VRFDUC3L4096YIH3V1
VRFDUC3L4096YIH3V1
    VIKINGTECHNOLOGY
    模块
    存储器 - 模块 FLASH - NAND(SLC) 4GB 模块
VRFDUC3L4096YIH3V1 数据手册
Viking eUSB Embedded USB Manual ~ Industrial Products Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 1 of 20 Revision History Date Revision A 9/12/14 B 11/4/14 Description Initial release VRFDUC3(L)032GYCNxx PN for SM3252 VRFDUC3032GYCNE1 (12/13/2013) Update PN table for new PN’s and 16GB (A1, 6/2/2014) Revised Standby Current and Operating Current based on 3.3V NAND devices (A2, 7/8/14) Removed firmware upgrade capability (A3, 8/8/14) Add VRFDUC31024YCG PN (9/12/14). Update PN table description Add tolerance info to Mechanical Dimensions C 3/27/15 Revise PN table to match PSG D 6/16/15 Revise PN table 4GB P/N at 5.0V 2-CH: VRFDUC3(L)4096YxHyy 4GB P/N at 3.3V 2-CH: VRFDUC3(L)4096YxH3yy E 9/1/2015 F 11/9/2015 G 6/12/16 H 10/27/2017 Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com Add VRFDUC3(L)2048YxE3yy and VRFDUC3(L)2048YxEyy per PSG update update with performance based on IOmeter06 for SMI 3252 controller Added Part Number VRFDUC3(L)2048YxGyy. Added Note 6 on Figure 3-4 Dimensions (Version 2, standard profile) to show maximum component height on secondary side (Bottom) is 3.7 ± 0.06 mm[0.145± 0.003 inches] specify the SCSI commands supported by the SMI 325/3252 controller. Change logo and color scheme . Add VRFDUC3(L)2048YxG3yy and PN decoder 10/27/2017 Viking Technology Page 2 of 20 Legal Information Legal Information Copyright© 2017 Sanmina Corporation. All rights reserved. The information in this document is proprietary and confidential to Sanmina Corporation. No part of this document may be reproduced in any form or by any means or used to make any derivative work (such as translation, transformation, or adaptation) without written permission from Sanmina. Sanmina reserves the right to revise this documentation and to make changes in content from time to time without obligation on the part of Sanmina to provide notification of such revision or change. Sanmina provides this documentation without warranty, term or condition of any kind, either expressed or implied, including, but not limited to, expressed and implied warranties of merchantability, fitness for a particular purpose, and noninfringement. While the information contained herein is believed to be accurate, such information is preliminary, and should not be relied upon for accuracy or completeness, and no representations or warranties of accuracy or completeness are made. In no event will Sanmina be liable for damages arising directly or indirectly from any use of or reliance upon the information contained in this document. Sanmina may make improvements or changes in the product(s) and/or the program(s) described in this documentation at any time. Sanmina, Viking Technology, Viking Modular Solutions, and the Viking logo are trademarks of Sanmina Corporation. Other company, product or service names mentioned herein may be trademarks or service marks of their respective owners. Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 3 of 20 Ordering Information: eUSB Family Viking High Performance USB embedded Drive Ordering Information Part Number VRFDUC3(L)2048YxE3yy VRFDUC3(L)2048YxG3yy VRFDUC3(L)4096YxH3yy VRFDUC3(L)8192YxK3yy VRFDUC3(L)016GYxK3yy VRFDUC3(L)030GYxN3yy Capacity 2GB 2GB 4GB 8GB 16GB 30GB Device Density 8Gb 8Gb 16Gb 32Gb 32Gb 64Gb Voltage 3.3 3.3 3.3 3.3 3.3 3.3 # Devices 2 2 2 2 4 4 Channels 2 2 2 2 2 2 LBA 3,928,176 3,928,176 7,835,184 15,649,200 31,277,232 62,533,296 VRFDUC3(L)2048YxEyy VRFDUC3(L)2048YxGyy VRFDUC3(L)4096YxHyy VRFDUC3(L)8192YxKyy VRFDUC3(L)016GYxKyy VRFDUC3(L)030GYxNyy 2GB 2GB 4GB 8GB 16GB 30G 8Gb 8Gb 16Gb 32Gb 32Gb 64Gb 5 5 5 5 5 5 2 2 2 2 4 4 2 2 2 2 2 2 3,928,176 3,928,176 7,835,184 15,649,200 31,277,232 62,533,296 Notes: 1. DUC3xxxx signifies standard profile, DUC3Lxxxx signifies low profile. 2. x = C for Commercial temperature range: 0 to 70°C (32 to 158° F) or I for Industrial temperature range: -40 to 85°C (-40 to 185° F) 3. Storage capacity listed will vary due to formatting and additional functions, and therefore is not available for storage. 4. USB’s ship formatted from the factory unless otherwise requested. 5. All eUSBs are based on SLC flash unless otherwise requested. 6. All capacities are available in 3.3V versions. 7. yy indicates BOM specific information 8. “L” indicate low profile 9. Maximum of 4KB per page Part Number Decoder VRFDUC3(L)xxxxYCy(3)(M)zz Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com Form Factor xxxx =Capacity (GB) Controller Temp Blank=eUSB Std Profile L=eUSB Low Profile 4G=4096 8G=8192 16G=016G 32G=032G Y= SMI3252 (USB) I=(-40 to +85 ºC) C=(0 to +70'c) y= Device code Voltage NAND M=MLC 3 = 3.3V Blank=5V Blank= SLC Customer unique Alpha Numeric zz=wildcard characters Blank= Generic 10/27/2017 Viking Technology Page 4 of 20 Table of Contents 1 INTRODUCTION 7 1.1 Product Overview 7 1.2 Features 7 1.3 Block Diagram 8 1.4 USB Interface 9 2 PRODUCT SPECIFICATIONS 9 2.1 Performance 9 2.2 Timing 9 2.3 Power-up AC timing Requirements 9 2.4 Electrical Characteristics 2.4.1 Absolute Maximum Ratings 2.4.2 DC Operating Conditions and Characteristics 2.4.3 Power Consumption 2.4.4 Capacitance 10 10 10 10 11 2.5 Environmental Conditions 2.5.1 Temperature and Altitude 11 11 2.6 Reliability 11 3 MECHANICAL INFORMATION 13 4 PIN AND SIGNAL DESCRIPTIONS 17 4.1 Signal and Power Description Tables 17 5 COMMAND SETS 18 6 CERTIFICATIONS AND COMPLIANCE 19 Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 5 of 20 7 REFERENCES 19 Table of Tables 1 Table 2-1: Sustained Read and Write Bandwidth _____________________________________ 9 Table 2-2: Maximum Sustained Read and Write Bandwidth _____________________________ 9 Table 2-3: Timing Specifications __________________________________________________ 9 Table 2-4: Absolute Maximum Ratings ____________________________________________ 10 Table 2-5: Voltage and Current Ratings ____________________________________________ 10 Table 2-6: Power Consumption __________________________________________________ 11 Table 2-7: Bus Line Capacitance _________________________________________________ 11 Table 2-8: Temperature and Altitude Related Specifications ____________________________ 11 Table 2-9: Reliability Specifications _______________________________________________ 11 Table 4-1: eUSB Connector Pin Signal Definitions ___________________________________ 17 Table 5-1: SCSI Feature Set ____________________________________________________ 18 Table 5-2: SCSI Error Codes List _________________________________________________ 19 Table 6-1: Device Certifications __________________________________________________ 19 Table of Figures Figure 1-1: High-Level Block Diagram ______________________________________________ 8 Figure 3-1: Location of PCB # marking ____________________________________________ 13 Figure 3-2: Dimensions (Version-1) _______________________________________________ 14 Figure 3-3: Dimensions (Version-2, low profile) ______________________________________ 15 Figure 3-4: Dimensions (Version 2, standard profile) __________________________________ 16 Figure 4-1: Connector Pin Assignments ____________________________________________ 17 Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 6 of 20 1 Introduction 1.1 Product Overview Viking Technology’s Embedded USB (eUSB) module provides a rugged, reliable and cost effective non-volatile memory, solutions to OEM customers in the Communication, Networking, Embedded and Industrial markets. The eUSB module is a secure pluggable device and a drop-in replacement for Intel® ZU130 Value Solid State Drive with a USB 2.0 interface, ECC and global wearleveling. Additional options such as MLC (Multi Level Cell) technology and ESD protection are also available. Viking’s rugged industrial designed USB’s offer the highest flash storage reliability and performance in harsh environments such as shock, vibration, humidity, altitude, ESD, and extreme temperatures. Viking USB’s meet JEDEC JESD22 standards and pass numerous qualifications including MIL-STDs and NEBS. Viking can also provide specialized services to OEMs designing customized hardware and systems by offering:  Locked BOM control with customer product change notification (PCN)  Pre-installed software, custom software imaging and ID strings  Custom packaging and labeling  Comprehensive supply-chain management  Customer specified testing  30k volt ESD protection  Conformal coating  Localized Field Application Engineering for complete pre and post sale technical support 1.2 Features The embedded USB drive delivers the following features:  USB 2.0 high speed compatible (supports Bulk-Only transport protocol)*  Up to 35 MB/s Read Speed and 23 MB/s Write Speed (Dual Channel)  Up to 23 MB/s Read Speed and 12 MB/s Write Speed (Single Channel)  Host Interface Speed 60MB/s  Drive Activity indicator signal  Low power Dissipation- less than 0.45W active; less than 1mW standby Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 7 of 20    Solid state, Non-volatile NAND Memory RoHS Compliant Static Wear Leveling * With exception of 3.3V only operation, USB specification is 5V. 1.3 Block Diagram Figure 1-1: High-Level Block Diagram USB/NAND CONTROLLER VOLTAGE REGULATOR 5V – 3.3V 3.3V 5.0V 5V RAM BUFFER LOCAL MICROPROCESSOR USB ENDPOINT CONTROLLER HOST CONNECTOR DM ` FLASH NAND DP DATA BUFFER GND #ACTIVE FLASH MEMORY INTERFACE (DUAL CHANNEL) ECC OSCILLATOR Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 8 of 20 1.4 USB Interface    The USB interface is compliant with the USB 2.0 specification. The USB interface connects the host computer to the embedded USB. The USB interface runs at a maximum speed of 2.0 Gbps (gigabits per second). If the host computer is unable to negotiate a speed of 2.0 Gbps, the USB interface automatically renegotiates to lower speeds. 2 Product Specifications 2.1 Performance The host interface speed is 60MB/s with a read/write bandwidth shown in the following tables. Table 2-1: Sustained Read and Write Bandwidth1 Access Type Read, Dual Channel Write, Dual Channel MB/s Up to 31.2 Up to 17.4 Notes: 1.Based on VRFDUC3L032GYCNE1 MicSLC SM3252 using IOMETER06 2.Based on VRFDUC3L016GYIKK1 TosSLC SM3252 using IOMETER06 Table 2-2: Maximum Sustained Read and Write Bandwidth Access Type Read, Dual Channel Write, Dual Channel MB/s Max up to 35 Max up to 23 2.2 Timing Table 2-3: Timing Specifications 2.3 Power-up AC timing Requirements Parameter Symbol Min. Typical Max. Unit Powerup to Ready (from 2.7V VBUS) tRESET 100 150 250 ms Notes: 1. This power-up timing can be changed to 10ms upon request. The long power-up delay is designed to accommodate slow power-up times of rack systems. Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 9 of 20 2.4 Electrical Characteristics 2.4.1 Absolute Maximum Ratings Table 2-4: Absolute Maximum Ratings Parameter Symbol Value Unit 5.0 Supply Voltage VBUS -0.3 ~ 5.5 V 3.3 Supply Voltage VBUS -0.3 ~ 4.0 V Input Voltage VIN GND - 0.5 ~ VCC + 0.5 V Storage Temperature TST -55 ~ 150 C Notes: 1. Permanent device damage may occur if ‘ABSOLUTE MAXIMUM RATINGS’ are exceeded. Functional operation should be restricted to recommended operating condition. Exposure to higher than recommended voltage for extended periods of time could affect device reliability. 2.4.2 DC Operating Conditions and Characteristics Table 2-5: Voltage and Current Ratings Parameter Symbol Min. Typical Max. Unit 5.0 Supply voltage (± 5%) 3.3 Supply voltage (± 5%) Regulated Output Voltage (internal eUSB voltage) Input high voltage VBUS VBUS 4.75 3.14 5.0 3.3 5.25 3.465 V V VDD33O 2.9 3.3 3.6 V VIH VIL VOH VOL 2.0 2.4 - 16.5 + 6.6 16.5 + 13.2 16.5 + 19.8 132 + 9.9 132 + 19.8 132 + 39.6 0.8 V V V V µA µA µA mA mA mA Input low voltage Output high voltage Output low voltage Standby Current 2 Operating Current 2 1 Flash Device 2 Flash Devices 4 Flash Devices 1 Flash Device 2 Flash Devices 4 Flash Devices ISTB IOP 0.4 23.1 + 33 23.1 + 66 23.1 + 132 165 + 19.8 165 + 39.6 165 + 79.2 Notes: 1. Recommended operating conditions (Voltages referenced to GND, TA = 0 to 70C) 2. Based on 3.3V NAND 2.4.3 Power Consumption All onboard power requirements of the eUSB are derived from the 5V or 3.3V input rail. Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 10 of 20 Table 2-6: Power Consumption Power Standby Operating Typical 1 450 units mW mW 2.4.4 Capacitance Table 2-7: Bus Line Capacitance Parameter Bus line capacitance Symbol Min Max Unit CL - 20 pF 2.5 Environmental Conditions 2.5.1 Temperature and Altitude Table 2-8: Temperature and Altitude Related Specifications Conditions Commercial Temperature Industrial 1 Temperature Humidity (noncondensing) Max Temperature Gradient Altitude Storage Time Duration Operating 0 to 70°C (32 to 158° F) -40 to 85°C (-40 to 185° F) Shipping -40 to 85°C (-40 to 185° F) -40 to 85°C (-40 to 185° F) Storage -40 to 85°C (-40 to 185° F) -40 to 85°C (-40 to 185° F) 5% to 95% 5% to 95% 5% to 95% 20°C/Hour (36°F/Hour) -304.8 to 24,384 m (-1,000 to 80,000 ft) n/a n/a -304.8 to 24,384 m (-1,000 to 80,000 ft) -304.8 to 24,384 m (-1,000 to 80,000 ft) n/a n/a 1 year Notes: 1. SLC flash based products are available in the following temperature ranges: a) Commercial temperature range of 0 to 70°C (32 to 158° F) b) Industrial temperature range -40 to 85°C (-40 to 185° F) 2.6 Reliability Table 2-9: Reliability Specifications Parameter Value Mean Time Between Failures (MTBF) Power On/Off Cycles Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 2 1 2,500,000 hours 50,000 cycles 10/27/2017 Viking Technology Page 11 of 20 Parameter Read Endurance 3 Write or Erase Endurance Wear-leveling Data retention Value Unlimited (specified by the flash component) Global >10 years Notes: 1. MTBF is calculated based on a Part Stress Analysis. It assumes nominal voltage, with all other o parameters within specified range. Telcordia method SR-332 component FIT rate at 55 c. 2. Power On/Off Cycles defined as power being removed from the drive, and then restored. Note that host systems and drive enclosures may remove power from the drive for reasons other than a system shutdown. 3. SLC NAND has a higher endurance then MLC NAND Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 12 of 20 3 Mechanical Information The dimensions of the eUSB (version-1) are based on the following PCB #s: 1208, 1209 As an example, the 1208 PCB would have a 0001208A marking that is silkscreened at the bottom edge of the PCB near the mounting hole on the same side as the connector (at bottom side of the eUSB) as shown in the following figure. Figure 3-1: Location of PCB # marking PCB # Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 13 of 20 Figure 3-2: Dimensions (Version-1) See Note 5 See Note 5 Notes: 1. PCB number is silkscreened on the PCB 2. Dimensions shown in millimeters [inches] 3. Max screw penetration is 5mm at all 4 locations. 4. The module connector height is 7.4 ± 0.13 [0.290± 0.005] plus standoff ~ 0.45mm ± 0.13 when mounted to a PCB. 5. Connector height with standoff is 8.00± 0.13 [0.315± 0.005] 6. PCB Tolerance is +/- 0.127mm [0.005 inch], unless otherwise stated Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 14 of 20 The dimensions of the eUSB (version 2) are based on the following PCB #s: 1448, 1449 Figure 3-3: Dimensions (Version-2, low profile) PCB thickness Primary Side (Top View) (Bottom View) Overall thickness Side View Low profile Module Connector: SAMTEC SMM-105-02-F-D-LC-09-P-TR Pitch: 2.00mm Secondary Side Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 15 of 20 Figure 3-4: Dimensions (Version 2, standard profile) PCB thickness See Note 4 Primary Side (Top View) (Bottom View) Secondary Side Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com Overall thickness Side View Notes: 1. Standard Profile Module Connector: SAMTEC SSM-105-L-DV-LC-009-P-TR Pitch: 2.54mm 2. Dimensions shown in millimeters 3. Max screw penetration is 5mm at all 4 locations. 4. The module connector height is 7.4 ± 0.13mm [0.290± 0.005 inches] 5. PCB Tolerance is +/- 0.127mm [0.005 inch], unless otherwise stated 6. Maximum component height on secondary side (Bottom) is 3.7 ± 0.06 mm[0.145± 0.003 inches] 10/27/2017 Viking Technology Page 16 of 20 4 Pin and Signal Descriptions Figure 4-1: Connector Pin Assignments 4.1 Signal and Power Description Tables Table 4-1: eUSB Connector Pin Signal Definitions Pin 1 2 3 4 5 6 7 8 9 Signal Name VBUS NC DM NC DP NC GND NC N/A Type Power NC I/O NC I/O NC Power NC Key 10 #Activity I/O Description 3.3 or 5V power supply Not connected USB 2.0 Data Negative Pin Not connected USB 2.0 Data Positive Pin Not connected Ground Not connected Polarization Status signal that indicates when the drive is busy. This signal may be used to drive a low current LED or other logic on the host to indicate drive status to the user or system. This signal is active low and has a 4mA drive strength. Notes: 1. * Available custom options: Pin 2 Chassis ground option; Pin 4 Hardware /WP; Pin 6 Hardware /Reset. Custom options available on locked BOMs only. Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 17 of 20 5 Command Sets The tables below summarize the supported SCSI feature set and commands. Table 5-1: SCSI Feature Set SCSI Command OpCode TEST_UNIT_READY 0x00 REZERO_UNIT 0x01 * REQUEST_SENSE 0x03 FORMAT 0x04 INQUIRY 0x12 MODE_SELECT_6 0x15 * MODE_SENSE_6 0x1A START_STOP_UNIT 0x1B SEND_DIAGNOSTIC 0x1D * PREVENT/ALLOW MEDIUM REMOVE 0x1E + READ_FORMAT_CAPACITIES 0x23 READ_CAPACITY 0x25 READ_10 0x28 WRITE_10 0x2A SEEK 0x2B * WRITE_AND_VERIFY 0x2E VERIFY 0x2F * SYNCHRONIZE_CACHE 0x35 * READTOC 0x43 PLAY_AUDIO_10 0x45 * MODE_SELECT_10 0x55 * MODE_SENSE_10 0x5A READ_12 0xA8 WRITE_12 0xAA Notes: 1. SM3252BB/SM325AC SMI Controller 2. Note *: Recognize the command and just response PASS status. No other process. 3. Note +: Recognize the command and just response PASS or Fail status. No other process. 4. Note others : Support command function but not full as described in spec. For example: Command WRITE_AND_VERIFY has write function only. Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 18 of 20 Table 5-2: SCSI Error Codes List 6 Certifications and Compliance Table 6-1: Device Certifications Certification/Compliance RoHS EU WEEE Compliant Safety Description Viking Technology, Sanmina Corporation ("Viking") shall use commercially reasonable efforts to provide components, parts, materials, products and processes to customers that do not contain: (i) lead, mercury, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE) above 0.1% by weight in homogeneous material or (ii) cadmium above 0.01% by weight of homogeneous material, except as provided in any exemption(s) from RoHS requirements (including the most current version of the "Annex" to Directive\ 2002/95/EC of 27 January, 2003), as codified in the specific laws of the EU member countries. Viking strives to obtain appropriate contractual protections from its suppliers in connection with the RoHS Directives. The Waste Electrical and Electronic Equipment Directive (WEEE Directive) is the European Community directive 2002/96/EC on waste electrical and electronic equipment (WEEE) which, together with the RoHS Directive 2002/95/EC, became European Law in February 2003, setting collection, recycling and recovery targets for all types of electrical goods. All printed circuit boards (PCBs) have a flammability rating of UL94V-0. 7 References  USB Specification, version 2.0 Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com 10/27/2017 Viking Technology Page 19 of 20 Index Dimensions ................................... 14 Endurance .................................... 12 Environmental Conditions ............. 11 Erase Endurance .......................... 12 Humidity ........................................ 11 Manual PSFDUC3XXXXYXX Revision H www.vikingtechnology.com MTBF ............................................ 11 Power Consumption ................ 10, 11 Temperature.................................. 11 Timing Specifications ...................... 9 Wear-leveling ................................ 12 10/27/2017 Viking Technology Page 20 of 20
VRFDUC3L4096YIH3V1 价格&库存
很抱歉,暂时无法提供与“VRFDUC3L4096YIH3V1”相匹配的价格&库存,您可以联系我们找货
