CONN007-2-W
CONN007-2-W
    LINXTECHNOLOGIES(灵思)
    N 型 连接器 插头,公引脚 50 欧姆 自由悬挂 焊接
CONN007-2-W 数据手册
CONN007-2-W N Type RF Interface, Plug, 50 Ω, LMR 240 / Belden 9258 / RG 8X, Threaded, 11 GHz Operating Frequency, 1 Position, Wire & Cable CONN007-2-W  ACTIVE TE Internal #: CONN007-2-W N Type RF Interface, Plug, 50 Ω, LMR 240 / Belden 9258 / RG 8X, Threaded, 11 GHz Operating Frequency, 1 Position, Wire & Cable View on TE.com > Connectors > RF Connectors > Coax Connectors RF Interface: N Type RF Connector Style: Plug Impedance: 50 Ω Compatible With RF Cable Type: Belden 9258, LMR 240, RG 8X RF Connector Coupling Mechanism: Threaded Features Product Type Features Connector Product Type Connector Assembly RF Interface N Type RF Connector Style Plug Compatible With RF Cable Type Belden 9258, LMR 240, RG 8X Sealable No Connector & Contact Terminates To Wire & Cable Configuration Features Number of Positions 1 Number of Coaxial Contacts 1 Electrical Characteristics Impedance 50 Ω Body Features Cable Connector Orientation Straight Body Material Brass Body Material Finish Plated Body Plating Material White Bronze Contact Features  Ferrule Plating Material White Bronze Ferrule Material Brass For support call+1 800 522 6752 01/03/2024 12:00AM | Page 1 CONN007-2-W N Type RF Interface, Plug, 50 Ω, LMR 240 / Belden 9258 / RG 8X, Threaded, 11 GHz Operating Frequency, 1 Position, Wire & Cable Ferrule Material Brass RF Connector Center Contact Plating Material Gold RF Connector Center Contact Material Brass Termination Features Termination Method to Wire & Cable Crimp Mechanical Attachment RF Connector Coupling Mechanism Threaded Connector Mounting Type Cable Mount (Free-Hanging) RF Contact Captivation Method Mechanical Detent Without Usage Conditions Operating Temperature Range -60 – 165 °C[-76 – 329 °F] Operation/Application Operating Frequency 11 GHz Circuit Application Signal Packaging Features Packaging Quantity 250 Packaging Method Bulk Other Dielectric Material PTFE Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Not Yet Reviewed Halogen Content Not Yet Reviewed for halogen content Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge  For support call+1 800 522 6752 01/03/2024 12:00AM | Page 2 CONN007-2-W N Type RF Interface, Plug, 50 Ω, LMR 240 / Belden 9258 / RG 8X, Threaded, 11 GHz Operating Frequency, 1 Position, Wire & Cable This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # ADP-NF-NF-B-W TE Part # ADP-NM-NF-R-W TE Part # ANT-450-HSW-NP TE Part # ANT-5GW-SPNF1 N Type Jack to N Type Jack Bulkhead N Plug to N Jack RA Antenna HSW 450 IP67 N Jack Antenna 5G WB Cell Dome IP67 N Jack TE Part # L9000142-01 TE Part # ANT-W63-SPNF1 TE Part # ARR-NF-NF-B TE Part # ARR-NF-NF-B-8 Antenna 868/915 LPWA Dome IP67 N Jack Antenna WiFi6/6E Dome N Jack Arrestor Blkhd N Jack to N Jack Arrestor Hi-Freq Blkhd N Jack to N Jack TE Part # ARR-NF-NM-B TE Part # ARR-NF-NM-B-8 Arrestor Blkhd N Jack to N Plug Arrestor Hi-Freq Blkhd N Jack to N Plug Customers Also Bought  For support call+1 800 522 6752 01/03/2024 12:00AM | Page 3 CONN007-2-W N Type RF Interface, Plug, 50 Ω, LMR 240 / Belden 9258 / RG 8X, Threaded, 11 GHz Operating Frequency, 1 Position, Wire & Cable TE Part #5745781-4 TE Part #9-1609095-0 TE Part #4-1879378-1 TE Part #5767007-8 09 MSFL RCPT RA 318 (IN,FM) 3FB3=F8362 Metal Chip Resistor: Current Sense MICT,260PLUG,38,ASSY,.025,REC TE Part #1410946-1 TE Part #3-1879216-0 TE Part #1757254-1 TE Part #CSI-RGFB-200-UFFR MULTI-GIG SOC. CAP SCREW, CPF0402 120K 0.1% 25PPM 1K RL SMPM SURFACE MOUNT RP-SMA to U.FL/MHF1 200mm 1.13 CUSTOMIZED HDW OD Documents Product Drawings N Type Plug 50 Ohm Cable Crimp English Datasheets & Catalog Pages The FCC Road Part 15 From Concept to Approval English RF Coaxial Connector Gender Naming English RF 101 Information for the RF Challenged English N Plug Coaxial Cable Mount Connector English  For support call+1 800 522 6752 01/03/2024 12:00AM | Page 4
CONN007-2-W 价格&库存
很抱歉,暂时无法提供与“CONN007-2-W”相匹配的价格&库存,您可以联系我们找货
