EYW09238 SERIES
92x92x38mm
Airflow: 56.6~192.9 CFM
mA
240
570
1100
2400
4400
160
300
530
1050
2200
80
150
270
540
1100
W
2.88
6.84
13.20
28.80
52.80
3.84
7.20
12.72
25.20
52.80
3.84
7.20
12.96
25.92
52.80
Noise Level
mm-H 2 O
13.2
29.1
48.9
66.9
79.0
13.2
29.1
48.9
66.9
103.7
13.2
29.1
48.9
66.9
103.7
Power
Consumption
CFM
56.6
84.6
113.6
150.9
184.5
56.6
84.6
113.6
150.9
192.9
56.6
84.6
113.6
150.9
192.9
Current
RPM
4000
6000
8000
10500
12500
4000
6000
8000
10500
13500
4000
6000
8000
10500
13500
P-Q Curve
48
VDC
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
12~28.0
12~28.0
12~28.0
12~28.0
12~28.0
36~56.0
36~56.0
36~56.0
36~56.0
36~56.0
Life at 40 o C L10
24
Max.
Static Pressure
12
Max. Airflow
VDC
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
Speed
Model No.
EYW09238012BL
EYW09238012BM
EYW09238012BH
EYW09238012BS
EYW09238012BU
EYW09238024BL
EYW09238024BM
EYW09238024BH
EYW09238024BS
EYW09238024BU
EYW09238048BL
EYW09238048BM
EYW09238048BH
EYW09238048BS
EYW09238048BU
Operating
Voltage Range
Rated
Voltage
Bearing
Static Pressure: 13.2~103.7 mm-H 2 O
Blade / Housing:
Plastic Material UL 94V-0 P.B.T.
Lead Wire: UL1061 #22 AWG
Weight: 2 33 . 0 g
Hour
80000
80000
75000
65000
65000
80000
80000
75000
65000
65000
80000
80000
75000
65000
65000
5
4
3
2
1
5
4
3
2
1
5
4
3
2
1
dB(A)
39.5
51.5
57.5
65.0
67.5
39.5
51.5
57.5
65.0
68.5
39.5
51.5
57.5
65.0
68.5
2B: 2-ball bearing L: sintetico bearing S: sleeve bearing
Voltage Available
05 12 24 48
Bearing System Available
2B L S
PERFORMANCE P-Q CURVE
Function Available
N A I F R Q S T M V C P DW U
OUTLINE DIMENSIONS
66.0
44.0
82.5±0.3
88.0
92.0±0.5
Static Pressure (mm-H 2 O)
110.0
22.0
38.0±0.5
80.0
120
160
200
45.0 ±0.1
300±10
Airflow (CFM)
Please refer to Model Numbering System for bearing, function and speed level indication.
Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S.
TECH web site at http://www.ystechusa.com for updated information. Customized Specifications are designed accordingly
很抱歉,暂时无法提供与“EYW09238012BE-12”相匹配的价格&库存,您可以联系我们找货
