6
UTSX6JC-----PSCR
UTSX6JC-----SSCR
7
A-A
SHELL : PA UL94 V0, UL746C F1 Black color
COUPLING RING: PA UL94 V0 F1 Black color
BACKSHELLS : PA UL94 V0 F1 Black color
BACKSHELL Seal : CR
INSERT : PA UL94 V0, UL746C F1
O'RING : NITRIL
MATING SEAL : SILICON
CONTACT SPRING: copper alloy
CONTACT BODY : brass, gold and nickel plated
SCREW : stainless steel
WIRING AREA (between insert and backshell seal)
E2
6
NOTA :
1- Contact to be ordered separately for version
UTSX0----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
A-A
COUPE
UTX_LAYOUT (Standard Version)
Only for layout 12-4 and 14-7
COUPLING RING
BACKSHELL
BODY
THREAD
BACKSHELL
SEAL
BACKSHELL
NUT
A
SHELL
PLUG
A
A
MATING
SEAL
INSERT
O'RING
CountryJurisdiction& Control List
FR
NOT LISTED
A MAX
P/N : CROSS REF TABLE
BASIC SERIES
SHELL TYPE
2
A
min
STANDARD
B
REDUCING
SEAL (NOTA.3)
C
HEXAGON backshell nut
MAX
D
Tightening
torque (N.m)
E1
E2
12
29.7
66.7
5 / 12
3 / 9
24
2
15.1
22.8
14
34.6
71.5
7 / 14
5 / 12
26
2.5
18.95
26.7
Torquing screw
advised : 20 N.cm
UTSX 6 JC 14 7 P SCR
6
JC
SHELL SIZE
12
14
INSERT
ARRANGEMENT
See NOTA 2
15/09/2021
ISS
DATE
Designed by:
TITLE
Scale
3/2
1
Wire strip length = 5,8 mm
G
F
E
D
FORMAT
C
A2
for example
3
RACCORD
B
* P/N
Plug
SCREW TERMINATION
TYPE OF
CONTACTS
P: MALE
S: FEMALE
Mass column deleted
25782C
Latest modification - by:
J.GAMBIER
Date:
Q.LECOMTE
29/10/2020
CUSTOMER DRAWING
MOD N
2
PLUG T6 WITH BACKSHELL JC AND SCREW CONTACT - SIZE 12 & 14
CONNECTEUR UTSX
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
H
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
B min
MAX
5
3- This part shall be used at the place of the
standard seal to accomodate with different cable
4- Plug, backshell and the reducing seal are delivered as
a kit. The backshell already includes the standard seal.
Cable section acceptance:
0,5 mm2 to 2,5 mm2
3
HEXAGON D
(See tightening torque in table)
4
COMMON QUOTES FOR ALL VERSION
Sealing in MATED conditions with COUNTERPART:
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week: immersion under 10 m of water.
-IPx9K : exposure to high pressure water of cleaning equipement
(IEC 60529)
CAPACITY
C
CONDITIONS
7
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
Sealing conditions: SEE TABLE
5
SEALING
8
PERFORMANCE CHARACTERISTICS :
DETAIL CONTACT
SHELL
SIZE
A
MATERIAL :
E1
COUPE
B
C
D
E
F
G
H
8
B.2; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTSX-0006A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX6JC124SSCR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+302.190371+36.69207
- 10+261.8953610+31.79943
- 25+231.0883025+28.05883
