CSJ-SGFB-100-MHF4
CSJ-SGFB-100-MHF4
    LINXTECHNOLOGIES(灵思)
    同轴电缆组件 SMA 至 IPEX MHF4 0.81mm OD 外径同轴缆线 3.937"(100.00mm)
CSJ-SGFB-100-MHF4 数据手册
8 D ITEM A B C D E F DESCRIPTION MHF PLUG TYPE IV CONNECT SMA FEM. BULKHEAD CABLE, COAX, 0.81mm NUT, 1/4-36UNS THIN, GLD WASH, LOCK, .05THK HEAT SHRINK TUBING 5 6 7 4 2 3 MATERIAL FINISH BRASS GOLD BRASS GOLD COAXIAL BLACK BRASS GOLD BRASS GOLD POLYOLEFIN BLACK 1 REVISIONS REV DESCRIPTION A INITIAL RELEASE OF LINX INTERNAL DRAWING B UPDATED VISUAL AND NOTES TO CURRENT DATA. ADDED 150mm LENGTH TO TABULATION. DATE APPV 13-NOV-19 CLL JHAGER DV 3/19/2021 3/30/21 BULKHEAD DESIGN. FLANGE [C,3] 2.6mm WAS JHAGER C UPDATED 7.0mm. 4/2/2021 11.4 0.45 2.6 0.10 SEE PART NUMBER TABLE 10.2 0.4 H 8.0 0.31 C C D 8 A C F 1.7 0.06 B D E 0.5 0.02 1/4 - 36UNS - 2A THREADS B A B NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN MILLIMETERS [INCHES]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. MINIMUM FREQUENCY RANGE: DC TO 6GHz. 5. CABLE ASSEMBLY SPECIFICATIONS; - CHARACTERISTIC IMPEDANCE: 50Ω ± 3Ω 6. CONNECTOR TO BE APPLIED IN ACCORDANCE WITH CONNECTOR SUPPLIER RECOMMENDED PROCEDURE. INTERFACE IAW MIL-STD-348B 7. TORQUE SPECIFICATIONS: -BULKHEAD MOUNTING NUT TORQUE: 7 TO 10 in-lbs. -RECOMMENDED MATING TORQUE: 7 TO 10 in-lbs. 8 CONNECTORS TO BE ORIENTED WITH MHF4 CONNECTOR MATING FACE 90° CLOCKWISE FROM BULKHEAD CONNECTOR THREAD FLAT FACE, AS SHOWN. CABLE SUPPLIED WITH WASHER AND NUT INSTALLED. 9. MAX PANEL THICKNESS 6.5mm 6.5 0.26 6.0 0.24 7 6 CABLE LENGTH INSERTION LOSS CSJ-SGFB-100-MHF4 100mm ± 1.5mm 0.37√f IN GHz TYP. CSJ-SGFB-150-MHF4 150mm ± 2.0mm 0.53√f IN GHz TYP. CSJ-SGFB-200-MHF4 200mm ± 3.0mm 0.68√f IN GHz TYP. CSJ-SGFB-300-MHF4 300mm ± 3.0mm 1.00√f IN GHz TYP. WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: ©2023 TE Connectivity. All Rights Reserved. 8 PART NUMBER 5 4 TOLERANCES: 0.50 [.020]-5.00 [.200]= 0.20 [.008] 5.00 [.200]-30.00 [1.200]= 0.40 [.016] 30.0 [1.20]-120.0 [4.75]= 0.60 [0.24] 120.0 [4.75]-315.0 [12.40]= 1.0 [.040] A TITLE: CBL ASSEMBLY, MHF4 TO FEM. BLKHD SMA, 0.81mm CBL PROJECTION: ANGLES: 1 SIZE DWG. NO. REV B DRAWN: B.MURPHY DT: 5-NOV-19 CSJ-SGFB-ccc-MHF4 DT: 13-NOV-19 SCALE: 3:1 DO NOT SCALE DRAWING ENGR: S HOGAN 3 2 B SHEET 1 OF 1 1 LDCFDFB_C
CSJ-SGFB-100-MHF4 价格&库存
很抱歉,暂时无法提供与“CSJ-SGFB-100-MHF4”相匹配的价格&库存,您可以联系我们找货
