BV0507EP3I155D030N100 数据手册
Features
Applications
● High frequency & Low Noise
● SMD Package (7.0×5.0mm)
● Quick Warm-up
Low vibration RF Communication
Wireless Communication
Low Phase Noise Signal Resource
SDH/SONET
GNSS
BV0507E Specifications
Parameter
Supply Voltage
Supply Current
LVDS
Value
Typ.
Max.
3.3
V
Vcc±5%
5
V
Vcc±5%
Unit
80
10 ~ 156.52
40,80, 100, 120, 122.88
±10
±12
±15
MHz
MHz
ppm
Frequency Range
Nominal Frequency
Freq. Stability Vs. Temp.
LVPECL
Min.
Conditions
mA
VOH
1.86
2.11
V
VOL
1.06
1.31
V
Duty Cycle
45
55
Rise/Fall Edge
0.2
1
ns
Load
50
pf
Vpp
250
350
450
mV
Vos
-40℃~+85℃
( VOH - VOL)/2
1.125.
1.25
1.375
V
Duty Cycle
45
55
( VOH - VOL)/2
Rise/Fall Edge
0.2
1
ns
Tr/Tf:20%←→80% waveform
Load
100
Ω
200
700
fs
±0.1
RMS Jitter(By E5052B)@100MHz
Supply Sensitivity
12KHz~5MHz
Load Sensitivity
±0.2
Aging/ First Year
±0.3
±1.0
Standard
SSB Phase Noise
@100MHz
-78
-75
Offset 10Hz
-112
-110
Offset 100Hz
-140
-135
-150
-145
dBc/Hz Offset 1kHz
Offset 10kHz
-155
-150
0~3.3
±20
Offset 100kHz
V
±30
±40
positive
Tuning Slope
Non-linearity
Load±5%
Control Voltage Range
Frequency Turning Range
Vcc±5%
ppm
10
ppm
Environmental Conditions
Operating Temperature Range
-40℃~+85℃
Storage Temperature Range
-55℃ ~ +125℃
At +25℃
At +25℃
Outline Dimension & Pin Connections
Maximum Ratings
Symbol
Rating
Supply Voltage
Parameter
Vdd
-0.5V / 6V
Control Voltage
Vcon
0V / 3V
ESD, HBM/CDM/MM
4KV/ 2KV/ 200V
Reliability
Parameter
Condition
Temperature Stress Test
IEC60068, GJB360B
Mechanical Stress Test
IEC60068, GJB360B
EMC Test (ESD)
IEC61000, JESD22
Solderability
EIA/JESD22-B102-C
Contact Pads
RoHS
Gold over Nickel
RoHS Directive 2011/65/EU Annex II Recasting 2002/95/EC
Ordering Guide
BV 0507E X X X XXX X XXXX XX.XX
Product:
VCXO
Outline:
7.0 × 5.0mm
Output:
P: LVPECL
D:LVDS
Supply Voltage:
3: 3.3 V
5: 5.0 V
Example: BV0507DH3I155D020N100
Frequency in MHz
Tuning Range:
XXXN: XXX ppm Min.
eg: 020N
Phase Noise:
C: -130dBc/Hz@1kHz
D: -135dBc/Hz@1kHz
E: -140dBc/Hz@1kHz
Stability vs. Temp.
155: ±15ppm
Temp. Range:
C: -20℃~+70℃
I: -40℃~+85℃
BV0507EP3I155D030N100 价格&库存
很抱歉,暂时无法提供与“BV0507EP3I155D030N100”相匹配的价格&库存,您可以联系我们找货
