NYW04010 SERIES
40x40x10mm
artment.
CFM
5.08
6.09
7.69
5.08
6.09
7.69
8.71
5.08
6.09
7.69
mm-H 2 O
1.69
2.64
3.64
1.69
2.64
3.64
5.09
1.69
2.64
3.64
Current
Max.
Static Pressure
Max. Airflow
Speed
RPM
5000
6000
7500
5000
6000
7500
8500
5000
6000
7500
mA
70
120
180
25
40
60
80
30
50
75
Noise Level
12
VDC
4~5.5
4~5.5
4~5.5
8~13.2
8~13.2
7~13.2
7~13.2
7~13.2
7~13.2
7~13.2
P-Q Curve
05
Operating
Voltage Range
Rated
Voltage
VDC
Life at 40 oC L10
Model No.
NYW0401000 5LL L
NYW0401000 5LM L
NYW0401000 5LH L
NYW040100 1 2BL 2B
NYW04010012BM 2B
NYW04010012BH 2B
NYW04010012BS 2B
NYW0401000 12LL L
NYW0401000 12LM L
NYW0401000 12LH L
Power
Consumption
(A)
.5
.5
.0
.5
.5
.5
.0
.0
.5
.0
.5
.0
.0
Bearing
Noise Level
Airflow: 5.08~8.71CFM
Static Pressure: 1.69~5.08 mm-H 2 O
Blade / Housing:
Plastic Material UL 94V-0 P.B.T.
Lead Wire: UL1007 #26 AWG
Weight: 13.6 g
W
0.35
0.60
0.90
0.30
0.48
0.72
0.96
0.42
0.60
0.90
Hour
50000
50000
55000
80000
80000
75000
65000
50000
50000
50000
4
3
2
4
3
2
1
4
3
2
dB(A)
17.5
21.5
25.0
17.5
21.5
25.0
28.0
17.5
21.5
25.0
2B: 2-ball bearing L : sintetico bearing S: sleeve bearing
Voltage Available
05 12 24 48
Bearing System Available
2B L S
Function Available
1 6I 5 4 3 2 7 8 9 10 111412 13
Please refer to Model Numbering System for bearing, function and speed level indication.
Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department.
Visit Y.S. TECH web site at http://www.ystechusa.com/ for updated information. Customized Specifications are designed accordingly.
很抱歉,暂时无法提供与“NYW04010012LS-12”相匹配的价格&库存,您可以联系我们找货
