KLDX-SMT2-0202-BTR
KLDX-SMT2-0202-BTR
    KYCON
    套管 - 电源连接器 插孔 2.50mm 内径(0.098"),5.50mm 外径(0.217") 表面贴装,直角
KLDX-SMT2-0202-BTR 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDX-SMT2-0202-ATR-1 Part Number Builder LR78160 KLDX-SMT2-0202 A TR Series Diameter Packing Option DC POWER CONNECTORS: KLDX-SMT2 Series Surface Mount DC Power Jack Series KLDX-SMT2-0202 - Surface Mount DC Power Jack Product Features 2.0mm and 2.5mm. Built-In DC On/Off Switch Laptop and Palm Computers, Portable Modems, Radar Detectors, and Other Portable Device Applications Surface Mount CSA/NRTL Certified File No. LR78160 Diameter A - 2.0mm Center Pin Diameter B - 2.5mm Center Pin Diameter Packaging Option TR - Tape and Reel Contact Kycon for Other Options Performance Specifications Materials and Finish Main Housing: LCP, UL 94V-0 Rated, Black Color Back Cover: PA9T, UL 94V-0 Rated, Black Color Center Pin: Copper Alloy, Nickel Plated Contact #1: Phosphor Bronze, Silver Plated Contact #2 and #3: Brass, Silver Plated KLDX-SMT2 Series Dimensions in mm Electrical Characteristics Contact Resistance Before Durability Test Between Terminals: 30 milliohms Max. Plug to Contacts: 50 milliohms Max. After Durability Test Between Terminals: 60 milliohms Max. Plug to Contacts: 100 milliohms Max. Rated Voltage: 24V DC Rated Current: 3.5A Insulation Resistance: 100 Megohms Min. at 500V DC Dielectric Withstanding Voltage: 500V AC RMS for 1 Minute Mechanical Characteristics Durability Test: 5000 Cycles Insertion Force: 0.3kg - 2.0kg Extraction Force: 0.3kg - 2.0kg Operating Temperature: -25˚C to +65˚C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
KLDX-SMT2-0202-BTR 价格&库存
很抱歉,暂时无法提供与“KLDX-SMT2-0202-BTR”相匹配的价格&库存,您可以联系我们找货
