MTI-680-DK
MTI-680-DK
    XSENS
    MTi-680 MTi 600 加速计,陀螺仪,磁力计,压力 评估板 - 传感器
MTI-680-DK 数据手册
MTi-680 3150 The MTi-680 is a Global Navigation Satellite System/Inertial Navigation System (GNSS/INS) with an integrated Real-Time Kinematic GNSS receiver. The MTi-680’s added RTK feature means you can improve your positional data from meter-level to centimeter-level accuracy. This easy-to-use GNSS/INS module is designed for easy integration and seamless interfacing with other equipment. The MTi-680 is supported by the MT Software Suite, which includes MT Manager (GUI for Windows/Linux), SDK, example codes and drivers for many platforms. Sensor Fusion Performance 28. mm 00 mm 13.00 mm • Small, IP51-rated RTK GNSS/INS • 0.2 deg roll/pitch & cm-level position accuracy • Connects to external RTK GNSS receiver • White label and OEM integration options available • 3D models available on request • Available online via Digi-Key, Mouser, Farnell and local distributors Mechanical Roll, Pitch 0,2 deg RMS IP-rating IP51 Yaw/Heading 0.5 deg RMS Operating Temperature -40 to 85 ºC Position
MTI-680-DK 价格&库存
很抱歉,暂时无法提供与“MTI-680-DK”相匹配的价格&库存,您可以联系我们找货
MTi-680-DK
    • 1+11996.25334
