EP58SC10-360-3F-P-24 数据手册
EP58 Series
Shaft Type/Blind Hollow Shaft Type Ø58mm Single-turn Absolute Rotary Encoder
Features
SENSORS
● Ø58mm flange type
● Applicable to various mounting environments
● Various output code: BCD, Binary, Gray code
(customizable)
● Various and high resolution (720, 1024-division)
CONTROLLERS
MOTION DEVICES
Applications
SOFTWARE
● Precision machine tool, Fabric machinery, Robot, Parking system
Please read “Safety Considerations”
in the instruction manual before using.
Ordering Information
EP58SC
10
Series Ø58mm
Shaft diameter
SC: Shaft clamping
External
10 Ø10mm
6
Ø6mm
Inner
8
Ø8mm
SS: Shaft synchro
HB: Blind hollow
shaft
Specifications
Type
Resolution
Output code
Electrical specification
Control
output
Output phase/
Output angle 1
1024
1
R
P
24
Pulses/
revolution
Output code
Rotating direction
Refer to
resolution
1: BCD code
2: Binary code
3: Gray code
F: O
utput value increases P: P
NP open
5: 5VDC ±5%
at CW direction
collector output
24: 1
2-24VDC
R: Output value increases N: NPN open
±5%
at CCW direction
collector output
Control output
Power supply
(A)
Photoelectric
Sensors
(B)
Fiber Optic
Sensors
(C)
LiDAR
720, 360, 180, 90, 45-division
1024, 512, 256, 128, 64-division
Division BCD code Binary code Gray code Division BCD code
Binary code
TS: 0 .5°±25' TS: 0 .5°±25' TS: 1 °±25'
TS: 0 .3515°±15' TS: 0 .3515°±15'
720
1024
(11-bit)
(10-bit)
(10-bit)
(13-bit)
(10-bit)
TS: 1 °±25' TS: 1 °±25' TS: 2 °±25'
TS: 0 .703°±15' TS: 0 .703°±15'
360
512
(10-bit)
(9-bit)
(9-bit)
(11-bit)
(9-bit)
TS: 2 °±25' TS: 2 °±25' TS: 4 °±25'
TS: 1 .406°±15' TS: 1 .406°±15'
180
256
(9-bit)
(8-bit)
(8-bit)
(10-bit)
(8-bit)
TS: 4 °±25' TS: 4 °±25' TS: 8 °±25'
TS: 2 .8125°±15' TS: 2 .8125°±15'
90
128
(8-bit)
(7-bit)
(7-bit)
(9-bit)
(7-bit)
TS: 8 °±25' TS: 8 °±25' TS: 1 6°±25'
TS: 5 .625°±15' TS: 5 .625°±15'
45
64
(7-bit)
(6-bit)
(6-bit)
(7-bit)
(6-bit)
(D)
Door/Area
Sensors
Gray code
TS: 0 .703°±15'
(10-bit)
TS: 1 .406°±15'
(9-bit)
TS: 2 .8125°±15'
(8-bit)
TS: 5 .625°±15'
(7-bit)
TS: 1 1.25°±15'
(6-bit)
(E)
Vision
Sensors
(F)
Proximity
Sensors
(G)
Pressure
Sensors
PNP open collector output Output voltage: min. (power supply-1.5)VDCᜡ, load current: max. 32mA
(H)
Rotary
Encoders
NPN open collector output Load current: max. 32mA, residual voltage: max. 1VDCᜡ
(I)
Connectors/
Connector Cables/
Sensor Distribution
Boxes/ Sockets
Ton=800ns, Toff=Max. 800ns (cable: 2m, I sink = 32mA)
35kHz
• 5VDCᜡ ±5% (ripple P-P: max. 5%)
• 12-24VDCᜡ ±5% (ripple P-P: max. 5%)
Max. 100mA (disconnection of the load)
Over 100MΩ (at 500VDC megger between all terminals and case)
750VAC 50/60Hz for 1 minute (between all terminals and case)
Axial cable type (cable gland)
• SC/SS type: max. 40gf·cm (0.004N·m)
• HB type: max. 90gf·cm (0.009N·m)
• SC/SS type: max. 15g·cm² (1.5×10-6kg·m²)
• HB type: max. 20g·cm² (2.0×10-6kg·m²)
• SC/SS type: radial: max. 10kgf, thrust: max. 2.5kgf
Shaft loading
• HB type: radial: max. 2kgf, thrust: max. 1kgf
※2
Max. allowable revolution 3,000rpm
Vibration
1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours
Shock
Approx. max. 50G
Ambient temp.
-10 to 70℃, storage: -25 to 85℃
Environment
Ambient humi.
35 to 85%RH, storage: 35 to 90%RH
Protection structure
IP50 (IEC standard)
Cable
Ø7mm, 15-wire, 2m, Shield cable
Accessories
Ø10mm (SC type)/Ø6mm (SS type) coupling, Fixing bracket
Approval
• SC type: approx. 545g (approx. 435g)
• SS type: approx. 525g (approx. 415g)
※3
Weight
• HB type: approx. 520g (approx. 410g)
※1: TS=Signal Pulse
※Environment resistance is rated at no freezing or condensation.
※2: Make sure that max. response revolution should be lower than or equal to max. allowable revolution when selecting the resolution.
Max. response frequency
× 60 sec]
[Max. response revolution (rpm)=
Resolution
※3: The weight includes packaging. The weight in parenthesis is for unit only.
Mechanical
specification
Response time (rise/fall)
Power supply
Current consumption
Insulation resistance
Dielectric strength
Connection
Starting torque
Moment of inertia
H-81
EP58 Series
Output Waveform
360-division (BCD code output)
Model
EP58
-360-1 -P20
2
3
4
5
6
7
8
178 179 180 181 182
357 358 359 0
21
22
23
10×20
10×21
10×22
10×23
100×20
100×21
TS
※TS=1°±25'
※Above waveform is based on the positive logic. (the output waveform of negative logic is opposite to the above waveform.)
360-division (Binary code output)
Model
EP58
-360-2 -P0
1
2
3
4
5
6
7
8
178 179 180 181 182
357 358 359 0
22
23
24
25
26
27
28
TS
※TS=1°±25'
1024-division (BCD code output)
Model
EP58
-1024-1 -P0
1
2
3
4
5
6
7
8
511 512 513
10211022 1023 0
22
23
10×20
10×21
10×22
10×23
100×20
100×21
100×22
100×23
1000×20
TS
※TS=0.3515°±15'
H-82
Absolute Ø58mm Single-turn Shaft/Blind Hollow Shaft Type
Output Waveform
1024-division (Binary code output)
EP58
Model
SENSORS
-1024-2 -P0
1
2
3
4
5
6
7
8
511 512513
102110221023 0
CONTROLLERS
MOTION DEVICES
22
23
SOFTWARE
24
25
26
27
28
29
(A)
Photoelectric
Sensors
TS
※TS=0.3515°±15'
(B)
Fiber Optic
Sensors
Control Output Diagram
(C)
LiDAR
Rotary encoder circuit
Load connection
Load connection
Source current
: max. 32mA
Output
+V
Main circuit
Main circuit
+V
Load
(D)
Door/Area
Sensors
Output
0V
0V
Load
(E)
Vision
Sensors
Sink current
: max. 32mA
(F)
Proximity
Sensors
(G)
Pressure
Sensors
※In case of overload or short on output terminal, it may cause output circuit break.
(H)
Rotary
Encoders
Connections
BCD code
Binary code / Gray code
Resolution 45- 64- 90- 128- 180- 256- 360- 512- 720- 1024-
Resolution 45- 64- 90- 128- 180- 256- 360- 512- 720- 1024division
Color
Power
division
White
+V
Black
GND (0V)
Brown
Red
Orange
division
division
division
division
division
division
division
Color
division
+V
Black
GND (0V)
Brown
Red
21
22
Orange
22
Yellow
23
Blue
24
Purple
25
N.C
Power
3
2
Blue
20×10
Purple
21×10
22×10
N.C
N.C
White/Orange N.C
White/Yellow N.C
White/Red
White/Purple
N.C
N.C
Shield wire
F.G.
White/Blue
division
White
Yellow
Output Gray
wire
White/Brown
division
Output Gray
wire
White/Brown
23×10
20×100
White/Red
N.C
N.C
White/Orange N.C
White/Yellow N.C
21×100
22×100
23×100
White/Blue
20×1000
White/Purple
N.C
N.C
Shield wire
F.G.
division
division
division
division
division
division
division
division
26
27
28
29
※Unused wires must be insulated.
※Encoder metal case and shield wire must be grounded (F.G.).
※N.C (not connected)
※Output cable must not be short-circuited, because Driver IC is used in output circuit.
※Do not apply tensile strength over 30N to the cable.
H-83
(I)
Connectors/
Connector Cables/
Sensor Distribution
Boxes/ Sockets
EP58 Series
Dimensions
(unit: mm)
Ø10 -0.02
-0.005
EP58SC10
3-M3 DP 6
3
54.5
22.5
-0.025
18
Ø7, 2m
3-1
Ø58
3 -1
9
Ø36 -0.064
Ø48
20 10
3
3-M4 DP 6
EP58SS6
10 4
4
Ø42
55.5
2-3
22.5
-0.004
Ø6 -0.016
9
Ø7, 2m
3-1
Ø58
3-1
Ø50 -0.009
-0.025
3-M4 DP 6
3-M3 DP 6
+0.02
Ø8 +0.005
EP58HB8
6
54.5
3-3
22.5
Ø15
Ø58
22.5 22.5
3-12
Ø42
3-M4 DP 6
Ø7, 2m
15
4-M3 DP 6
66
Bracket
9.2
1.5
3.4
3.4
4-M4
12
22
Ø15
+0.1
Ø6
12
22
45
2-Ø7
2-Ø3.4
25
+0.1
Ø10
EP58SS6
2-3.5
7
70
40
6
Ø3-4.5
Ø22
2
HB type
6
Ø3-3.5
Ø36.5
24
15
7
8.5
65
3-1
EP58SC10
R2.1
50
65
3-1
R27
5 15 5
R1.8
Coupling
SS type
12.5
SC type
6
2.8
2.8
4-M3
Parallel misalignment: max. 0.25mm
Angular misalignment: max. 5°
End-play: max. 0.5mm
※Do not load overweight on the shaft.
※Do not put strong impact when insert a coupling into shaft.
Failure to follow this instruction may result in product damage.
※Fix the unit or a coupling by a wrench under 0.15N.m of torque.
※When you install this unit, if eccentricity and deflection angle are larger,
it may shorten the life cycle of this unit.
※For parallel misalignment, angular misalignment, end-play terms, refer to the "Glossary"
section of Technical Description.
※For flexible coupling (ERB series) information, refer to the ERB series section.
H-84
EP58SC10-360-3F-P-24 价格&库存
很抱歉,暂时无法提供与“EP58SC10-360-3F-P-24”相匹配的价格&库存,您可以联系我们找货
