CP17782_AMY-70-S-C
CP17782_AMY-70-S-C
    LEDIL(芬兰)
    带座透镜 18° 光
CP17782_AMY-70-S-C 数据手册
PRODUCT DATASHEET CP17782_AMY-70-S-C AMY-70-S-C ~18° spot beam. Assembly with holder C compatible with LEDiL HEKLA. Black version. SPECIFICATION: Dimensions Height Ø 69.9 mm 16.4 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material AMY-70-S Single lens PMMA AMY-70-HLD-C Holder PC Colour Finish black ORDERING INFORMATION: Component CP17782_AMY-70-S-C » Box size: 480 x 280 x 300 mm Qty in box 210 MOQ MPQ 210 15 Box weight (kg) 8.7 Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/12 PRODUCT DATASHEET CP17782_AMY-70-S-C See also our general installation guide: www.ledil.com/installation_guide Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (MEASURED): LED V10 Gen 8 FWHM / FWTM 17.0° / 37.0° Efficiency 92 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED V11 HD Gen 8 FWHM / FWTM 18.0° / 38.0° Efficiency 91 % Peak intensity 5.9 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 633d Hekla LED V13 Gen 8 FWHM / FWTM 23.0° / 48.0° Efficiency 90 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I LED V8 Gen 8 FWHM / FWTM 17.0° / 36.0° Efficiency 93 % Peak intensity 6.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15253_HEKLA-SOCKET-A Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 17.0° / 36.0° Efficiency 90 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C LED CMU15xx FWHM / FWTM 23.0° / 48.0° Efficiency 88 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: F17438_HEKLA-G2-I LED LUXEON Fusion 12-up (20x24) FWHM / FWTM 19.0° / 38.0° Efficiency 84 % Peak intensity 5.2 cd/lm LEDs/each optic 12 Light colour White Required components: C16142_HEKLA-SOCKET-K F18158_HEKLA-RZ-LENS Bender Wirth: 442 Typ L8 LED LUXEON Fusion 21-up (20x24) FWHM / FWTM 19.0° / 38.0° Efficiency 82 % Peak intensity 4.9 cd/lm LEDs/each optic 21 Light colour White Required components: C16142_HEKLA-SOCKET-K F18158_HEKLA-RZ-LENS Bender Wirth: 442 Typ L8 Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (MEASURED): LED LUXEON Fusion 27-up (20x24) FWHM / FWTM 23.0° / 45.0° Efficiency 82 % Peak intensity 3.6 cd/lm LEDs/each optic 27 Light colour White Required components: C16142_HEKLA-SOCKET-K F18158_HEKLA-RZ-LENS Bender Wirth: 442 Typ L8 LED CTM-14 (Tunable White) Gen2 FWHM / FWTM 22.0° / 46.0° Efficiency 89 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour Tunable White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 442 Typ L8 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 23.0° / 49.0° Efficiency 88 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM 23.0° / 48.0° Efficiency 92 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED V8 Gen7 FWHM / FWTM 14.0° / 32.0° Efficiency 91 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour White Required components: F15253_HEKLA-SOCKET-A LED VERO10 FWHM / FWTM 14.0° / 32.0° Efficiency 91 % Peak intensity 9.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15616_HEKLA-SOCKET-F LED VERO13 FWHM / FWTM 18.0° / 40.0° Efficiency 89 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (SIMULATED): LED Vesta DTW 9mm (4W/6W/12W) FWHM / FWTM 14.0° / 32.0° Efficiency 91 % Peak intensity 9.7 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 652b Hekla LED Vesta DTW 9mm (4W/6W/12W) FWHM / FWTM 18.0° / 36.0° Efficiency 87 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour White Required components: F18158_HEKLA-RZ-LENS Bender Wirth: 652b Hekla LED CLL03x/CLU03x FWHM / FWTM 22.0° / 42.0° Efficiency 89 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I LED CLU700/701/702/703 FWHM / FWTM 10.0° / 20.0° Efficiency 93 % Peak intensity 18.9 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (SIMULATED): LED CLU700/701/702/703 FWHM / FWTM 10.0° / 22.0° Efficiency 92 % Peak intensity 17.2 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED CMA1825 FWHM / FWTM 18.0° / 41.0° Efficiency 90 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15254_HEKLA-SOCKET-B LED CMA1840 FWHM / FWTM 21.0° / 45.0° Efficiency 89 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 637a Hekla LED CMT14xx FWHM / FWTM 15.0° / 34.0° Efficiency 91 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (SIMULATED): LED CMU10xx FWHM / FWTM 14.0° / 34.0° Efficiency 91 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour White Required components: F17435_HEKLA-G2-C LED CXA/B 15xx FWHM / FWTM 14.0° / 29.0° Efficiency 91 % Peak intensity 10.1 cd/lm LEDs/each optic 1 Light colour White Required components: F15256_HEKLA-SOCKET-D LED LUXEON CX Plus CoB - HD S04H9 FWHM / FWTM 16.0° / 34.0° Efficiency 91 % Peak intensity 8.2 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED COB L-Type (LES 11) FWHM / FWTM 18.0° / 38.0° Efficiency 90 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour White Required components: F17437_HEKLA-G2-H Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (SIMULATED): LED Fortimo SLM L15 CoB FWHM / FWTM 22.0° / 44.0° Efficiency 90 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 632a Hekla XL LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 14.0° / 30.0° Efficiency 92 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 22.0° / 44.0° Efficiency 89 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I LED LC020T (Tunable white) FWHM / FWTM 16.0° / 34.0° Efficiency 91 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET CP17782_AMY-70-S-C OPTICAL RESULTS (SIMULATED): LED XOB 14.5 mm FWHM / FWTM 22.0° / 42.0° Efficiency 82 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: F17438_HEKLA-G2-I Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET CP17782_AMY-70-S-C GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 09/06/2023 Subject to change without prior notice Published: 07/07/2021 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
CP17782_AMY-70-S-C 价格&库存
很抱歉,暂时无法提供与“CP17782_AMY-70-S-C”相匹配的价格&库存,您可以联系我们找货
