Industrial 2.5” SATA SSD
Specification
(INSPIRE Series, 3D TLC)
Version 1.6
Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585
Tel : +65-6493 5035
Fax : +65-6493 5037
Website: http://www.flexxon.com
Email: flexxon@flexxon.com
ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED,
OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON.
TABLE OF CONTENTS
1.
2.
GENERAL DESCRIPTION ............................................................................ 1
1.1.
Introduction ....................................................................................................................... 1
1.2.
Product Overview .............................................................................................................. 1
1.3.
Power Loss Protection (Optional) ..................................................................................... 2
PRODUCT SPECIFICATIONS ....................................................................... 3
2.1.
Performance ....................................................................................................................... 3
2.2.
Power ................................................................................................................................. 3
2.3.
TBW (Terabytes Written) .................................................................................................. 4
2.4.
MTBF ................................................................................................................................ 4
2.5.
Data Retention ................................................................................................................... 4
3.
ENVIRONMENTAL SPECIFICATIONS .......................................................... 5
4.
ATA COMMANDS ........................................................................................ 6
5.
PIN ASSIGNMENT ...................................................................................... 8
6.
PHYSICAL DIMENSION .............................................................................. 9
7.
ORDERING INFORMATION ...................................................................... 10
1. GENERAL DESCRIPTION
1.1. Introduction
FLEXXON’s INSPIRE 2.5” SSD has SATA III interface, and is fully compliant with standard 2.5-inch
Form Factor. It supports high performance, high endurance, good compatibility and provides
comprehensive data protection. It is suitable for multi-tasking application.
1.2. Product Overview
Flash
3D TLC
Capacity
32GB up to 2TB
SATA Interface
Compliant with SATA Revision 3.2
Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface
ECC Scheme
INSPIRE 2.5” SSD applies the LDPC (Low Density Parity Check) of ECC algorithm
UART Function
GPIO
Support SMART and TRIM commands
Support DDR3/DDR3L External DRAM
Low Power Management
Power Failure Protection
Data shaping technique for enhanced data endurance
Data Refresh technology for data integrity
Global Wear Levelling Algorithm
AES256 and TCG OPAL (Optional)
Temperature Range
Operation (Silver) : 0°C ~ 70°C
Operation (Diamond) : -40°C ~ 85°C
Storage: -55°C ~ 95°C
RoHS Compliant
1
1.3. Power Loss Protection (Optional)
FLEXXON designs SSD device with a hardware power loss protection mechanism. It has a voltage
drop detector, so when the SSD device detects the host power dropping, the SSD’s power loss
protection circuit will be triggered and begin providing power to the SSD. The SSD then will start to
flush cached data from DRAM memory to NAND flash memory in order to preserve data integrity
and prevent data loss.
Normal operation
Unexpected Power Loss happens
When the SSD detects the host power
The SSD is powered by the host power, and
dropping, the power loss protection circuit
the power loss protection circuit is charged
starts to provide power to the SSD while it
by the host power.
flushes cached data from DRAM to NAND.
Figure 1-power loss protection mechanism
2
2. PRODUCT SPECIFICATIONS
2.1. Performance
Table 2-1 Performance of INSPIRE 2.5” SSD
Sequential
Capacity
CrystalDiskMark
Read (MB/s)
Write (MB/s)
Read (IOPS)
Write (IOPS)
32GB
279
104
30712
16235
60/64GB
390
208
51274
30995
120/128GB
553
402
116027
78352
240/256GB
493
406
101553
78520
480/512GB
563
511
132818
109676
960GB/1TB
565
521
116218
115927
1920GB/2TB
565
520
116218
115906
NOTES:
1. The performance was measured using CrystalDiskMarkv5.0x64 with SATA 6Gbps host.
2. Performance may differ according to flash configuration and platform.
2.2. Power
Table 2-2 Supply Voltage of INSPIRE 2.5” SSD
Parameter
Rating
Operating Voltage
5V +/-5%
Table 2-3 Power Consumption of INSPIRE 2.5” SSD
Parameter
Power Consumption (W)
Idle (Max.)
0.64W
Active (Max.)
4.56W
NOTE:
1. Power Consumption may differ from flash configuration and platform.
3
2.3. TBW (Terabytes Written)
Capacity
TBW
32GB
49
64GB
95
128GB
191
256GB
384
512GB
769
1TB
1536
2TB
3072
NOTES:
1. TBW may differ according to flash configuration and platform.
2. Samples were tested under JESD218A endurance test method and JESD219A endurance
workloads specification.
2.4. MTBF
MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value
represents the average time between a repair and the next failure. The predicted result of
FLEXXON’s INSPIRE 2.5” is more than 2 million hours.
2.5. Data Retention
10 years if > 90% life remaining (@25C)
1 year if < 10% life remaining (@25C)
4
3. ENVIRONMENTAL SPECIFICATIONS
Test Items
Test Conditions
Storage Temperature
-55°C ~ 95°C
Operating Temperature
Silver Grade: 0°C ~ 70°C
Diamond Grade: -40°C~ 85°C
Storage Humidity
Silver Grade: 40°C, 95% RH
Diamond Grade: 55°C, 95% RH
Operating Humidity
Silver Grade: 40°C, 93% RH
Shock
1500G, Half Sin Pulse Duration 0.5ms
Vibration
80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min
Drop
80cm free fall, 6 face of each unit
Bending
≥ 20N, Hold 1 min/5 times
ESD
24°C, 49% RH, +/-4KV
5
4. ATA COMMANDS
Table 4-1 Supported ATA Command Set
# Command
Code
Protocol
Execute Drive Diagnostic
90h
Device diagnostic
Flush Cache
E7h
Non-data
Identify Device
ECh
PIO data-in
Initialize Drive Parameters
91h
Non-data
Read DMA
C8h
DMA
Read Log Ext
2Fh
PIO data-in
Read Multiple
C4h
PIO data-in
Read Sector(s)
20h
PIO data-in
Read Verify Sector(s)
40h or 41h
Non-data
Set Feature
EFh
Non-data
Set Multiple Mode
C6h
Non-data
Write DMA
CAh
DMA
Write Multiple
C5h
PIO data-out
Write Sector(s)
30h
PIO data-out
NOP
00h
Non-data
Read Buffer
E4h
PIO data-in
Write Buffer
E8h
PIO data-out
Check Power Mode
E5h or 98h
Non-data
Idle
E3h or 97h
Non-data
Idle Immediate
E1h or 95h
Non-data
Sleep
E6h or 99h
Non-data
Standby
E2h or 96h
Non-data
Standby Immediate
E0h or 94h
Non-data
Security Set Password
F1h
PIO data-out
Security Unlock
F2h
PIO data-out
Security Erase Prepare
F3h
Non-data
Security Erase Unit
F4h
PIO data-out
Security Freeze Lock
F5h
Non-data
Security Disable Password
F6h
PIO data-out
General Feature Set
Power Management Feature Set
Security Mode Feature Set
SMART Feature Set
6
SMART Disable Operations
B0h
Non-data
SMART Enable/Disable Autosave
B0h
Non-data
SMART Enable Operations
B0h
Non-data
SMART Execute Off-Line Immediate
B0h
Non-data
SMART Read Data
B0h
PIO data-in
SMART Read Threshold
B0h
PIO data-in
SMART Return Status
B0h
Non-data
SMART Save Attribute Values
B0h
Non-data
Read Native Max Address
F8h
Non-data
Set Max Address
F9h
Non-data
Set Max Set Password
F9h
PIO data-out
Set Max Lock
F9h
Non-data
Set Max Freeze Lock
F9h
Non-data
Set Max Unlock
F9h
PIO data-out
Flush Cache Ext
EAh
Non-data
Read Sector(s) Ext
24h
PIO data-in
Read DMA Ext
25h
DMA
Read Multiple Ext
29h
PIO data-in
Read Native Max Address Ext
27h
Non-data
Read Verify Sector(s) Ext
42h
Non-data
Set Max Address Ext
37h
Non-data
Write DMA Ext
35h
DMA
Write Multiple Ext
39h
PIO data-out
Write Sector(s) Ext
34h
PIO data-out
Read FPDMA Queued
60h
DMA Queued
Write FPDMA Queued
61h
DMA Queued
Data Set Management
06h
DMA
Seek
70h
Non-data
Host Protected Area Feature Set
48-bit Address Feature Set
NCQ Feature Set
Others
7
5. PIN ASSIGNMENT
Figure 5-1 Pin Assignment of INSPIRE 2.5” SSD
Table 5-1 Signal Segment Pin Assignment and Description
Pin Number
Function
S1
GND
S2
RX+ (Differential Signal Pair A)
S3
RX– (Differential Signal Pair A)
S4
GND
S5
TX– (Differential Signal Pair B)
S6
TX+ (Differential Signal Pair B)
S7
GND
Table 5-2 Power Segment Pin Assignment and Descriptions
Pin Number
Function
P1
NC
P2
NC
P3
DEVSLP
P4
GND
P5
GND
P6
GND
P7
5V
P8
5V
P9
5V
P10
GND
P11
DAS/DSS
P12
GND
P13
NC
P14
NC
P15
NC
8
6. PHYSICAL DIMENSION
Dimension: 100mm(L) x 69.85mm(W) x 7mm(H)
9
7. ORDERING INFORMATION
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSB032GBS-M500
64GB
FSSB064GBE-M500
FSSB064GBS-M500
60GB
FSSB060GBE-M500
FSSB060GBS-M500
128GB
FSSB128GBE-M500
FSSB128GBS-M500
120GB
FSSB120GBE-M500
FSSB120GBS-M500
256GB
FSSB256GBE-M500
FSSB256GBS-M500
240GB
FSSB240GBE-M500
FSSB240GBS-M500
512GB
FSSB512GBE-M500
FSSB512GBS-M500
480GB
FSSB480GBE-M500
FSSB480GBS-M500
1TB
FSSB001TBE-M500
FSSB001TBS-M500
960GB
FSSB960GBE-M500
FSSB960GBS-M500
2TB
FSSB002TBE-M500
FSSB002TBS-M500
1920GB
FSSB1920BE-M500
FSSB1920BS-M500
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSB032GBS-M50P
64GB
FSSB064GBE-M50P
FSSB064GBS-M50P
60GB
FSSB060GBE-M50P
FSSB060GBS-M50P
128GB
FSSB128GBE-M50P
FSSB128GBS-M50P
120GB
FSSB120GBE-M50P
FSSB120GBS-M50P
256GB
FSSB256GBE-M50P
FSSB256GBS-M50P
240GB
FSSB240GBE-M50P
FSSB240GBS-M50P
512GB
FSSB512GBE-M50P
FSSB512GBS-M50P
480GB
FSSB480GBE-M50P
FSSB480GBS-M50P
1TB
FSSB001TBE-M50P
FSSB001TBS-M50P
960GB
FSSB960GBE-M50P
FSSB960GBS-M50P
2TB
FSSB002TBE-M50P
FSSB002TBS-M50P
1920GB
FSSB1920BE-M50P
FSSB1920BS-M50P
10
Conformal coating
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSB032GBS-M50V
64GB
FSSB064GBE-M50V
FSSB064GBS-M50V
60GB
FSSB060GBE-M50V
FSSB060GBS-M50V
128GB
FSSB128GBE-M50V
FSSB128GBS-M50V
120GB
FSSB120GBE-M50V
FSSB120GBS-M50V
256GB
FSSB256GBE-M50V
FSSB256GBS-M50V
240GB
FSSB240GBE-M50V
FSSB240GBS-M50V
512GB
FSSB512GBE-M50V
FSSB512GBS-M50V
480GB
FSSB480GBE-M50V
FSSB480GBS-M50V
1TB
FSSB001TBE-M50V
FSSB001TBS-M50V
960GB
FSSB960GBE-M50V
FSSB960GBS-M50V
2TB
FSSB002TBE-M50V
FSSB002TBS-M50V
1920GB
FSSB1920BE-M50V
FSSB1920BS-M50V
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSB032GBS-M50S
64GB
FSSB064GBE-M50S
FSSB064GBS-M50S
60GB
FSSB060GBE-M50S
FSSB060GBS-M50S
128GB
FSSB128GBE-M50S
FSSB128GBS-M50S
120GB
FSSB120GBE-M50S
FSSB120GBS-M50S
256GB
FSSB256GBE-M50S
FSSB256GBS-M50S
240GB
FSSB240GBE-M50S
FSSB240GBS-M50S
512GB
FSSB512GBE-M50S
FSSB512GBS-M50S
480GB
FSSB480GBE-M50S
FSSB480GBS-M50S
1TB
FSSB001TBE-M50S
FSSB001TBS-M50S
960GB
FSSB960GBE-M50S
FSSB960GBS-M50S
2TB
FSSB002TBE-M50S
FSSB002TBS-M50S
1920GB
FSSB1920BE-M50S
FSSB1920BS-M50S
AES256, TCG OPAL
11
Conformal coating and Power Loss Protection
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSB032GBS-M50D
64GB
FSSB064GBE-M50D
FSSB064GBS-M50D
60GB
FSSB060GBE-M50D
FSSB060GBS-M50D
128GB
FSSB128GBE-M50D
FSSB128GBS-M50D
120GB
FSSB120GBE-M50D
FSSB120GBS-M50D
256GB
FSSB256GBE-M50D
FSSB256GBS-M50D
240GB
FSSB240GBE-M50D
FSSB240GBS-M50D
512GB
FSSB512GBE-M50D
FSSB512GBS-M50D
480GB
FSSB480GBE-M50D
FSSB480GBS-M50D
1TB
FSSB001TBE-M50D
FSSB001TBS-M50D
960GB
FSSB960GBE-M50D
FSSB960GBS-M50D
2TB
FSSB002TBE-M50D
FSSB002TBS-M50D
1920GB
FSSB1920BE-M50D
FSSB1920BS-M50D
12
Revision History
Revision
Draft Date
History
1.0
2019/08
Preliminary release
1.1
2019/10
Update Ordering Information
1.2
2019/12
Update performance
1.3
2020/01
1.4
2020/09
1.5
2021/04
Update Capacity
1.6
2022/04
13
很抱歉,暂时无法提供与“FSSB960GBE-M500”相匹配的价格&库存,您可以联系我们找货
