSS
DQS13_t,
DM4_n,
DBI4_n,
TDQS13_t
DQS13_c,
TDQS13_c
244
DQS4_c
50
VSS
DQS17_t,
DM8_n, DBI8_n,
TDQS17_t
194
CB1, NC
101
VSS
245
DQS4_t
40
51
195
VSS
Notes:
1. VPP is 2.5V DC
2. Pin 230 is defined as NC for UDIMMs, RDIMMs and LRDIMMs. Pin 230 is defined as SAVE_n (ADR) for NVDIMMs.
3. Pins 1 and 145 are defined as NC for UDIMMs, RDIMMs and LRRDIMMs. Pins 1 and 145 are defined as 12V for Hybrid /NVDIMM DIMMs.
4. A15 needed for 4GBit DRAM, A16 needed for 8GBit DRAM, A17 needed for 16GBit DRAM
5. Only x8 and x16 DRAM support Data Mask (DM) and Data Bus Inversion (DBI). Only x8 DRAM support TDQS
6. DM, DBI & TDQS functions are supported with dedicated one pin labeled as DM_n/DBI_n/TDQS_t.
The pin is bi-directional pin for DRAM. The DM_n/DBI _n pin is Active Low as DDR4 supports VDDQ reference termination.
TDQS function does not drive actual level on the pin. DM, DBI & TDQS functions are programmable through DRAM Mode Register (MR). The
MR bit location is bit A11 in MR1 and bit A12:A10 in MR5 . Write operation: Either DM or DBI function can be enabled but both functions
cannot be enabled simultaneously. When both DM and DBI functions are disabled, DRAM turns off its input receiver and does not expect any
valid logic level. Read operation: Only DBI function applies. When DBI function is disabled, DRAM turns off its output driver and does not drive
any valid logic level. TDQS function: When TDQS function is enabled, DM & DBI functions are not supported. When TDQS function is disabled,
When enabled, the same termination resistance function is applied to the TDQS_t/TDQS_c pins that is applied to DQS_t/DQS_c pins.
DM, DBI & TDQS functions are described in more detail on x8 based datasheets
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 8 of 42
PIN FUNCTION DESCRIPTION
Pin Name
Description
Pin Name
Description
A0-A17'
Register address input
SCL
BA0, BA1
Register bank select input
SDA
BG0, BG1
Register bank group select input
SA0-SA2
RAS_n
Register row address strobe input
PAR
I2C serial bus clock for SPD/TS and
register
I2C serial bus data line for SPD/TS and
register
I2C slave address select for SPD/TS
and register
Register parity input
CAS_n3
Register column address strobe input
VDD
SDRAM core power supply
VREFCA
SDRAM command/address reference
supply
VSS
Power supply return (ground)
2
WE_n4
CS0_n, CS1_n,
CS2_n, CS3_n
CKE0, CKE1
Register write enable input
DIMM Rank Select Lines input
Register clock enable lines input
ACT_n
Register on-die termination control lines
input
Register input for activate input
VDDSPD
Serial SPDrTS positive power supply
DQ0-DQ63
DIMM memory data bus
ALERT_n
Register ALERT_n output
CB0-CB7
DIMM ECC check bits
Data Buffer data strobes (positive line of
differential pair)
Data Buffer data strobes (negative line of
differential pair)
Vpp
DRAM Activation Power Supply
ODT0, ODT1
TDQS9_t-TDQS17_t
TDQS9_c- TDQS17_c
RESET_n
EVENT_n
CK0_t, CK1_t
CK0_c, CK1_c
Register clock input (positive line of
differential pair)
Register clocks input (negative line of
differential pair)
Vtt
RFU
Set Register and SDRAMs to a Known
state
SPD signals a thermal event has
occurred.
SDRAM I/O termination supply
Reserved for future use
Notes:
1. Address A17 is only valid for 16GBit DRAM
2. RAS_n is a multiplexed function with A16. (A16 needed for 8GBit DRAM)
3. CAS_n is a multiplexed function with A15. (A15 needed for 4GBit DRAM)
4. WE_n is a multiplexed function with A14
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 9 of 42
Input/Output Functional Descriptions
Symbol
Type
CK_t, CK_c
Input
CKE0, (CKE1)
Input
CS0_n, (CS1_n)
Input
C0,C1,C2
Input
ODT0, (ODT1)
Input
ACT_n
Input
RAS_n/A16,
CAS_n/A15,
WE_n/A14
Input
DM_n/DBI_n/
TDQS_t,
(DMU_n/DBIU_n),
(DML_n/DBIL_n)
Input/
Output
BG0 - BG1
Input
Function
Clock: CK_t and CK_c are differential clock inputs. All address and control input
signals are sampled on the crossing of the positive edge of CK_t and negative
edge of CK_c.
Clock Enable: CKE HIGH activates, and CKE Low deactivates, internal clock
signals and device input buffers and output drivers. Taking CKE Low provides
Precharge Power-Down and Self-Refresh operation (all banks idle), or Active
Power-Down (row Active in any bank). CKE is asynchronous for Self-Refresh exit.
After VREFCA and VREFDQ have become stable during the power on and
initialization sequence, they must be maintained during all operations (including
Self-Refresh). CKE must be maintained high throughout read and write accesses.
Input buffers, excluding CK, CK_c, ODT and CKE, are disabled during powerdown. Input buffers, excluding CKE, are disabled during Self-Refresh.
Chip Select: All commands are masked when CS_n is registered HIGH. CS_n
provides for external Rank selection on systems with multiple Ranks. CS_n is
considered part of the command code.
Chip ID: Chip ID is only used for 3DS for 2,4,8high stack via TSV to select each
slice of stacked component. Chip ID is considered part of the command code.
On Die Termination: ODT (registered HIGH) enables termination resistance
internal to the DDR4 SDRAM. When enabled, ODT is only applied to each DQ,
DQS_t, DQS_c and DM_n/DBI_n/TDQS_t,NU/TDQS_c (When TDQS is enabled
via Mode Register A11=1 in MR1) signal for x8 configurations. For x16
configuration ODT is applied to each DQ, DQSU_c, DQSU_t, DQSL_t, DQSL_c,
DMU_n, and DML_n signal. The ODT pin will be ignored if MR1 is programmed to
disable RTT_NOM.
Activation Command Input: ACT_n defines the Activation command being entered
along with CS_n. The input into RAS_n/A16, CAS_n/A15 and WE_n/A14 will be
considered as Row Address A16, A15 and A14.
Command Inputs RAS_n/A16, CAS_n/A15 and WE_n/A14 (along with CS_n)
define the command being entered. Those pins have multi function. For example,
for activation with ACT_n Low, those are Addressing like A16,A15 and A14 but for
non-activation command with ACT_n High, those are Command pins for Read,
Write and other command defined in command truth table.
Input Data Mask and Data Bus Inversion: DM_n is an input mask signal for write
data. Input data is masked when DM_n is sampled LOW coincident with that input
data during a Write access. DM_n is sampled on both edges of DQS. DM is muxed
with DBI function by Mode Register A10,A11,A12 setting in MR5. For x8 device,
the function of DM or TDQS is enabled by Mode Register A11 setting in MR1.
DBI_n is an input/output identifying whether to store/output the true or inverted
data. If DBI_n is LOW, the data will be stored/output after inversion inside the
DDR4 SDRAM and not inverted if DBI_n is HIGH. TDQS is only supported in x8.
Bank Group Inputs: BG0 - BG1 define to which bank group an Active, Read, Write
or Precharge command is being applied. BG0 also determines which mode register
is to be accessed during a MRS cycle. x4/8 have BG0 and BG1 but x16 has only
BG0.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 10 of 42
Input/Output Functional Descriptions (cont.)
Symbol
Type
Function
BA0 - BA1
Input
Bank Address Inputs: BA0 - BA1 define to which bank an Active, Read, Write or
Precharge command is being applied. Bank address also determines if the mode
register or extended mode register is to be accessed during a MRS cycle.
Input
Address Inputs: Provided the row address for ACTIVATE Commands and the column
address for Read/Write commands th select one location out of the memory array in the
respective bank. (A10/AP, A12/BC_n, RAS_n/A16, CAS_n/A15 and WE_n/A14 have
additional functions, see other rows. The address inputs also provide the op-code during
Mode Register Set commands. A17 is only defined for the x4 configuration.
A10 / AP
Input
Auto-precharge: A10 is sampled during Read/Write commands to determine whether
Autoprecharge should be performed to the accessed bank after the Read/Write
operation. (HIGH: Autoprecharge; LOW: no Autoprecharge).A10 is sampled during a
Precharge command to determine whether the Precharge applies to one bank (A10
LOW) or all banks (A10 HIGH). If only one bank is to be precharged, the bank is
selected by bank addresses.
A12 / BC_n
Input
Burst Chop: A12 / BC_n is sampled during Read and Write commands to determine if
burst chop (on-the-fly) will be performed. (HIGH, no burst chop; LOW: burst chopped).
See command truth table for details.
RESET_n
Input
Active Low Asynchronous Reset: Reset is active when RESET_n is LOW, and inactive
when RESET_n is HIGH. RESET_n must be HIGH during normal operation. RESET_n
is a CMOS rail to rail signal with DC high and low at 80% and 20% of V DD.
DQ
Input /
Output
Data Input/ Output: Bi-directional data bus. If CRC is enabled via Mode register then
CRC code is added at the end of Data Burst. Any DQ from DQ0~DQ3 may indicate the
internal Vref level during test via Mode Register Setting MR4 A4=High. Refer to vendor
specific datasheets to determine which DQ is used.
CB
Input /
Output
Check Bit Input/ Output: Bi-directional ECC portion of data bus for x72 configurations
Input /
Output
Data Strobe: output with read data, input with write data. Edge-aligned with read data,
centered in write data. For x16, DQSL corresponds to the data on DQL0-DQL7; DQSU
corresponds to the data on DQU0-DQU7. The data strobe DQS_t, DQSL_t, and DQSU_t
are paired with differential signals DQS_c, DQSL_c, and DQSU_c, respectively, to
provide differential pair signaling to the system during reads and writes. DDR4 SDRAM
supports differential data strobe only and does not support single-ended.
A0 - A17
DQS_t,
DQS_c,
DQSU_t,
DQSU_c,
DQSL_t,
DQSL_c
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 11 of 42
Symbol
ALERT_n
TEN
Type
Function
Output
Alert: It has multi functions such as CRC error flag, Command and Address Parity error
flag. If there is error in CRC, then Alert_n goes LOW for the period time interval and
goes back HIGH. IF there is error in Command Address Parity Check, then Alert_n goes
LOW for relatively long period until on going DRAM internal recovery transaction to
complete.
Input
Boundary Scan Mode Enable: Required on x16 devices and optional input on x4/x8 with
densities equal to or greater than 8Gb. HIGH in this pin will enable boundary scan
operation along with other pins. It is a CMOS rail to rail signal with DC high and low at
80% and 20% of VDD.
NC
No Connect: No internal electrical connection is present.
VDDQ
Supply
DQ Power Supply: 1.2 V +/- 0.06 V
VSSQ
Supply
DQ Ground
VDD
Supply
VSS
Supply
Ground
Vpp
Supply
DRAM Activation Power Supply: 2.5V (2.375V min , 2.75 max)
VREFCA
Supply
Reference voltage for CA
ZQ
Supply
Reference Pin for ZQ calibration
Note:
The input only pins (BG0-BG-1, BA0-BA1, A0-A17, ACT_n, RAS_n,/A16, CAS_n/A15, WE_n/A14, CS_n, CKE, ODT, and RESET_n) do not supply
termination.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 12 of 42
MECHANICAL OUTLINE
4.1mm
3.90
mm
Max
133.50 mm Max
31.4 mm
Max
1.50 mm
Max
Notes:
1. All dimensions in mm (inches)
2. Tolerance is +/- 0.0127, unless otherwise stated.
3. Refer to JEDEC Standard Mechanical Outline MO-309 for other details
4. DDR4 PCB is higher and thicker then DDR3 and the gold finger pins may have a ramp zone for easy insertion into DIMM
Sockets
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 13 of 42
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 14 of 42
FUNCTIONAL BLOCK DIAGRAM
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 15 of 42
Notes:
The ZQ ball on each DDR4 component is connected to an external 240Ω ±1% resistor that is tied to ground. It is used for the calibration of
the component’s ODT and output driver.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 16 of 42
DQ Internal Vref Specifications
Parameter
Vref Max operating point
Range 1
Vref Min operating point
Range 1
Range 2
Range 2
Vref Stepsize
Vref Set Tolerance
Vref Step Time
Vref VaIid tolerance
Symbol
Min
Typ
Max
Unit
NOTE
Vref_max_R1
92%
VDDQ
1, 11
Vref_min_R1
60%
VDDQ
1,11
Vref_max_R2
77%
VDDQ
1, 11
0.65%
0.00%
0.00%
0.00%
0.80%
1.63%
0.15%
150
60
0.15%
VDDQ
VDDQ
VDDQ
VDDQ
ns
ns
VDDQ
1,11
2
3,4,6
3,5,7
9
8
10
Vref_min_R2
Vref_step
Vref_set_tol
45%
0.50%
-1 .625%
-0.15%
Vref_time-long
Vref_time-Short
Vref_val_tol
-0.15%
Notes:
1. JESD8-24 specifies Vref to be 70% of VDDQ. Vref DC voltage referenced to VDDQ_DC. VDDQ_DC is 1.2V
2. Vref stepsize increment/decrement range. Vref at DC level.
3. Vref_new = Vref_old+n*Vref_step; n=number of step; if increment use “+”; If decrement use “-”
4. The minimum value of Vref setting tolerance=Vref_new-1.625%*VDDQ.
The maximum value of Vref setting tolerance=Vref_new+1.625%*VDDQ. For n>4
5. The maximum value of Vref setting tolerance=Vref_new-0.15%*VDDQ.
The maximum value of Vref setting tolerance=Vref_new+0.15%*VDDQ. For n&4 tbd
6. Measured by recording the min and max values of the Vref output over the range, drawing a straight line between those points and comparing all
other Vref output settings to that line
7. Measured by recording the min and max values of the Vref output across 4 consecutive steps(n=4), drawing a straight line between those points
and comparing all other Vref output settings to that line
8. Time from MRS command to increment of decrement one step size for Vref
9. Time from MRS command to increment of decrement more than one step size up to full range of Vref
10. Only applicable for DRAM component level test/characterization purpose.
Not applicable for normal mode of operation. Vref valid is to qualify the step times which will be characterized at the
component level.
11. DRAM range1 or 2 set by MRS bit MR6,A6.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 17 of 42
OVERVIEW OF DDR4 UDIMM MODULE OPERATION
The DDR4 architecture is generally a point-to-point topology with a dedicated channel design. The highest system
performance levels can be achieved with DDR4-2133 and beyond, when the system is configured as 1 UDIMM Per
Channel (1DPC). DDR4 has more features than DDR3 with a pseudo-open drain (POD12) 1.2v I/O for the data channel,
trained Vref, bank groups and write CRC. The POD12 interface only applies to the data channel. The address command
channel behave like DDR3 using mid-point termination and mid-point Vref. The new bank group interleaving feature in
DDR4 maximizes data transfer bandwidth.
DDR4 DRAM use pseudo-open drain (POD12) 1.2v drivers with Vdd terminations on DQ lines to increase data rates;
unlike DDR3 DRAM that uses stub-series terminated logic drivers, The DRAM addressing scheme in DDR4 is organized
into bank groups, Side A and Side B. The host DDR4 memory controller interleaves (multiplexes) among the bank groups
to achieve high data rates. DDR4 architecture is a 8n prefetch with bank groups, including the use of two or four selectable
bank groups. This will permit the DDR4 memory devices to have separate activation, read, write or refresh operations
simultaneously underway in each of the unique bank groups to improve overall memory efficiency and bandwidth,
especially when small memory granularities are used.
The data written to the UDIMM is read back the same way. However when writing to the internal registers with a "load
mode" operation, a specific address is required. This requires the controller to know if the rank is mirrored or not. There is
a bit assignment in the SPD that indicates whether the module has been designed with a mirrored feature or not.
DDR4 offers ECC recovery from command and parity errors to prevent the host system from crashing. The use of CRC
parity is an optional feature on address command and data; (Error command blocking when parity enabled and post CA
parity. If the UDIMM does not support CRC, the values of 0x00 will fill the CRC table. The new CA parity feature on the
command/address bus provides a low-cost method of verifying the integrity of command and address transfers over a link,
for all operations.
Some of the main attributes of DDR4 memory are:
1) Internally generated VrefDQ and Calibration.
VrefDQ is supplied by the DRAM internally.
VrefCA is supplied by the board.
2) The ACT_n activate pin replaces RAS#, CAS#, and WE# commands,
3) Alert_n for error checking
4) Bank group Interleaving
5) Improved training modes upon power-up
5) Nominal and dynamic ODT: Improvements to the ODT protocol and a new Park Mode allow for a nominal termination
and dynamic write termination without having to drive the ODT pin
6) DQ bus geardown mode for 2667 Mhz data rates and beyond
7) External VPP at 2.5V (for wordline boost)
8) 1.2V VDD power with power-saving features that include MPSM Maximum Power Savings Mode, Low Power Auto Self
Refresh, Temperature Controlled Refresh, Fine Granularity Refresh, and CMD/ADDT latency. DLL off mode.
Important Note:
Longer boot-up times may be experienced in certain situations due to controller initiated functions such as VrefDQ
calibration, write leveling and other trainings for the UDIMM.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 18 of 42
DDR4 MODE REGISTERS
A12
A11
MR0
RFU
MR1
Qoff
TDQS
MR2
Write
CRC
RFU
MR3
MPR Read Format
MR4
MR5
MR6
Write
Preamble
Read DBI
Enable
A10
A9
Write Recovery and RTP
A7
Test
Mode
Write
Leveling
Rtt_NOM
Rtt_WR
RFU
Write CMD Latency
with CRC and DM
Read
Preamble
Read
Preamble
Training
Enable
Self
Refresh
Abort
Enable
Write DBI
Enable
Data
Mask
Enable
Parity
Persiste
nt Error
tCCD_L and tDLLK Timing
MR7
A8
DLL
Reset
RFU
A6
A5
A4
CAS Latency CL
RFU
RFU
Auto Self Refresh
A3
A2
Burst
Type
CL
Additive Latency
CWL
A1
Burst Length BL
RFU
Temp
Sensor
PerDRAM
Addr
Mode
Gear
down
MPR
Enable
CS-to-Address Latency
CAL
RFU
VrefDQ
Monitor
Enable
Temp
Refresh
Mode
Temp.
Refresh
Range
Rtt_PARK
ODT
input
in
Power
Down
Panty
Error
Status
CRC
Error
Clear
VrefDQ
Training
enable
VrefDQ
Training
Range
DLL
Enable
Ron
RFU
A0
RFU
RFU
MPR Page
Max
Power
Down
Enable
RFU
CMD Address Parity
Latency
VretDQ Training Value
Manufacturing use only to program the RCD
Notes:
Refer to JEDEC documentation for detail of the control/status bits
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 19 of 42
DC OPERATING CONDITIONS AND CHARACTERISTICS
ABSOLUTE MAXIMUM RATINGS
Parameter
Symbol
Value
Unit
Notes
Voltage on any pin relative to GND
Vin, Vout
-0.3 ~ 1.5
V
1,
Voltage on VDD supply relative to GND
VDD
-0.3 ~ 1.5
V
1,3
Voltage on VDDQ supply relative to GND
VDDQ
-0.3 ~ 1.5
V
1,3
Voltage on VPP supply relative to GND
VPP
-0.3 ~ 3.0
V
4
1,5
Module operating temperature (ambient)
Topr
0 ~ 55
C
1,2
Storage temperature
Tstg
-55 ~ +100
C
Notes:
1. Permanent device damage may occur if ‘ABSOLUTE MAXIMUM RATINGS’ are exceeded. Functional operation should be restricted
to recommended operating condition.
Exposure to higher than recommended voltage for extended periods of time could affect device reliability. Stresses greater than those
listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional
operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not
implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability
2. Storage Temperature is the case surface temperature on the center/top side of the DRAM. For the measurement conditions, please
refer to JESD51- 2 standard.
3. VDD and VDDQ must be within 300 mV of each other at all times and VREFCA must be not greater than 0.6 x VDDQ, When VDD and
VDDQ are less than 500 mV; VREF may be equal to or less than 300 mV
4. VPP must be equal or greater than VDD/VDDQ at all times
5. Refer to JEDEC JC451 specification
DRAM Component Operating Temperature Range
Symbol
Toper
Parameter
Rating
Units
Note
Normal Operating Temperature Range
0 to 85
°C
1,2
Extended Temperature Range
85 to 95
°C
1,3
Notes:
1. Operating Temperature TOPER is the case surface temperature on the center / top side of the DRAM. For measurement conditions,
please refer to the JEDEC document JESD51-2.
2. The Normal Temperature Range specifies the temperatures where all DRAM specifications will be supported. During operation, the
DRAM case temperature must be maintained between 0 - 85oC under all operating conditions.
3. Some applications require operation of the DRAM in the Extended Temperature Range between 85oC and 95oC case
temperature. Full specifications are guaranteed in this range, but the following additional conditions apply:
a) Refresh commands must be doubled in frequency, therefore reducing the Refresh interval tREFI to 3.9 µs. It is also possible to
specify a component with 1X refresh (tREFI to 7.8µs) in the Extended Temperature Range. Please refer to the DIMM SPD for
option availability.
b) If Self-Refresh operation is required in the Extended Temperature Range, then it is mandatory to either use the Manual SelfRefresh mode with Extended Temperature Range capability (MR2 A6 = 0b and MR2 A7 = 1b) or enable the optional Auto SelfRefresh mode (MR2 A6 = 1b and MR2 A7 = 0b). DDR4 SDRAMs support Auto Self-Refresh and in Extended Temperature Range
and please refer to component datasheet and/or the DIMM SPD for tREFI requirements in the Extended Temperature Range
tREFI by Device Density
Parameter
Average periodic refresh
interval
Symbol
2Gb
4Gb
8Gb
16Gb
Units
0°C ≤ Tcase ≤ 85°C
7.8
7.8
7.8
7.8
μs
85°C ≤ Tcase ≤ 95°C
3.9
3.9
3.9
3.9
μs
tREFI
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 20 of 42
AC & DC Operating Conditions
DC OPERATING CONDITIONS AND CHARACTERISTICS (POD12)
Symbol
VDD
Rating
Parameter
Supply Voltage VDD:
PC4:1.2V±5%,
VPP
Supply Voltage for Output.
Values in () are at 70% of
VDD
2.5V +10%, -5%
VDDSPD
@2.5V
VDDQ
Units
Notes
Min
Typ
Max
1.14
1.2
1.26
v
1,2,3
1.14
(0.798)
1.2
(0.84)
1.26
(0.882)
v
1
2.375
2.5
2.75
v
3
2.2
2.5
2.8
v
Notes:
1. JESD8-24 specifies Vref to be 70% of VDDQ. Under all conditions VDDQ must be less than or equal to VDD.
2. VDDQ tracks with VDD. AC parameters are measured with VDD and VDDQ tied together.
3. DC bandwidth is limited to 20MHz.,
4. PODI2 1.2 V Pseudo Open Drain Interface has a VDDQ value of 1.2V but the reference voltage allows PODI2 to be used with other VDDQ values.
POD12 signals have pull-up-only parallel input termination and have an asymmetric output drive impedance. For example, if the output drivers were
using a 60 ohm pull-up drive impedance then the pull-down drivers would be expected to produce a 40 ohm pull-down drive impedance. PODI2 does
not explicitly call for series termination resistors, so it is suitable for point-to-point as well as multi-drop stub environments which may require some
additional termination.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 21 of 42
DC CHARACTERISTICS, IDD CURRENTS
IDD DEFINITIONS
Symbol
Parameter
IDD0
One bank ACTIVATE-PRECHARGE current
IPP0
IDD1
IDD2N
IDD2NT
IDD2P
IDD2Q
One bank ACTIVATE-PRECHARGE, Word Line Boost, IPP current
One bank ACTIVATE-READ-PRECHARGE current
Precharge standby current
Precharge standby ODT current
Precharge power-down current
Precharge quiet standby current
IDD3N
IPP3N
IDD3P
IDD4R
IDDQ4R
IDD4W
Active standby current
Active standby IPP current
Active power-down current
Burst read current
Burst read IDDQ current
Burst write current
IDD5B
IPP5B
IDD6N
IDD6E
IDD6R
IDD6A
Burst refresh current (1x REF)
Burst refresh IPP current (1 x REF)
Self refresh current: Normal temperature range (0°C to +85°C)
Self refresh current: Extended temperature range (0°C to +95°C)
Self refresh current: Reduced temperature range (0°C to +45°C)
Auto self refresh current (25°C)
IDD6A
Auto self refresh current (45°C)
IDD6A
Auto self refresh current (75°C)
IDD7
Bank interleave read current
IPP7
Bank interleave read IPP current
IDD8
Maximum power-down current
Notes:
1) DDR4 IDD and IDDQ specs include the same DDR3 IDD and IDDQ specs with these exceptions:
a. IDD2P0 and IDD2P1 are replaced with a single IDD2P. There’s no longer any difference in power for the
DLL because of better DLL power management inside the DRAM device without any benefit for using slow exit.
b. IDD6 is renamed IDD6N Self Refresh Current: Normal Temperature Range
c. IDD6ET is renamed IDD6E Self-Refresh Current: Extended Temperature Range
d. IDD6TC is renamed IDD6AAut0 Self-Refresh Current
e. IDD8 is redefined from (optional) RESET Low Current to IDD8 Maximum Power Down Current, TBD
2) IDD values are an average (not peak) current drawn throughout the entire time that it takes to execute the set of
conditions specified by JEDEC standards.
3) Consult with Viking for tools to help specify the Total Design Power (TDP)
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 22 of 42
IDD6 Specification
Symbol
IDD6N
IDD6E
IDD6R
IDD6A
Temperature Range
o
0 - 85 C
o
0 - 95 C
o
0 - 45 C
o
0 C ~ Ta
Tb ~ Ty
Tz ~ TOPERmax
Value
22
33
10
9
10
16
Unit
mA
mA
mA
mA
mA
mA
Notes
3,4
4,5,6
4,6,9
4,6,7,8
4,6,7,8
4,6,7,8
Notes:
1. Some IDD currents are higher for x16 organization due to larger page-size architecture.
2. Max. values for IDD currents considering worst case conditions of process, temperature and voltage.
3. Applicable for MR2 settings A6=0 and A7=0.
4. Supplier data sheets include a max value for IDD6.
5. Applicable for MR2 settings A6=0 and A7=1. IDD6ET is only specified for devices which support the Extended Temperature Range feature.
6. Refer to the supplier data sheet for the value specification method (e.g. max, typical) for IDD6ET and IDD6TC
7. Applicable for MR2 settings A6=1 and A7=0. IDD6TC is only specified for devices which support the Auto Self Refresh feature.
8. The number of discrete temperature ranges supported and the associated Ta - Tz values are supplier/design specific. Temperature ranges are
specified for all supported values of TOPER. Refer to supplier data sheet for more information.
9. Applicable for MR2 settings TBD. IDD6R is verified by design and characterization, and may not be subject to production test.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 23 of 42
IDD CURRENTS, SINGLE RANK, 4Gbit
Symbol
DDR4-1866
DDR4-2133
DDR4-2400
Units
IDD0
IPP0
IDD1
IDD2N
IDD2NT
IDD2P
IDD2Q
IDD3N
IPP3N
IDD3P
IDD4R
IDDQ4R
IDD4W
IDD5B
IPP5B
IDD6N
IDD6E
IDD6R
IDD6A (25°C)
IDD6A (45°C)
IDD6A (75°C)
IDD7
IPP7
IDD8
522
36
567
396
450
270
351
549
27
396
1260
288
1404
1710
198
180
243
90
81
90
144
1440
90
162
540
36
585
414
486
270
351
567
27
396
1350
324
1584
1710
198
180
243
90
81
90
144
1665
108
162
576
36
612
450
522
288
369
603
27
396
1440
360
1764
1728
198
180
243
90
81
90
144
1890
126
162
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
Notes:
1.
Users should refer to the DRAM supplier data sheet and/or the DIMM SPD to determine if DDR4 SDRAM devices support the following options
or requirements referred to in this material.
2. Values as per Micron Datasheet Revision “A”.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 24 of 42
IDD CURRENTS, 2 RANK, 4Gbit
Symbol
1
IDD0
IPP01
IDD11
IDD2N2
IDD2NT1
IDD2P2
IDD2Q2
IDD3N2
IPP3N2
IDD3P2
IDD4R1
IDDQ4R1
IDD4W1
IDD5B1
IPP5B1
IDD6N2
IDD6E2
IDD6R2
IDD6A2 (25°C)
IDD6A2 (45°C)
IDD6A2 (75°C)
IDD71
IPP71
IDD82
DDR4-1866
DDR4-2133
DDR4-2400
Units
792
306
837
792
720
540
702
1098
54
792
1530
558
1674
1980
468
360
486
180
162
180
288
1710
360
324
810
306
855
828
756
540
702
1134
54
792
1620
594
1854
1980
468
360
486
180
162
180
288
1935
378
324
864
324
900
900
810
576
738
1206
54
792
1728
648
2052
2016
468
360
486
180
162
180
288
2178
414
324
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
Notes:
1. One module rank in the active IDD/PP, the other rank in IDD2P/PP3N.
2. All ranks in this IDD/PP condition.
3. Values as per Micron Datasheet Revision “A.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 25 of 42
IDD CURRENTS, SINGLE RANK, 8Gbit
DDR4-2133
15-15-15
1.2V
DDR4-2400
17-17-17
1.2V
IDD0
IDD0A
IDD1
IDD1A
IDD2N
IDD2NA
IDD2NT
IDD2NL
IDD2NG
IDD2ND
IDD2N_par
IDD2P
IDD2Q
IDD3N
IDD3NA
IDD3P
IDD4R
IDD4RA
IDD4RB
IDD4W
IDD4WA
IDD4WB
IDD4WC
IDD4W_par
IDD5B
315
333
450
468
198
225
225
135
198
180
207
144
180
324
342
189
927
963
945
756
792
846
666
828
1971
333
351
477
504
207
234
234
153
207
189
216
144
189
324
342
198
1017
1062
1044
810
855
810
720
891
1998
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
IDD5F2
IDD5F4
1386
1152
207
306
1530
99
1395
1170
207
306
1557
99
mA
mA
Symbol
IDD6N
IDD6E
IDD7
IDD8
Notes:
1.
2.
Units
mA
mA
mA
mA
Samsung D – Die referred for Idd values.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 26 of 42
IDD CURRENTS, DUAL RANK, 8Gbit
Symbol
1
IDD0
1
IDD0A
1
IDD1
1
IDD1A
2
IDD2N
1
IDD2NA
1
IDD2NT
1
IDD2NL
1
IDD2NG
1
IDD2ND
1
IDD2N_par
2
IDD2P
2
IDD2Q
2
IDD3N
2
IDD3NA
2
IDD3P
1
IDD4R
1
IDD4RA
1
IDD4RB
1
IDD4W
1
IDD4WA
1
IDD4WB
1
IDD4WC
1
IDD4W_par
1
IDD5B
1
IDD5F2
1
IDD5F4
2
IDD6N
2
IDD6E
1
IDD7
2
IDD8
DDR4-2133
15-15-15
1.2V
DDR4-2400
17-17-17
1.2V
459
477
594
612
396
369
369
279
342
324
351
288
477
495
621
648
414
378
378
297
351
333
360
288
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
360
648
684
378
1071
1107
1089
900
936
990
810
972
2115
1530
1296
414
612
1674
198
378
648
684
396
1161
1206
1188
954
999
954
864
1035
2142
1539
1314
414
612
1701
198
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
mA
Units
Notes:
3. Users should refer to the DRAM supplier data sheet and/or the DIMM SPD to determine if DDR4 SDRAM devices support the following options or
4. Samsung D – Die referred for Idd values.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 27 of 42
Input/Output Capacitance
Symbol
Parameter
DDR4-1600, 1867, 2133
DDR4-2400,2667
DDR4-3200
Min
Max
Min
Max
Min
Max
Units
Note
CIO
Input/output capacitance
0.7
1.4
0.7
1.3
TBD
TBD
pF
CDIO
Input/output capacitance delta
-0.1
0.1
-0.1
0.1
TBD
TBD
pF
1,2,3
1,2,3,1
1
CDDQS
CCK
DQS and DQS#
Input capacitance, CK and CK#
0.2
0.05
0.8
0.2
0.05
0.8
TBD
TBD
TBD
TBD
pF
pF
1,2,3,5
1,3
CDCK
Input capacitance delta CK and
CK#
0.05
TBD
TBD
pF
1,3,4
CI
CDI_CTRL
CDl_ADD_CMD
CALERT
CZQ
Input capacitance(CTRL, ADD,
CMD pins only)
Input capacitance delta(All
CTRL
pins only)
ADD/CMD pins only)
lnput/output capacitance of
ALERT
Input/output capacitance of ZQ
0.05
0.2
0.8
0.2
0.7
TBD
TBD
pF
1,3,6
-0.1
0.1
-0.1
0.1
TBD
TBD
pF
1,3,7,8
-0.1
0.1
-0.1
0.1
TBD
TBD
pF
1,2,9,
10
0.5
0.5
1.5
1.5
0.5
0.5
1.5
1.5
TBD
TBD
TBD
TBD
pF
pF
1,3
1,3,12
Notes:
1. This parameter is not subject to production test. It is verified by design and characterization. The silicon only capacitance is validated
by de-embedding the package L & C parasitic. The capacitance is measured with VDD, VDDQ, VSS, VSSQ applied with all other
signal pins floating. Measurement procedure tbd.
2. DQ, DM, DQS_T, DQS_C, TDQS_T, TDQS_C. Although the DM, TDQS_T and TDQS_C pins have different functions, the loading
matches DQ and DQS
3. This parameter applies to monolithic devices only; stacked/dual-die devices are not covered here.
4. Absolute value CK_T-CK_C
5. Absolute value of CIO(DQS_T)-CIO(DQS_C)
6. CI applies to ODT, CS_n, CKE, A0-A17, BA0-BA1, BG0-BG1, RAS_n, CAS_n, WE_n.
7. CDI CTRL applies to ODT, CS_n and CKE
8. CDI_CTRL = CI(CTRL)-0.5*(CI(CLK_T)+CI(CLK_C))
9. CDI_ADD_ CMD applies to, A0-A17, BA0-BA1, BG0-BG1, RAS_n, CAS_n, WE_n.
10. CDI_ADD_CMD = CI(ADD_CMD)-0.5*(CI(CLK_T)+CI(CLK_C))
11. CDIO = CIO(DQ,DM)-0.5*(CIO(DQS_T)+CIO(DQS_C))
12. Maximum external load capacitance on ZQ pin: tbd pF
DC and AC Specifications for the SMBus Interface
The specifications for the SMBus follow JEDEC standards.
Datasheet
PS9MUxx72x8xxx_VP
Revision A
3/13/2017
Viking Technology
Page 28 of 42
Speed Bins by Speed Grade
DDR4-1600 Speed Bins and Operating Conditions
Speed Bin
DDR4-1600
CL-nRCD-nRP
11-11-11
Parameter
Symbol
Min
Unit
NOTE
Max
14
Internal read command to first data
tAA
13.75
5,12
(13.50)
18
ns
Internal read command to first data with
read DBI enabled
tAA_DBI
tAA(min) +
2nCK
tAA(max)
+2nCK
ns
ACT to internal read or write delay time
tRCD
13.75
5,12
(13.50)
ns
PRE command period
tRP
13.75
5,12
(13.50)
ns
ACT to PRE command period
tRAS
35
9 x tREFI
ns
ACT to ACT or REF command period
tRC
48.75
5,12
(48.50)
ns
Normal
Read DBI
CL = 9
CL = 11
5
(Optional)
tCK(AVG)
CL = 10
CL = 12
tCK(AVG)
CL = 10
CL = 12
tCK(AVG)
CL = 11
CL = 13
tCK(AVG)
1.25
CL = 12
CL = 14
tCK(AVG)
1.25
CWL = 9
CWL = 9,11
ns
1,2,3,4,11
,14
ns
1,2,3,4,11
ns
1,2,3,4
