KLDX-0202-BC
KLDX-0202-BC
    KYCON
    套管 - 电源连接器 插孔 2.50mm 内径(0.098"),5.50mm 外径(0.217") 通孔,直角
KLDX-0202-BC 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDX-0202-A Part Number Builder R E 140125 LR78160 KLDX-0202 A Series Diameter DC POWER CONNECTORS: KLDX Series Lead Style PCB Mount DC Power Jack Series KLDX-0202 - PCB Mount DC Power Jack Product Features 2.0mm and 2.5mm Built-In DC On/Off Switch Laptop and Palm Computers, Portable Modems, Radar Detectors, and Other Portable Device Applications CSA/NRTL Certified File No. LR78160 UL File No. E140125 Diameter A - 2.0mm Center Pin Diameter B - 2.5mm Center Pin Diameter Lead Style Blank - Standard Straight C - Crimped Performance Specifications Materials and Finish Plastic Housing: PBT, UL94V-0 Rated, Black Color Center Pin: Copper Alloy, Nickel Plated Contact #1 and #3: Brass, Tin Plated Contact #2: Phosphor Bronze, Tin Plated Electrical Characteristics Contact Resistance Before Durability Test Between Terminals: 30 milliohms Max. Plug to Contacts: 50 milliohms Max. After Durability Test Between Terminals: 60 milliohms Max. Plug to Contacts: 100 milliohms Max. Rated Voltage: 24V DC Rated Current: 3.5A Insulation Resistance: 100 Megohms Min. at 500V DC Dielectric Withstanding Voltage: 500V AC RMS for 1 Minute Contact Kycon For HT Reflow Compatible and Other Options KLDX Series Dimensions in mm KLDX-0202-x KLDX-0202-xC Mechanical Characteristics Durability Test: 5000 Cycles Insertion Force: 0.3kg - 2.5kg Extraction Force: 0.3kg - 2.5kg Operating Temperature: -25˚C to +85˚C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 1218
KLDX-0202-BC 价格&库存
很抱歉,暂时无法提供与“KLDX-0202-BC”相匹配的价格&库存,您可以联系我们找货
