PA3223
PA3223
    IFM(易福门)
    圆柱形,有螺纹
    PRESSURE TRANSMITTER,0-25 BAR,AN
PA3223 数据手册
PA3223 Pressure transmitter with ceramic measuring cell PA-025-RBN14-A-ZVG/US/ /V Product characteristics Number of inputs and outputs Number of analogue outputs: 1 Measuring range 0...25 bar Process connection 0...363 psi 0...2.5 MPa threaded connection 1/4" NPT internal thread Application Special feature Gold-plated contacts Application for industrial applications Media liquids and gases Medium temperature [°C] -25...90; (on request: -40...90 °C) Min. bursting pressure 350 bar 5075 psi 35 MPa Pressure rating 150 bar 2175 psi 15 Mpa Type of pressure relative pressure Electrical data Operating voltage Min. insulation resistance [V] [MΩ] Protection class 9.6...32 DC 100; (500 V DC) III Reverse polarity protection yes Inputs / outputs Number of inputs and outputs Number of analogue outputs: 1 Outputs Total number of outputs 1 Output signal analogue signal Number of analogue outputs Analogue current output 1 [mA] 4...20 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PA3223-01 — 13.04.2023 — PA3223 Pressure transmitter with ceramic measuring cell PA-025-RBN14-A-ZVG/US/ /V Max. load [Ω] 720; (Ub = 24 V; (Ub - 9,6 V) / 20 mA) Overload protection yes Measuring/setting range Measuring range 0...25 bar 0...363 psi 0...2.5 MPa Accuracy / deviations Repeatability [% of the span] Characteristics deviation [% of the span] < 0,1; (with temperature fluctuations < 10 K) < ± 0,25 (BFSL) / < ± 0,5 (LS); (BFSL = Best Fit Straight Line; LS = limit value setting) Long-term stability < ± 0,05; (per 6 months) [% of the span] Temperature coefficient zero point [% of the span / 10 K] 0,1; (0...80 °C) Temperature coefficient span [% of the span / 10 K] 0,2; (0...80 °C) Response times Step response time analogue output [ms] 3 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 65 Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 30 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V radiation of interference according to the automotive directive 2004/104/EC CISPR 25 Shock resistance Vibration resistance MTTF immunity according to the automotive directive 2004/104/EC ISO 11452-2 HF radiated 100 V/m ISO 7637-2 pulse severity level 4 DIN EN 60068-2-27 50 g (11 ms) DIN EN 61373 category 3 DIN EN 60068-2-6 20 g (10...2000 Hz) DIN EN 61373 category 2 [years] Pressure Equipment Directive 506 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Railway applications DIN EN 50155 / IEC 60571 Klasse T3, C1, S1 Mechanical data Weight [g] Materials Materials (wetted parts) 225.5 stainless steel (1.4404 / 316L); FKM; PA; EPDM/X stainless steel (1.4305 / 303); ceramics; FKM Min. pressure cycles 100 million Process connection threaded connection 1/4" NPT internal thread ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PA3223-01 — 13.04.2023 — PA3223 Pressure transmitter with ceramic measuring cell PA-025-RBN14-A-ZVG/US/ /V Restrictor element integrated no (can be retrofitted) Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PA3223-01 — 13.04.2023 —
PA3223 价格&库存
很抱歉,暂时无法提供与“PA3223”相匹配的价格&库存,您可以联系我们找货
