EYW08038 SERIES
80x80x38mm
Airflow: 55.2~135.0 CFM
mA
550
950
1550
2900
4800
300
450
730
1300
2300
200
270
360
700
1200
W
6.60
11.40
18.60
34.80
57.60
7.20
10.80
16.80
31.20
55.20
9.60
12.96
17.28
33.60
57.60
Noise Level
mm-H 2 O
23.3
39.6
63.0
102.1
145.0
23.3
39.6
63.0
102.1
145.0
23.3
39.6
63.0
102.1
145.0
Power
Consumption
CFM
55.2
70.9
87.1
111.6
135.0
55.2
70.9
87.1
111.6
135.0
55.2
70.9
87.1
111.6
135.0
Current
RPM
7000
9000
11000
14000
17000
7000
9000
11000
14000
17000
7000
9000
11000
14000
17000
P-Q Curve
48
VDC
7~14.0
7~14.0
7~14.0
7~14.0
7~14.0
10~28.0
10~28.0
10~28.0
10~28.0
10~30.0
24~75.0
24~75.0
24~75.0
24~75.0
24~75.0
Life at 40 o C L10
24
Max.
Static Pressure
12
Max. Airflow
VDC
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
2B
Speed
Model No.
EYW08038012BL
EYW08038012BM
EYW08038012BH
EYW08038012BSS
EYW08038012BU
EYW08038024BL
EYW08038024BM
EYW08038024BH
EYW08038024BSS
EYW08038024BU
EYW08038048BL
EYW08038048BM
EYW08038048BH
EYW08038048BSS
EYW08038048BU
Operating
Voltage Range
Rated
Voltage
Bearing
Static Pressure: 23.3~145.0 mm-H 2 O
Blade / Housing:
Plastic Material UL 94V-0 P.B.T.
Lead Wire: UL1061 #22 AWG
Weight: 220.0 g
Hour
80000
80000
75000
65000
65000
80000
80000
75000
65000
65000
80000
80000
75000
65000
65000
5
4
3
2
1
5
4
3
2
1
5
4
3
2
1
dB(A)
50.0
56.0
60.8
67.5
69.5
50.0
56.0
60.8
67.5
69.5
50.0
56.0
60.8
67.5
69.5
2B: 2-ball bearing L: sintetico bearing S: sleeve bearing
Voltage Available
05 12 24 48
Bearing System Available
2B L S
PERFORMANCE P-Q CURVE
Function Available
N A I F R Q S T M V C P DW U
OUTLINE DIMENSIONS
90.0
60.0
71.5 ±0.3
120.0
80.0 ±0.5
Static Pressure (mm-H 2 O)
150.0
30.0
38.0 ±0.5
56.0
84.0 112
140
45.0 ±0.1
Airflow (CFM)
Please refer to Model Numbering System for bearing, function and speed level indication.
Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department.
Visit Y.S. TECH web site at http://www.ystech.com.tw for updated information. Customized Specifications are designed accordingly
很抱歉,暂时无法提供与“EYW08038024BU-12”相匹配的价格&库存,您可以联系我们找货
