ANT-MAG-B50-SMA
ANT-MAG-B50-SMA
    LINXTECHNOLOGIES(灵思)
    ANTENNA MAGNETIC BASE 50MM RG174
ANT-MAG-B50-SMA 数据手册
ANT-MAG-B50-SMA Wide Band, Remote Mount, Magnet, SMA, Single Port ANT-MAG-B50-SMA  ACTIVE TE Internal #: ANT-MAG-B50-SMA Wide Band, Remote Mount, Magnet, SMA, Single Port View on TE.com > Antennas Mounting Location: Remote Mounting Type: Magnet Antenna Termination: SMA Band Type: Wide Band Port Configuration: Single Port Features Product Type Features Antenna Termination SMA Configuration Features Antenna Style Magnetic Mounting Location Remote Band Type Wide Band Port Configuration Single Port Electrical Characteristics Impedance 50 Ω Mechanical Attachment Mounting Type Magnet Dimensions Cable Length 4 m[13.12 ft] Product Width 50 mm[1.97 in] Product Length 50 mm[1.97 in] Product Height 37.4 mm[1.47 in] Operation/Application Antenna Environment Outdoor Product Compliance For compliance documentation, visit the product page on TE.com>  For support call+1 800 522 6752 01/02/2024 11:46PM | Page 1 ANT-MAG-B50-SMA Wide Band, Remote Mount, Magnet, SMA, Single Port Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  TE Part # ANT-ELE-S01-005 TE Part # ANT-ELE-S01-011 TE Part # CONSMA001 TE Part # CONSMA002-L-G Antenna Whip 860-960MHz MagBaseMnt Antenna Short 2.4GHz MagBase-Mnt SMA Jack 50 Ohm PCB Through Hole SMA Jack 50 Ohm PCB Through Hole For support call+1 800 522 6752 01/02/2024 11:46PM | Page 2 ANT-MAG-B50-SMA Wide Band, Remote Mount, Magnet, SMA, Single Port TE Part # CONSMA002-SMD-G TE Part # CONSMA008-G SMA Jack 50 Ohm PCB Surface Mount SMA Jack 50 Ohm Through Hole PCB Customers Also Bought TE Part #2-1415899-2 TE Part #1393240-4 TE Part #9-1415036-1 TE Part #1742456-2 RZ03-1C4-D012 RT314524 PTMT00A0 RT .265 DIA TERMINAL 10-6 AWG TPCU TE Part #ANT-315-CW-HWR-SMA TE Part #ANT-418-CW-HWR-SMA TE Part #ANT-ELE-S01-005 TE Part #ANT-ELE-S01-008 Antenna 1/2 Wave Whip Swivel 315MHz SMA Antenna 1/4 Wave Whip Swivel 418MHz SMA Antenna Whip 860-960MHz MagBaseMnt Antenna DualBand 824-960MHz MagBase-Mnt TE Part #ANT-ELE-S01-011 TE Part #ANT-MAG-B66-RPS Antenna Short 2.4GHz MagBase-Mnt Antenna Magnetic Base 66mm RG174 4M RPS Documents Product Drawings Antenna Magnetic Base 50mm RG174 4M SMA English Datasheets & Catalog Pages ANT-MAG-Bxx-xxx English VHETH Antenna Series Ground Plane Optimization English  Sub-6 Cellular LTE-5G NR Frequency Band Guide For support call+1 800 522 6752 01/02/2024 11:46PM | Page 3 ANT-MAG-B50-SMA Wide Band, Remote Mount, Magnet, SMA, Single Port Sub-6 Cellular LTE-5G NR Frequency Band Guide English Considerations for Operation within the 260-470MHz Band English Understanding Antenna Specifications and Operation English Antennas Design, Application and Performance English The FCC Road Part 15 From Concept to Approval English RF 101 Information for the RF Challenged English Virtual Antenna English Microsplatch Ground Plane Optimization English  For support call+1 800 522 6752 01/02/2024 11:46PM | Page 4
ANT-MAG-B50-SMA 价格&库存
很抱歉,暂时无法提供与“ANT-MAG-B50-SMA”相匹配的价格&库存,您可以联系我们找货
