7
MATERIAL :
A
(without marking)
UTSX7-----PSCR
G
B
1- Contact to be ordered separately for version
UTSX7----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
UTX_LAYOUT (Standard Version)
Only for layout 12-4 and 14-7
E
F
O'RING
5
SEALING
CONDITION
SHELL
RECEPTACLE
4
3 LOCKING
PINS
D
PANEL THICKNESS
L
CountryJurisdiction& Control List
FR
NOT LISTED
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
P/N : CROSS REF TABLE
UTSX
7 14 7 P SCR
* P/N
for example
J
BASIC SERIES
SHELL TYPE
DETAIL CONTACT
2
0.2
SHELL
SIZE A
0.2
B
31.75 27.15
1
34.90 30.20
0.3
C
19.3
0.2
D
19.15
22.31
0.3
E
2.2
0.2 MAX
F
24.5
MAX
0.2
0.15
G
H
J
K
46.5
38.3
21.4
22.7
52.5
44.4
24.5
25.9
2
L
3
UNEF CLASS
2A
THREAD
Torquing screw
advised : 20 N.cm
7/8 20
Cable section acceptance:
0,5 mm2 to 2,5 mm2
3
PANEL CUT OUT
5
THREAD
K
6
C
6
UTSX7-----SSCR
7
NOTA:
Sealing in MATED conditions with
COUNTERPART:
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week: immersion
under 10 m of water.
-IPx9K : exposure to high pressure water
of cleaning equipement (IEC 60529)
8
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
Sealing conditions: SEE TABLE
NUT
14
SHELL : PA UL94 V0, UL746C F1 Black color
INSERT : PA UL94 V0, UL746C F1
NUT : Aluminium alloy + Anodic oxidation
O'RING : Nitril
CONTACT SPRING: copper alloy
CONTACT BODY : brass, gold and nickel plated
SCREW : stainless steel
PERFORMANCE CHARACTERISTICS :
H
12
A
B
C
D
E
F
G
H
SIDE VIEW FOR EACH VERSION
8
B.2; Validé
COMMON QUOTES FOR ALL VERSION
7
SHELL SIZE
12
14
INSERT
ARRANGEMENT
See NOTA 2
B
15/09/2021
ISS
DATE
Designed by:
TITLE
Scale
3/1
1"20
3
Jam nut
receptacle
SCREW TERMINATION
TYPE OF
CONTACTS
Mass column deleted
Latest modification - by:
J.GAMBIER
25782C
Q.LECOMTE
Date: 02/11/2020
H
G
F
E
D
C
FORMAT
A2
CUSTOMER DRAWING
MOD N
2
JAM NUT RECEPTACLE WITH SCREW CONTACT- SIZE 12 & 14
UTSX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
Wire strip length = 5,8 mm
P: MALE
S: FEMALE
SOURIAU DRG N°
UTSX-0007A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX7147SSCR”相匹配的价格&库存,您可以联系我们找货
