7
UTGX0JC-----P
WIRING AREA (between insert and backshell seal
I1
MATERIAL :
N
- SHELL : PA UL94 V0, UL746C F1 Black color
8
- 3 LOCKING PINS RING : Nickel plated Brass + stainless
steel.
- BACKSHELLS : PA UL94 V0 F1 Black color
- BACKSHELL Seal : CR
- INSERT (UTGX0JC-----) : PA UL94 V0, UL746C F1 Black
color
- INSERT (UTGX0JC--/E---) : Polychloroprene
- CONTACTS: brass + coated depending on P/N
I2
7
REAR mounting
PERFORMANCE CHARACTERISTICS :
I4
6
NOTA:
1- Contact to be ordered separately for version
UTGX0JC----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
UTO-CONTACT-L-C02 (Female insulator)
UTO-DHP-003-C01 (Female insulator #20)
UTO-DHP-002-C01 (Female insulator #16)
UTO-CONTACT-L-C01 (Male insulator)
UTO-DHP-003-C01 (Male insulator #20)
UTO-DHP-001-C01 (Male insulator #16)
C144-UTS1-A (HiSeal Version)
M
PANEL CUT OUT DEFINITION
5
Sealing in MATED conditions with
COUNTERPART:
COUNTERPART and UNMATED conditions:
-IP68 1 bar during 1 week:
immersion under 10 m of water.
(IEC 60529)
-IP69K : exposure to high pressure water of cleaning
equipement(DIN 40050)
BACKSHELL
NUT
BACKSHELL
SEAL
10
12
14
REAR
mounting
0.1
J
3.2
0.1
K
0.15
L
M
17.9
18.3
18.3
22.3
20.6
20.6
25.1
23.0
23.0
PANEL
THICKNESS
MAX
N
2.8
CountryJurisdiction& Control List
FR
NOT LISTED
A
(Without marking)
B
SHELL TYPE
2
A
B
1
10
23.8
18.26
12
26.2
20.62
14
28.6
23.01
H
0.1
C
0.2
0.2
D
E
15.2
3.2
19.15
11.35
22.31
G
MAX
F
HEXAGON backshell nut
G
Tightening
torque (N.m)
H
30% (g.)
I1
I2
I3
I4
67
18.5
1
2.5 / 8
1.5 / 5
20.5
32
28
32
15
70
24
2
5 / 12
3 / 9
24
36
32
36
25
76
26
2.5
7 / 14
5 / 12
28
39.5
36
39.5
35
F
E
D
Normal (no digit)
W,X,Y,Z
SHELL SIZE
10
12
14
TYPE OF
CONTACTS
P: MALE
S: FEMALE
TYPE OF
LAYOUT
Standard layout (No digit)
E : HISEAL Handsolder contacts
INSERT
ARRANGEMENT
See NOTA 2
22/09/2020
DATE
TITLE
MASS
Square flange
receptacle
JC
Designed by:
MINI
* P/N for example
BACKSHELL
ISS
0.2
UTGX 0 JC 14 E 19 P
BASIC SERIES
A
0.4
4
P/N : CROSS REF TABLE
C (x4)
REDUCING
STANDARD SEAL (NOTA.3)
5
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
B
CAPACITY
H
3
BACKSHELL
BODY
HEXAGON G
(See tightening torque in table)
F MAX
E
SHELL
SHELL
SIZE
(IEC 60529)
D
4
COMMON DIMENSIONS
SEALING
FOR ALL VERSION CONDITIONS
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
under 500V
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
Sealing conditions: SEE TABLE
L
I3
K
A
(Without marking)
6
UTGX0JC-----S
J (x4)
SHELL
SIZE
A
UTGX0JC--E---
B
C
D
E
F
G
H
UTGX0JC-----
8
A.3; Validé
SIDE VIEW FOR EACH VERSION
Scale
3/2
-New drawing
Latest modification - by:
J.FEURPRIERDate:22/09/2020
C
A2
2
SQUARE FLANGE RECEPTACLE WITH BACKSHELL - SIZE 10 12 14 - Std and Hiseal version
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
FORMAT
CUSTOMER DRAWING
MOD N
3
SOURIAU DRG N°
UTGX-0011A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTGX0JC124S”相匹配的价格&库存,您可以联系我们找货
