MTi-680
3150
The MTi-680 is a Global Navigation Satellite System/Inertial Navigation System (GNSS/INS) with
an integrated Real-Time Kinematic GNSS receiver.
The MTi-680’s added RTK feature means you can
improve your positional data from meter-level to
centimeter-level accuracy. This easy-to-use GNSS/INS module is designed for easy integration and
seamless interfacing with other equipment.
The MTi-680 is supported by the MT Software
Suite, which includes MT Manager (GUI for Windows/Linux), SDK, example codes and drivers for
many platforms.
Sensor Fusion Performance
28.
mm
00
mm
13.00 mm
• Small, IP51-rated RTK GNSS/INS
• 0.2 deg roll/pitch & cm-level position accuracy
• Connects to external RTK GNSS receiver
• White label and OEM integration options available
• 3D models available on request
• Available online via Digi-Key, Mouser, Farnell and
local distributors
Mechanical
Roll, Pitch
0,2 deg RMS
IP-rating
IP51
Yaw/Heading
0.5 deg RMS
Operating Temperature
-40 to 85 ºC
Position
很抱歉,暂时无法提供与“MTI-680”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8208.97876
- 5+8182.66793
