EYW06015 SERIES
60x60x15mm
Noise Level
Max. Airflow
Speed
Operating
Voltage Range
P-Q Curve
24
CFM
14.1
18.0
20.9
14.1
18.0
20.9
23.5
27.0
14.1
18.0
20.9
23.5
27.0
14.1
18.0
20.9
23.5
14.1
18.0
20.9
23.5
Life at 40 o C L10
12
RPM
3300
4100
4800
3300
4100
4800
5300
6100
3300
4100
4800
5300
6100
3300
4100
4800
5300
3300
4100
4800
5300
Power
Consumption
05
VDC
4 ~5.5
4 ~5.5
4 ~5.5
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
12~26.4
12~26.4
12~26.4
12~26.4
12~26.4
12~26.4
12~26.4
12~26.4
Current
VDC
L
L
L
2B
2B
2B
2B
2B
L
L
L
L
L
2B
2B
2B
2B
L
L
L
L
Max.
Static Pressure
Model No.
EYW06015005LL
EYW06015005LM
EYW06015005LH
EYW06015012BL
EYW06015012BM
EYW06015012BH
EYW06015012BS
EYW06015012BSS
EW06015012LL
EYW06015012LM
EYW06015012LH
EYW06015012LS
EYW06015012LSS
EYW06015024BL
EYW06015024BM
EYW06015024BH
EYW06015024BS
EYW06015024LL
EYW06015024LM
EYW06015024LH
EYW06015024LS
Rated
Voltage
Bearing
Airflow: 14.1~27.0 CFM
Static Pressure: 2.0~6.5 mm-H 2 O
Blade / Housing:
Plastic Material UL 94V-0 P.B.T.
Lead Wire: UL1007 #26 AWG
Weight: 33.5 g
mm-H 2 O
2.0
3.0
3.9
2.0
3.0
3.9
5.0
6.5
2.0
3.0
3.9
5.0
6.5
2.0
3.0
3.9
5.0
2.0
3.0
3.9
5.0
mA
130
200
360
55
100
130
150
230
70
100
130
150
260
25
40
55
70
25
40
55
70
W
0.65
1.00
1.80
0.66
1.20
1.56
1.80
2.76
0.84
1.20
1.56
1.80
3.12
0.60
0.96
1.32
1.68
0.60
0.96
1.32
1.68
Hour
50000
50000
50000
80000
80000
75000
65000
65000
50000
50000
50000
50000
50000
80000
80000
75000
65000
50000
50000
50000
50000
5
4
3
5
4
3
2
1
5
4
3
2
1
5
4
3
2
5
4
3
2
dB(A)
22.0
28.4
33.0
22.0
28.4
33.0
35.0
38.0
22.0
28.4
33.0
35.0
38.0
22.0
28.4
33.0
35.0
22.0
28.4
33.0
35.0
2B: 2-ball bearing L: sintetico bearing S: sleeve bearing
Voltage Available
Bearing System Available
05 12 24 48
2B L S
PERFORMANCE P-Q CURVE
Function Available
N A I F R Q S T M V C P DW U
OUTLINE DIMENSIONS
3.90
2.60
50.0±0.3
5.20
60.0±0.5
Static Pressure (mm-H 2 O)
6.50
1.30
∅4.3±0.1
6.00 12.0 18.0 24.0 30.0
15.0±0.5
300±10
Airflow (CFM)
Please refer to Model Numbering System for bearing, function and speed level indication.
Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S.
TECH web site at http://www.ystechUSA.com for updated information. Customized Specifications are designed accordingly
很抱歉,暂时无法提供与“EYW06015024BH-5”相匹配的价格&库存,您可以联系我们找货
