WP2806008UH(S)
Unmatched GaN HEMT
Product Features
Applications
Up to 6GHz Operation
Broadband Amplifiers
14dB Small Signal Gain at 4.7GHz
Cellular Infrastructure
11.7 W Typical PSAT at 4.7GHz
Test Instrumentation
61% Efficiency at PSAT at 4.7GHz
WiMAX, LTE, WCDMA, GSM
28V Operation
Radar Application
Package Type: 360BH
Absolute Maximum Rating
Parameter
Symbol
Rating
Units
Conditions
Drain-Source Voltage
VDSS
160
Volts
25˚C
Gate-to-Source Voltage3
VGS
-10, +2
Volts
25˚C
Storage Temperature3
TSTG
-65, +150
˚C
Operating Junction Temperature1,3
TJ
225
˚C
Maximum Forward Gate Current3
IGMAX
30
mA
25˚C
Maximum Drain Current2
IDMAX
1
A
Id@ Vd =10V, Vg= 1V
Soldering Temperature3
TS
245
˚C
1.
2.
3.
Continuous use at maximum temperature will affect MTTF.
Current limit for long term, reliable operation.
After additional updates.
DC Characteristics1 (TA=25˚C)
Parameter
Symbol
MIN
TYP
MAX
Units
Conditions
Gate Threshold Voltage
VGS(th)
-3.1
VDC
VDS = 10V, ID = 1mA
Gate Quiescent Voltage
VGS(Q)
-2.23
VDC
VDS = 28V, ID = 70mA
Saturated Drain Current2
IDS
1000
mA/mm
VDS = 10V, VGS = 1V
Drain-Source Breakdown Voltage
VBR
VDC
ID = 1 mA/mm
160
1. Measured on wafer prior to packaging.
2. Scaled from PCM data.
RF Characteristics (TA=25˚C, F0=4.6GHz, Unless otherwise noted)
Parameter
Symbol
MIN
TYP
MAX Units
Conditions
Power Gain
GSS
11
dB
VDD = 28V, IDQ = 70mA, Pulse Width = 100usec, Duty Cycle = 10%
Output Power
POUT
6
W
Saturated Output Power
PSAT
11.6
W
Pulsed Drain Efficiency1
n
58
VDD = 28V, IDQ = 70mA, Pulse Width = 100usec, Duty Cycle = 10% @ PSAT
Output Mismatch Stress
VSWR
10:1
No damage at all phase angles, VDD = 28V, IDQ = 70mA, POUT = 1 WCW
1. Drain Efficiency = POUT / PDC
All specifications may change without notice.
Version 2.0
1
WAVEPIA Co., LTD.
sales@wavepia.com
http://www.wavepia.com
WP2806008UH(S)
Unmatched GaN HEMT
Pulse Signal Performance (TA=25℃, Measured in the test board amplifier circuit)
VDD=28V, IDQ=70mA, Pulse Width=100μsec, Duty Cycle=10%
Version 2.0
2
WAVEPIA Co., LTD.
sales@wavepia.com
WP2806008UH(S)
Unmatched GaN HEMT
Small Signal Performance (TA=25℃, Measured in the test board amplifier circuit)
VDD=28V, IDQ=70mA
Version 2.0
3
WAVEPIA Co., LTD.
sales@wavepia.com
WP2806008UH(S)
Unmatched GaN HEMT
Evaluation Board
Reference Number
Value
Items
Package
Manufacturer
C2
0.3 pF
High Q Capacitor
0805
Johanson
C3
2.2 pF
High Q Capacitor
0603
Johanson
C4
0.5 pF
High Q Capacitor
0603
Johanson
C5
10 pF
High Q Capacitor
0603
Johanson
C6, C7
220 pF
High Q Capacitor
0805
Johanson
C8
1 nF
High Q Capacitor
0805
Johanson
C9
1 uF
High Q Capacitor
0805
Johanson
C10
10 uF
Tantalum Capacitor
B
Vishay
C11
1.5 pF
High Q Capacitor
CHA
Temex
C12
3 pF
High Q Capacitor
CHA
Temex
C13
15 pF
High Q Capacitor
CHA
Temex
C14
100 pF
High Q Capacitor
CHA
Temex
C1
220 nF
High Voltage Capacitor
3225
Johanson Dielectrics
C15
470 nF
4532
R1
300 ohm
Chip Resistor
0603
Samsung
R2
11 ohm
Chip Resistor
0603
Samsung
Version 2.0
4
WAVEPIA Co., LTD.
sales@wavepia.com
WP2806008UH(S)
Unmatched GaN HEMT
Product Dimension
• Package Type: 360BS (Surface mount)
• Unit: mm
Version 2.0
5
WAVEPIA Co., LTD.
sales@wavepia.com
WP2806008UH(S)
Unmatched GaN HEMT
Product Dimension
• Package Type: 360BH (Through hole)
• Unit: mm
Version 2.0
6
WAVEPIA Co., LTD.
sales@wavepia.com
WP2806008UH(S)
Unmatched GaN HEMT
Part Number System
W P 2 8 0 6 0 0 8 U H/S
▪ S (Surface mount), H (Through Hole)
▪ M (Matched), U (Unmatched)
▪ Power Output (W)
▪ Frequency (GHz)
▪ Drain Voltage (DC)
▪ WAVEPIA
Parameter
Value
Units
Drain Voltage
28
V
Lower Frequency
DC
GHz
Upper Frequency
6
GHz
Output Power
8
W
Transistor Type
Unmatched
Package
S: Surface mount
H: Through hole
Version 2.0
7
WAVEPIA Co., LTD.
sales@wavepia.com
很抱歉,暂时无法提供与“WP2806008UH”相匹配的价格&库存,您可以联系我们找货
