FSSB512GBE-M500
FSSB512GBE-M500
    FLEXXON
    固态硬盘(SSD) FLASH - NAND(TLC) 512GB SATA 2.5" 5V
FSSB512GBE-M500 数据手册
Industrial 2.5” SATA SSD Specification (INSPIRE Series, 3D TLC) Version 1.6 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................ 1 1.1. Introduction ....................................................................................................................... 1 1.2. Product Overview .............................................................................................................. 1 1.3. Power Loss Protection (Optional) ..................................................................................... 2 PRODUCT SPECIFICATIONS ....................................................................... 3 2.1. Performance ....................................................................................................................... 3 2.2. Power ................................................................................................................................. 3 2.3. TBW (Terabytes Written) .................................................................................................. 4 2.4. MTBF ................................................................................................................................ 4 2.5. Data Retention ................................................................................................................... 4 3. ENVIRONMENTAL SPECIFICATIONS .......................................................... 5 4. ATA COMMANDS ........................................................................................ 6 5. PIN ASSIGNMENT ...................................................................................... 8 6. PHYSICAL DIMENSION .............................................................................. 9 7. ORDERING INFORMATION ...................................................................... 10 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s INSPIRE 2.5” SSD has SATA III interface, and is fully compliant with standard 2.5-inch Form Factor. It supports high performance, high endurance, good compatibility and provides comprehensive data protection. It is suitable for multi-tasking application. 1.2. Product Overview  Flash  3D TLC  Capacity  32GB up to 2TB  SATA Interface  Compliant with SATA Revision 3.2  Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface  ECC Scheme  INSPIRE 2.5” SSD applies the LDPC (Low Density Parity Check) of ECC algorithm  UART Function  GPIO  Support SMART and TRIM commands  Support DDR3/DDR3L External DRAM  Low Power Management  Power Failure Protection  Data shaping technique for enhanced data endurance  Data Refresh technology for data integrity  Global Wear Levelling Algorithm  AES256 and TCG OPAL (Optional)  Temperature Range  ■ Operation (Silver) : 0°C ~ 70°C ■ Operation (Diamond) : -40°C ~ 85°C ■ Storage: -55°C ~ 95°C RoHS Compliant 1 1.3. Power Loss Protection (Optional) FLEXXON designs SSD device with a hardware power loss protection mechanism. It has a voltage drop detector, so when the SSD device detects the host power dropping, the SSD’s power loss protection circuit will be triggered and begin providing power to the SSD. The SSD then will start to flush cached data from DRAM memory to NAND flash memory in order to preserve data integrity and prevent data loss. Normal operation Unexpected Power Loss happens When the SSD detects the host power The SSD is powered by the host power, and dropping, the power loss protection circuit the power loss protection circuit is charged starts to provide power to the SSD while it by the host power. flushes cached data from DRAM to NAND. Figure 1-power loss protection mechanism 2 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of INSPIRE 2.5” SSD Sequential Capacity CrystalDiskMark Read (MB/s) Write (MB/s) Read (IOPS) Write (IOPS) 32GB 279 104 30712 16235 60/64GB 390 208 51274 30995 120/128GB 553 402 116027 78352 240/256GB 493 406 101553 78520 480/512GB 563 511 132818 109676 960GB/1TB 565 521 116218 115927 1920GB/2TB 565 520 116218 115906 NOTES: 1. The performance was measured using CrystalDiskMarkv5.0x64 with SATA 6Gbps host. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of INSPIRE 2.5” SSD Parameter Rating Operating Voltage 5V +/-5% Table 2-3 Power Consumption of INSPIRE 2.5” SSD Parameter Power Consumption (W) Idle (Max.) 0.64W Active (Max.) 4.56W NOTE: 1. Power Consumption may differ from flash configuration and platform. 3 2.3. TBW (Terabytes Written) Capacity TBW 32GB 49 64GB 95 128GB 191 256GB 384 512GB 769 1TB 1536 2TB 3072 NOTES: 1. TBW may differ according to flash configuration and platform. 2. Samples were tested under JESD218A endurance test method and JESD219A endurance workloads specification. 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s INSPIRE 2.5” is more than 2 million hours. 2.5. Data Retention  10 years if > 90% life remaining (@25C)  1 year if < 10% life remaining (@25C) 4 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -55°C ~ 95°C Operating Temperature Silver Grade: 0°C ~ 70°C Diamond Grade: -40°C~ 85°C Storage Humidity Silver Grade: 40°C, 95% RH Diamond Grade: 55°C, 95% RH Operating Humidity Silver Grade: 40°C, 93% RH Diamond Grade: 55°C, 95% RH Shock 1500G, Half Sin Pulse Duration 0.5ms Vibration 80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min Drop 80cm free fall, 6 face of each unit Bending ≥ 20N, Hold 1 min/5 times ESD 24°C, 49% RH, +/-4KV 5 4. ATA COMMANDS Table 4-1 Supported ATA Command Set # Command Code Protocol Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Initialize Drive Parameters 91h Non-data Read DMA C8h DMA Read Log Ext 2Fh PIO data-in Read Multiple C4h PIO data-in Read Sector(s) 20h PIO data-in Read Verify Sector(s) 40h or 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out Write Sector(s) 30h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Check Power Mode E5h or 98h Non-data Idle E3h or 97h Non-data Idle Immediate E1h or 95h Non-data Sleep E6h or 99h Non-data Standby E2h or 96h Non-data Standby Immediate E0h or 94h Non-data Security Set Password F1h PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out General Feature Set Power Management Feature Set Security Mode Feature Set SMART Feature Set 6 SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Execute Off-Line Immediate B0h Non-data SMART Read Data B0h PIO data-in SMART Read Threshold B0h PIO data-in SMART Return Status B0h Non-data SMART Save Attribute Values B0h Non-data Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Flush Cache Ext EAh Non-data Read Sector(s) Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Read Native Max Address Ext 27h Non-data Read Verify Sector(s) Ext 42h Non-data Set Max Address Ext 37h Non-data Write DMA Ext 35h DMA Write Multiple Ext 39h PIO data-out Write Sector(s) Ext 34h PIO data-out Read FPDMA Queued 60h DMA Queued Write FPDMA Queued 61h DMA Queued Data Set Management 06h DMA Seek 70h Non-data Host Protected Area Feature Set 48-bit Address Feature Set NCQ Feature Set Others 7 5. PIN ASSIGNMENT Figure 5-1 Pin Assignment of INSPIRE 2.5” SSD Table 5-1 Signal Segment Pin Assignment and Description Pin Number Function S1 GND S2 RX+ (Differential Signal Pair A) S3 RX– (Differential Signal Pair A) S4 GND S5 TX– (Differential Signal Pair B) S6 TX+ (Differential Signal Pair B) S7 GND Table 5-2 Power Segment Pin Assignment and Descriptions Pin Number Function P1 NC P2 NC P3 DEVSLP P4 GND P5 GND P6 GND P7 5V P8 5V P9 5V P10 GND P11 DAS/DSS P12 GND P13 NC P14 NC P15 NC 8 6. PHYSICAL DIMENSION Dimension: 100mm(L) x 69.85mm(W) x 7mm(H) 9 7. ORDERING INFORMATION Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSB032GBS-M500 64GB FSSB064GBE-M500 FSSB064GBS-M500 60GB FSSB060GBE-M500 FSSB060GBS-M500 128GB FSSB128GBE-M500 FSSB128GBS-M500 120GB FSSB120GBE-M500 FSSB120GBS-M500 256GB FSSB256GBE-M500 FSSB256GBS-M500 240GB FSSB240GBE-M500 FSSB240GBS-M500 512GB FSSB512GBE-M500 FSSB512GBS-M500 480GB FSSB480GBE-M500 FSSB480GBS-M500 1TB FSSB001TBE-M500 FSSB001TBS-M500 960GB FSSB960GBE-M500 FSSB960GBS-M500 2TB FSSB002TBE-M500 FSSB002TBS-M500 1920GB FSSB1920BE-M500 FSSB1920BS-M500 Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSB032GBS-M50P 64GB FSSB064GBE-M50P FSSB064GBS-M50P 60GB FSSB060GBE-M50P FSSB060GBS-M50P 128GB FSSB128GBE-M50P FSSB128GBS-M50P 120GB FSSB120GBE-M50P FSSB120GBS-M50P 256GB FSSB256GBE-M50P FSSB256GBS-M50P 240GB FSSB240GBE-M50P FSSB240GBS-M50P 512GB FSSB512GBE-M50P FSSB512GBS-M50P 480GB FSSB480GBE-M50P FSSB480GBS-M50P 1TB FSSB001TBE-M50P FSSB001TBS-M50P 960GB FSSB960GBE-M50P FSSB960GBS-M50P 2TB FSSB002TBE-M50P FSSB002TBS-M50P 1920GB FSSB1920BE-M50P FSSB1920BS-M50P Power Loss Protection 10 Conformal coating Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSB032GBS-M50V 64GB FSSB064GBE-M50V FSSB064GBS-M50V 60GB FSSB060GBE-M50V FSSB060GBS-M50V 128GB FSSB128GBE-M50V FSSB128GBS-M50V 120GB FSSB120GBE-M50V FSSB120GBS-M50V 256GB FSSB256GBE-M50V FSSB256GBS-M50V 240GB FSSB240GBE-M50V FSSB240GBS-M50V 512GB FSSB512GBE-M50V FSSB512GBS-M50V 480GB FSSB480GBE-M50V FSSB480GBS-M50V 1TB FSSB001TBE-M50V FSSB001TBS-M50V 960GB FSSB960GBE-M50V FSSB960GBS-M50V 2TB FSSB002TBE-M50V FSSB002TBS-M50V 1920GB FSSB1920BE-M50V FSSB1920BS-M50V Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSB032GBS-M50S 64GB FSSB064GBE-M50S FSSB064GBS-M50S 60GB FSSB060GBE-M50S FSSB060GBS-M50S 128GB FSSB128GBE-M50S FSSB128GBS-M50S 120GB FSSB120GBE-M50S FSSB120GBS-M50S 256GB FSSB256GBE-M50S FSSB256GBS-M50S 240GB FSSB240GBE-M50S FSSB240GBS-M50S 512GB FSSB512GBE-M50S FSSB512GBS-M50S 480GB FSSB480GBE-M50S FSSB480GBS-M50S 1TB FSSB001TBE-M50S FSSB001TBS-M50S 960GB FSSB960GBE-M50S FSSB960GBS-M50S 2TB FSSB002TBE-M50S FSSB002TBS-M50S 1920GB FSSB1920BE-M50S FSSB1920BS-M50S AES256, TCG OPAL 11 Conformal coating and Power Loss Protection Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSB032GBS-M50D 64GB FSSB064GBE-M50D FSSB064GBS-M50D 60GB FSSB060GBE-M50D FSSB060GBS-M50D 128GB FSSB128GBE-M50D FSSB128GBS-M50D 120GB FSSB120GBE-M50D FSSB120GBS-M50D 256GB FSSB256GBE-M50D FSSB256GBS-M50D 240GB FSSB240GBE-M50D FSSB240GBS-M50D 512GB FSSB512GBE-M50D FSSB512GBS-M50D 480GB FSSB480GBE-M50D FSSB480GBS-M50D 1TB FSSB001TBE-M50D FSSB001TBS-M50D 960GB FSSB960GBE-M50D FSSB960GBS-M50D 2TB FSSB002TBE-M50D FSSB002TBS-M50D 1920GB FSSB1920BE-M50D FSSB1920BS-M50D 12 Revision History Revision Draft Date History 1.0 2019/08 Preliminary release 1.1 2019/10 Update Ordering Information 1.2 2019/12 Update performance 1.3 2020/01 Update Ordering Information 1.4 2020/09 Update Ordering Information 1.5 2021/04 Update Capacity 1.6 2022/04 Update Ordering Information 13
FSSB512GBE-M500 价格&库存
很抱歉,暂时无法提供与“FSSB512GBE-M500”相匹配的价格&库存,您可以联系我们找货
