BV0507ED3I155D030N100
    XTALTQ(恒晶科技)
    SMD6
    振荡器 100 MHz LVDS VCXO 3.3V 振幅控制 6-SMD,无引线
BV0507ED3I155D030N100 数据手册
Features Applications ● High frequency & Low Noise ● SMD Package (7.0×5.0mm) ● Quick Warm-up ● ● ● ● ● Low vibration RF Communication Wireless Communication Low Phase Noise Signal Resource SDH/SONET GNSS BV0507E Specifications Parameter Supply Voltage Supply Current LVDS Value Typ. Max. – 3.3 – V Vcc±5% – 5 – V Vcc±5% Unit – 80 10 ~ 156.52 40,80, 100, 120, 122.88 ±10 ±12 ±15 MHz MHz ppm 20 Frequency Range Nominal Frequency Freq. Stability Vs. Temp. LVPECL Min. Conditions mA VOH 1.86 – 2.11 V VOL 1.06 – 1.31 V Duty Cycle 45 – 55 % Rise/Fall Edge – 0.2 1 ns Load – – 50 pf Vpp 250 350 450 mV Vos -40℃~+85℃ ( VOH - VOL)/2 1.125. 1.25 1.375 V Duty Cycle 45 – 55 % ( VOH - VOL)/2 Rise/Fall Edge – 0.2 1 ns Tr/Tf:20%←→80% waveform Load – – 100 Ω 200 – 700 fs ±0.1 RMS Jitter(By E5052B)@100MHz Supply Sensitivity 12KHz~5MHz – – Load Sensitivity – – ±0.2 Aging/ First Year ±0.3 – ±1.0 Standard SSB Phase Noise @100MHz -78 -75 Offset 10Hz – -112 -110 Offset 100Hz – -140 -135 – -150 -145 dBc/Hz Offset 1kHz Offset 10kHz -155 -150 – 0~3.3 ±20 – – Offset 100kHz V ±30 ±40 positive Tuning Slope Non-linearity Load±5% – Control Voltage Range Frequency Turning Range Vcc±5% ppm 10 ppm % Environmental Conditions Operating Temperature Range -40℃~+85℃ Storage Temperature Range -55℃ ~ +125℃ At +25℃ At +25℃ Outline Dimension & Pin Connections Maximum Ratings Symbol Rating Supply Voltage Parameter Vdd -0.5V / 6V Control Voltage Vcon 0V / 3V ESD, HBM/CDM/MM 4KV/ 2KV/ 200V Reliability Parameter Condition Temperature Stress Test IEC60068, GJB360B Mechanical Stress Test IEC60068, GJB360B EMC Test (ESD) IEC61000, JESD22 Solderability EIA/JESD22-B102-C Contact Pads RoHS Gold over Nickel RoHS Directive 2011/65/EU Annex II Recasting 2002/95/EC Ordering Guide BV 0507E X X X XXX X XXXX XX.XX Product: VCXO Outline: 7.0 × 5.0mm Output: P: LVPECL D:LVDS Supply Voltage: 3: 3.3 V 5: 5.0 V Example: BV0507DH3I155D020N100 Frequency in MHz Tuning Range: XXXN: XXX ppm Min. eg: 020N Phase Noise: C: -130dBc/Hz@1kHz D: -135dBc/Hz@1kHz E: -140dBc/Hz@1kHz Stability vs. Temp. 155: ±15ppm Temp. Range: C: -20℃~+70℃ I: -40℃~+85℃
BV0507ED3I155D030N100 价格&库存
很抱歉,暂时无法提供与“BV0507ED3I155D030N100”相匹配的价格&库存,您可以联系我们找货
