KLDX-0202-BP-LT
KLDX-0202-BP-LT
    KYCON
    套管 - 电源连接器 插孔 2.50mm 内径(0.098"),5.50mm 外径(0.217") 通孔,直角
KLDX-0202-BP-LT 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDX-0202-AP-LT Part Number Builder R E 140125 LR78160 KLDX-0202 DC POWER CONNECTORS: KLDX Series Series A P LT Diameter Peg Type Locking Type PCB Mount DC Power Jack Series KLDX-0202 - PCB Mount DC Power Jack Locking Type Product Features 2.0mm and 2.5mm Built-In DC On/Off Switch Locking Feature (Will Lock with Kycon Locking Plug) To Be Used with Locking/Non-Locking Tuning Fork Style Plug Laptop and Palm Computers, Portable Modems, Radar Detectors, and Other Portable Device Applications CSA/NRTL Certified File No. LR78160 UL File No. E140125 Diameter A - 2.0mm Center Pin Diameter B - 2.5mm Center Pin Diameter Peg Blank - without Peg P - with Peg Type LT - Locking Type Contact Kycon For Other Options Performance Specifications Materials and Finish Body: PBT Thermoplastic, UL94V-0 Rated, Color Black Center Pin: Brass, Nickel Plated Contact #1: Brass, Tin Plated Contact #2: Phosphor Bronze, Tin Plated Contact #3: Brass, Tin Plated Recommended to be used with Kycon locking plug (tuning fork design): KLDX-PA-0202-A-LT, KLDX-PA-0202-B-LT If used with non-locking plug, tuning fork design is required. See picture. Tuning fork contact Electrical Characteristics Rated Current: 3.5A Rated Voltage: 24V DC Insulation Resistance: 50 Megohms Min. at 100 or 200V DC for 1 Minute KLDX-0202 Series Dimensions in mm KLDX-0202-x-LT Mechanical Characteristics Durability Test: 5000 Cycles Insertion Force: 0.3kg - 2.0kg Extraction Force: 0.3kg - 2.0kg Operating Temperature: -25˚C to +85˚C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
KLDX-0202-BP-LT 价格&库存
很抱歉,暂时无法提供与“KLDX-0202-BP-LT”相匹配的价格&库存,您可以联系我们找货
