FSSB7680BS-SE0S
FSSB7680BS-SE0S
    FLEXXON
    固态硬盘(SSD)- 7.68TB SATA III 2.5"
FSSB7680BS-SE0S 数据手册
Industrial 2.5” SATA SSD Specification (XCEL SERIES, 3D TLC) Version 1.6 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................ 1 1.1. Introduction ....................................................................................................................... 1 1.2. Product Overview .............................................................................................................. 2 PRODUCT SPECIFICATIONS ....................................................................... 3 2.1. Performance ....................................................................................................................... 3 2.2. Power ................................................................................................................................. 3 2.3. TBW (Terabytes Written) .................................................................................................. 3 2.4. MTBF ................................................................................................................................ 4 2.5. Data Retention ................................................................................................................... 4 3. ENVIRONMENTAL SPECIFICATIONS .......................................................... 5 4. ATA COMMANDS ........................................................................................ 6 5. PIN ASSIGNMENT .................................................................................... 13 6. PHYSICAL DIMENSION ............................................................................ 14 7. ORDERING INFORMATION ...................................................................... 15 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s XCEL 2.5” SATA Solid State Disk (SSD) has SATA III interface, and is fully compliant with the standard 2.5-inch form factor. It is designed with high density, ultimate performance and high reliability, suitable for enterprise applications. Figure 1-1 XCEL 2.5” SATA SSD Controller Block Diagram 1 1.2. Product Overview ❖ Flash ▪ 3D TLC ❖ Capacity ▪ 240GB up to 7680GB ❖ SATA Interface ▪ Compliant with SATA Revision 3.2 ▪ Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface ❖ ECC Scheme ▪ XCEL applies LDPC (Low Density Parity Check) of ECC algorithm ❖ UART Function ❖ GPIO ❖ Support SMART and TRIM commands ❖ Low Power Management ❖ Power Loss Protection Algorithm ❖ Support TCG OPAL/AES256 ❖ Temperature Range ❖ ■ Operation (Silver): 0°C ~ 70°C ■ Operation (Diamond): -40°C ~ 85°C ■ Storage: -40°C ~ 85°C RoHS Compliant 2 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of XCEL 2.5” SATA SSD Sequential Capacity 240GB ~7680GB Read (MB/s) Write (MB/s) 550 530 NOTES: 1. The performance was measured using CrystalDiskMarkv5.0x64 with SATA 6Gbps host. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of XCEL 2.5” SATA SSD 2.3. Parameter Rating Operating Voltage 5V TBW (Terabytes Written) Capacity TBW 240GB 378 480GB 794 960GB 1580 1920GB 3118 3840GB 6114 7680GB 11751 NOTES: 1. TBW may differ according to flash configuration and platform. 2. Samples were tested under JESD218A endurance test method and JESD219A endurance workloads specification. 3 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s XCEL 2.5” SATA SSD is more than 2 million hours. 2.5. Data Retention • 10 years if > 90% life remaining (@25C) • 1 year if < 10% life remaining (@25C) 4 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -40°C ~ 85°C Operating Temperature Silver Grade: 0°C ~ 70°C Diamond Grade: -40°C ~ 85°C Storage Humidity 40°C, 93% RH Operating Humidity 40°C, 90% RH Shock 1500G, Half Sin Pulse Duration 0.5ms Vibration 80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min Drop 80cm free fall, 6 face of each unit Bending ≥ 20N, Hold 1 min/5 times ESD 24°C, 49% RH, +/-4KV 5 4. ATA COMMANDS Table 4-1 ATA Command List Op Code Support Description Op Code B6h 00h Y 12h Support - Description NV Cache: QUERY NV CACHE PINNED NOP SET DMA EXT B6h 03h 06h - Y 13h - NV Cache: QUERY NV CFA REQUEST CACHE MISSES EXTENDED ERROR DMA EXT DATA SET B6h 14h - NV Cache: FLUSH NV CACHE MANAGEMENT 08h - DEVICE RESET C4h Y READ MULTIPLE 0Bh - REQUEST SENSE DATA C5h Y WRITE MULTIPLE EXT 10h Y RECALIBRATE C6h Y SET MULTIPLE MODE 11h-1Fh - RECALIBRATE C7h - READ DMA QUEUED 20h Y READ SECTOR(S) C8h Y READ DMA 21h Y READ SECTOR(S) C9h Y READ DMA WITHOUT RETRY WITHOUT RETRY 22h - READ LONG CAh Y WRITE DMA 23h - READ LONG WITHOUT CBh Y WRITE DMA WITHOUT RETRY RETRY 24h Y READ SECTOR(S) EXT CCh - WRITE DMA QUEUED 25h Y READ DMA EXT CDh - CFA WRITE MULTIPLE WITHOUT ERASE 26h - READ DMA QUEUED Y CEh EXT EXT 27h Y READ NATIVE MAX WRITE MULTIPLE FUA - D1h CHECK MEDIA CARD TYPE ADDRESS EXT 29h Y READ MULTIPLE EXT DAh - GET MEDIA STATUS 2Ah - READ STREAM DMA DEh - MEDIA LOCK DFh - MEDIA UNLOCK EXT 2Bh - READ STREAM EXT 6 2Fh Y READ LOG EXT E0h Y STANDBY IMMEDIATE 30h Y WRITE SECTOR(S) E1h Y IDLE IMMEDIATE 31h Y WRITE SECTOR(S) E2h Y STANDBY WITHOUT RETRY 32h - WRITE LONG E3h Y IDLE 33h - WRITE LONG WITHOUT E4h Y READ BUFFER RETRY 34h Y WRITE SECTOR(S) EXT E5h Y CHECK POWER MODE 35h Y WRITE DMA EXT E6h Y SLEEP 36h - WRITE DMA QUEUED E7h Y FLUSH CACHE E8h Y WRITE BUFFER Y READ BUFFER DMA FLUSH CACHE EXT EXT 37h Y SET MAX ADDRESS EXT CFA WRITE SECTORS 38h - WITHOUT ERASE E9h 39h Y WRITE MULTIPLE EXT EAh Y 3Ah - WRITE STREAM DMA EBh Y WRITE BUFFER DMA EXT 3Bh - WRITE STREAM EXT ECh Y 3Ch - WRITE VERIFY EDh - 3Dh Y WRITE DMA FUA EXT EEh - WRITE DMA QUEUED EFh 3Eh 01h - FUA EXT IDENTIFY DEVICE MEDIA EJECT IDENTIFY DEVICE DMA SET FEATURES: Enable 8-bit PIO transfer mode (CFA feature set only) 3Fh - WRITE LOG EXT EFh 02h Y SET FEATURES: Enable write cache 40h Y READ VERIFY EFh 03h Y SECTOR(S) SET FEATURES: Set transfer mode based on value in Count field 41h 42h Y Y READ VERIFY EFh 05h Y SET FEATURES: Enable SECTOR(S) WITHOUT advanced power RETRY management READ VERIFY EFh 06h SECTOR(S) EXT - SET FEATURES: Enable Power-Up In Standby feature set 7 44h - Reserved EFh - 07h SET FEATURES: Power-Up In Standby feature set device spin-up 45h O WRITE EFh - 0Ah UNCORRECTABLE EXT 47h Y READ LOG DMA EXT SET FEATURES: Enable CFA power mode 1 EFh - 0Bh SET FEATURES: Enable Write-Read-Verify feature set 50h - FORMAT TRACK EFh 10h 01h - SET FEATURES: Enable use of Serial ATA feature 51h - CONFIGURE STREAM EFh 10h 02h Y SET FEATURES: Enable DMA Setup FIS Auto-Activate optimization 57h Y WRITE LOG DMA EXT EFh 10h 03h Y SET FEATURES: Enable Device-initiated interface power state (DIPM) transitions 60h Y READ FPDMA QUEUED EFh 10h 04h - SET FEATURES: Enable use of Serial ATA feature 61h Y WRITE FPDMA EFh 10h 05h - QUEUED SET FEATURES: Enable use of Serial ATA feature 70h Y SEEK EFh 10h 06h O SET FEATURES: Enable Software Settings Preservation (SSP) 71-76h - SEEK EFh 10h 07h Y SET FEATURES: Enable Device Automatic Partial to Slumber transitions 77h Y SET DATE AND TIME EFh 10h EXT 09h O SET FEATURES: Enable Device Sleep 8 78h Y ACCESSIBLE MAX EFh 42h - SET FEATURES: Enable ADDRESS Automatic Acoustic CONFIGURATION Management feature set 79-7Fh - SEEK EFh 43h - SET FEATURES: Set Maximum Host Interface Sector Times 87h - CFA TRANSLATE EFh 44h - SECTOR 90h Y EXECUTE DEVICE SET FEATURES: Vendor Specific ECC byte EFh 55h Y DIAGNOSTIC SET FEATURES: Disable read look-ahead feature 91h Y INITIALIZE DEVICE EFh 5Dh - PARAMETERS 92h Y DOWNLOAD release interrupt EFh 5Eh - MICROCODE 93h Y DOWNLOAD - STANDBY IMMEDIATE SET FEATURES: Enable service interrupt EFh 5Fh - MICROCODE DMA 94h SET FEATURES: Enable SET FEATURES: Enable NDRQ Feature EFh 66h Y SET FEATURES: Disable reverting to power-on defaults 95h - IDLE IMMEDIATE EFh 81h - SET FEATURES: Disable 8-bit PIO transfer mode (CFA feature set only) 96h - STANDBY EFh 82h Y SET FEATURES: Disable write cache 97h - IDLE EFh 85h Y SET FEATURES: Disable advanced power management 98h - CHECK POWER MODE EFh 86h - SET FEATURES: Disable Power-Up In Standby feature set 99h - SLEEP EFh 8Ah 9 - SET FEATURES: Disable CFA power mode A0h - PACKET EFh - 8Bh SET FEATURES: Disable Write-Read-Verify feature set A1h - IDENTIFY PACKET EFh 90h 01h - DEVICE SET FEATURES: Disable use of Serial ATA feature A2h - SERVICE EFh 90h 02h Y SET FEATURES: Disable DMA Setup FIS Auto Activate optimization B0h D0h Y SMART: READ DATA EFh 90h 03h Y SET FEATURES: Disable Device-initiated interface power state (DIPM) transitions B0h B0h D1h D2h Y Y SMART: READ EFh 90h 03h - ATTRIBUTE use of Serial ATA THRESHOLDS feature SMART: EFh 90h 06h Y ENABLE/DISABLE D4h Y SMART: EXECUTE SET FEATURES: Disable Software Settings AUTOSAVE B0h SET FEATURES: Disable Preservation (SSP) EFh 90h 07h Y OFF-LINE IMMEDIATE SET FEATURES: Disable Device Automatic Partial to Slumber transitions B0h D5h Y SMART: READ LOG EFh 90h 09h O SET FEATURES: Disable Device Sleep B0h D6h Y SMART: WRITE LOG EFh AAh Y SET FEATURES: Enable read look-ahead feature B0h D8h Y SMART: ENABLE EFh BBh - OPERATIONS B0h D9h Y SMART: DISABLE SET FEATURES: Default ECC byte EFh C2h OPERATIONS - SET FEATURES: Disable Automatic Acoustic Management feature set 10 B0h DAh Y SMART: RETURN EFh C3h - STATUS SET FEATURES: Enable/Disable the Sense Data Reporting feature set B0h B0h DBh E0h Y - SMART: EFh CCh Y reverting to power-on AUTOMATIC OFF-LINE defaults SMART: Vendor EFh DDh - specific B1h C0h Y SET FEATURES: Enable ENABLE/DISABLE DEVICE SET FEATURES: Disable release interrupt EFh DEh - CONFIGURATION: SET FEATURES: Disable SERVICE interrupt RESTORE B1h C1h Y DEVICE EFh DFh - CONFIGURATION: SET FEATURES: Disable NDRQ Feature FREEZE LOCK B1h C2h Y DEVICE Y F1h CONFIGURATION: SECURITY SET PASSWORD IDENTIFY B1h C3h Y DEVICE F2h Y F3h y SECURITY UNLOCK CONFIGURATION: SET B1h C4h Y DEVICE CONFIGURATION: SECURITY ERASE PREPARE IDENTIFY DM B1h C5h Y DEVICE F4h Y F5h Y F6h Y SECURITY ERASE UNIT CONFIGURATION: SET DMA B4h 0000h O SANITIZE DEVICE: SECURITY FREEZE LOCK SANITIZE STATUS EXT B4h 0011h O SANITIZE DEVICE: CRYPTO SCRAMBLE SECURITY DISABLE PASSWORD EXT B4h 0012h O SANITIZE DEVICE: Y F8h BLOCK ERASE EXT B4h 0014h O SANITIZE DEVICE: READ NATIVE MAX ADDRESS F9h OVERWRITE EXT 00h Y SET MAX: SET MAX ADDRESS 11 B4h 0020h O SANITIZE DEVICE: F9h 01h Y SANITIZE FREEZE SET MAX: SET MAX PASSWORD LOCK EXT B4h 0040h O SANITIZE DEVICE: F9h 02h Y SANITIZE ANTIFREEZE SET MAX: SET MAX LOCK LOCK EXT B6h 00h - NV Cache: SET NV F9h 03h Y CACHE POWER MODE SET MAX: SET MAX UNLOCK EXT B6h 01h - NV Cache: RETURN F9h 04h Y FROM NV CACHE SET MAX: SET MAX FREEZE LOCK POWER MODE EXT B6h 10h - NV Cache: ADD LBA(S) F9h 05h Y TO NV CACHE PINNED SET MAX: SET MAX PASSWORD DMA SET DMA EXT B6h 11h - NV Cache: REMOVE F9h LBA(S) FROM NV 06h Y SET MAX: SET MAX UNLOCK DMA CACHE PINNED SET DMA EXT NOTE: “Y” means “Support”. “O” means “Option, default No support”. “-” means “No support”. 12 5. PIN ASSIGNMENT Figure 5-1 XCEL 2.5’’ SATA SSD Pin Assignment Table 5-1 Signal Segment Pin Assignment and Descriptions Pin Number Function S1 GND S2 A+ (Differential Signal Pair A) S3 A – (Differential Signal Pair A) S4 GND S5 B – (Differential Signal Pair B) S6 B+ (Differential Signal Pair B) S7 GND Table 5-2 Power Segment Pin Assignment and Descriptions Pin Number Function P1 Not Used (3.3V) P2 Not Used (3.3V) P3 DEVSLP P4 GND P5 GND P6 GND P7 5V pre-charge P8 5V P9 5V P10 GND P11 Reserved P12 GND P13 Not Used (12V pre-charge) P14 Not Used (12V) P15 Not Used (12V) 13 6. PHYSICAL DIMENSION Dimension: 100mm (L) x 69.85mm (W) x 7.00mm(H) 14 7. ORDERING INFORMATION Support TCG OPAL/AES Capacity MPN (Silver Grade) MPN (Diamond Grade) 240GB FSSB240GBS-SE0S FSSB240GBE-SE0S 480GB FSSB480GBS-SE0S FSSB480GBE-SE0S 960GB FSSB960GBS-SE0S FSSB960GBE-SE0S 1920GB FSSB1920BS-SE0S FSSB1920BE-SE0S 3840GB FSSB3840BS-SE0S FSSB3840BE-SE0S 7680GB FSSB7680BS-SE0S FSSB7680BE-SE0S * Support TCG OPAL/AES with conformal coating Capacity MPN (Silver Grade) MPN (Diamond Grade) 240GB FSSB240GBS-SE0V FSSB240GBE-SE0V 480GB FSSB480GBS-SE0V FSSB480GBE-SE0V 960GB FSSB960GBS-SE0V FSSB960GBE-SE0V 1920GB FSSB1920BS-SE0V FSSB1920BE-SE0V 3840GB FSSB3840BS-SE0V FSSB3840BE-SE0V 7680GB FSSB7680BS-SE0V FSSB7680BE-SE0V * * Please check with FLEXXON 15 Revision History Revision Draft Date History 1.0 2018/11 Preliminary Release 1.1 2019/02 Update template and TBW 1.2 2019/04 Update ordering information 1.3 2019/04 Update ordering number with conformal coating 1.4 2019/05 Update ordering number 1.5 2019/06 Update capacity 1.6 2020/02 Update TBW 16
FSSB7680BS-SE0S 价格&库存
很抱歉,暂时无法提供与“FSSB7680BS-SE0S”相匹配的价格&库存,您可以联系我们找货
