PRODUCT
DATASHEET
CP18573_AMY-110-W-C
AMY-110-W-C
~36° wide beam. Assembly with holder C
compatible with LEDiL HEKLA. Black version.
SPECIFICATION:
Dimensions
Height
ROHS compliant
Ø 109.7 mm
23.6 mm
yes
MATERIALS:
Component
Type
Material
Colour
AMY-110-W
Single lens
PMMA
clear
AMY-110-HLD-C
Holder C
PC
black
Finish
ORDERING INFORMATION:
Component
CP18573_AMY-110-W-C
» Box size: 480 x 280 x 300 mm
Qty in box
77
MOQ
77
MPQ
7
Box weight (kg)
8.6
Last update: 27/07/2023
Subject to change without prior notice
Published: 02/12/2022
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
See also our general installation guide: www.ledil.com/installation_guide
2/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
OPTICAL RESULTS (MEASURED):
LED
CTM-14 (Tunable White) Gen2
FWHM / FWTM
35.0° / 63.5°
Efficiency
88 %
Peak intensity
1.9 cd/lm
LEDs/each optic
1
Light colour
Tunable White
Required components:
C16142_HEKLA-SOCKET-K
Bender Wirth: 442 Typ L8
3/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
OPTICAL RESULTS (SIMULATED):
LED
V10 Gen 8
FWHM / FWTM
36.0° / 58.0°
Efficiency
92 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
F15255_HEKLA-SOCKET-C
LED
V11 HD Gen 8
FWHM / FWTM
36.0° / 58.0 + 59.0°
Efficiency
92 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
F15859_HEKLA-SOCKET-I
LED
V13 Gen 8
FWHM / FWTM
36.0° / 63.0°
Efficiency
90 %
Peak intensity
2 cd/lm
LEDs/each optic
1
Light colour
White
LED
V18 Gen 8
FWHM / FWTM
36.0° / 71.0°
Efficiency
84 %
Peak intensity
1.6 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 462 Typ L8
4/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
LED
V8 Gen 8
FWHM / FWTM
36.0° / 55.0°
Efficiency
92 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
F15253_HEKLA-SOCKET-A
LED
V9 HD Gen 8
FWHM / FWTM
36.0 + 35.0° / 55.0°
Efficiency
92 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
Vero SE 10
FWHM / FWTM
38.0° / 62.0°
Efficiency
92 %
Peak intensity
2 cd/lm
LEDs/each optic
1
Light colour
White
LED
Vero SE 29
FWHM / FWTM
40.0° / 83.0°
Efficiency
77 %
Peak intensity
1.1 cd/lm
LEDs/each optic
1
Light colour
White
5/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
LED
VERO18
FWHM / FWTM
38.0 + 36.0° / 72.0 + 73.0°
Efficiency
89 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Vesta DTW 13mm (21W)
FWHM / FWTM
36.0° / 54.0°
Efficiency
93 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 632b Hekla XL
LED
Vesta DTW 15mm (33W)
FWHM / FWTM
37.0 + 36.0° / 63.0°
Efficiency
90 %
Peak intensity
2 cd/lm
LEDs/each optic
1
Light colour
White
LED
Vesta DTW 9mm (4W/6W/12W)
FWHM / FWTM
Efficiency
93 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 652b Hekla
6/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
LED
Vesta TW 13mm (18W) DP
FWHM / FWTM
36.0° / 61.0 + 60.0°
Efficiency
90 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
Tunable White
Bender Wirth: 492 Typ L8
LED
Vesta TW 15mm DP
FWHM / FWTM
34.0 + 35.0° / 63.0°
Efficiency
89 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
Tunable White
Bender Wirth: 482 Typ L8
LED
Vesta TW 18mm (31W) DP
FWHM / FWTM
36.0° / 71.0°
Efficiency
84 %
Peak intensity
1.6 cd/lm
LEDs/each optic
1
Light colour
Tunable White
LED
Vesta TW 9mm (9W) DP
FWHM / FWTM
39.0° / 60.0°
Efficiency
93 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
Tunable White
Bender Wirth: 489 Typ L8
7/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
LED
CLL03x/CLU03x
FWHM / FWTM
35.0° / 62.0°
Efficiency
90 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
White
F17438_HEKLA-G2-I
LED
LUXEON CoB 1204/1205
FWHM / FWTM
37.0° / 61.0 + 60.0°
Efficiency
91 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 632a Hekla XL
LED
LUXEON CoB 1205HD
FWHM / FWTM
36.0° / 58.0°
Efficiency
92 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
F15858_HEKLA-SOCKET-H
LED
LUXEON CoB 1208
FWHM / FWTM
36.0° / 62.0°
Efficiency
91 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
White
8/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
LED
LUXEON CoB 1211
FWHM / FWTM
37.0 + 36.0° / 71.0 + 70.0°
Efficiency
89 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 631b Hekla XL
LED
LUXEON CoB 1213/1216/1812
FWHM / FWTM
39.0° / 80.0 + 81.0°
Efficiency
81 %
Peak intensity
1.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LC016D / LC019D / LC026D / LC033D
FWHM / FWTM
35.0° / 65.0°
Efficiency
89 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
White
F17438_HEKLA-G2-I
9/10
PRODUCT
DATASHEET
CP18573_AMY-110-W-C
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
Due to use of high power COB's with this product, special attention to proper
thermal design is highly recommended. LEDiL has no liability for direct,
indirect or consecutive damages arising from the LEDiL products being used
outside of the recommended temperature range.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
10/10
CP18573_AMY-110-W-C 价格&库存
很抱歉,暂时无法提供与“CP18573_AMY-110-W-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 7+54.316657+6.58378
- 28+54.0628328+6.55301
- 105+54.06163105+6.55287
- 210+54.06043210+6.55272
- 525+54.05924525+6.55258
- 国内价格 香港价格
- 2+54.316652+6.58378
- 10+54.0628310+6.55301
- 30+54.0616330+6.55287
- 125+54.06043125+6.55272
- 300+54.05924300+6.55258
