VSP001
VSP001
    IFM(易福门)
    圆柱形,有螺纹
    加速 传感器 面板安装
VSP001 数据手册
VSP001 Acceleration sensor VIBRATION SENSOR Product characteristics Measuring range of vibration Frequency range [g] [Hz] Measuring principle -80...80; (-50...50 g when connected to a VSE) 2...10000 piezoelectric Communication interface IEPE Application Design for connection to external diagnostic electronics VSE Electrical data Bias voltage DC [V] 10...12 Current consumption [mA] 0.5...8 Min. insulation resistance [MΩ] 100; (500 V DC) Reverse polarity protection yes Measuring/setting range Measuring range of vibration Frequency range [g] [Hz] Measuring principle Noise density -80...80; (-50...50 g when connected to a VSE) 2...10000 piezoelectric [mg] 0.1 Max. transverse sensitivity [%] 5 Minimum measuring time [s] 2 Number of measurement axes 1 Accuracy / deviations Accuracy ±5% Measuring sensitivity 100 mV/g Interfaces Communication interface IEPE Operating conditions Ambient temperature [°C] -55...125 Storage temperature [°C] -55...125 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSP001-00 — 13.04.2023 — VSP001 Acceleration sensor VIBRATION SENSOR Protection IP 67 Tests / approvals EMC EN 61326-1 Shock resistance : 2013 5000 g MTTF [years] 1142 [g] 73.5 Mechanical data Weight Type of mounting set screw Materials housing: stainless steel Tightening torque [Nm] 8 Accessories Items supplied set screws Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Maximum cable length: 1000 m 1 2 3 4 not used IEPE + not used IEPE - ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSP001-00 — 13.04.2023 —
VSP001 价格&库存
很抱歉,暂时无法提供与“VSP001”相匹配的价格&库存,您可以联系我们找货
