CONSMA007-G
CONSMA007-G
    LINXTECHNOLOGIES(灵思)
    SMA 连接器 插头,公引脚 50 欧姆 自由悬挂 焊接
CONSMA007-G 数据手册
CONSMA007-G SMA RF Interface, Plug, 50 Ω, RG 188 / RG 174 / RG 316, Threaded, 18 GHz Operating Frequency, 1 Position, Wire & Cable, Cable Mount (Free-Hanging) CONSMA007-G  ACTIVE TE Internal #: CONSMA007-G SMA RF Interface, Plug, 50 Ω, RG 188 / RG 174 / RG 316, Threaded, 18 GHz Operating Frequency, 1 Position, Wire & Cable, Cable Mount (Free-Hanging) View on TE.com > Connectors > RF Connectors > Coax Connectors RF Interface: SMA RF Connector Style: Plug Impedance: 50 Ω Compatible With RF Cable Type: RG 174, RG 188, RG 316 RF Connector Coupling Mechanism: Threaded Features Product Type Features Connector Product Type Connector Assembly RF Interface SMA RF Connector Style Plug Compatible With RF Cable Type RG 174, RG 188, RG 316 Sealable No Connector & Contact Terminates To Wire & Cable Configuration Features Number of Positions 1 Number of Coaxial Contacts 1 Electrical Characteristics Impedance 50 Ω Body Features Cable Connector Orientation Straight Body Material Brass Body Material Finish Plated Body Plating Material Gold Contact Features Ferrule Plating Material  Ferrule Material For support call+1 800 522 6752 Gold Brass 01/03/2024 12:00AM | Page 1 CONSMA007-G SMA RF Interface, Plug, 50 Ω, RG 188 / RG 174 / RG 316, Threaded, 18 GHz Operating Frequency, 1 Position, Wire & Cable, Cable Mount (Free-Hanging) Ferrule Plating Material Gold Ferrule Material Brass RF Connector Center Contact Plating Material Gold RF Connector Center Contact Material Beryllium Copper Termination Features Termination Method to Wire & Cable Crimp Mechanical Attachment RF Connector Coupling Mechanism Threaded Connector Mounting Type Cable Mount (Free-Hanging) RF Contact Captivation Method Mechanical Detent Without Usage Conditions Operating Temperature Range -65 – 165 °C[-85 – 329 °F] Operation/Application Operating Frequency 18 GHz Circuit Application Signal Packaging Features Packaging Quantity 100 Packaging Method Tray Other Dielectric Material PTFE Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (4% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location.  Halogen Content For support call+1 800 522 6752 Low Bromine/Chlorine - Br and Cl < 900 01/03/2024 12:00AM | Page 2 CONSMA007-G SMA RF Interface, Plug, 50 Ω, RG 188 / RG 174 / RG 316, Threaded, 18 GHz Operating Frequency, 1 Position, Wire & Cable, Cable Mount (Free-Hanging) Halogen Content Low Bromine/Chlorine - Br and Cl < 900 ppm per homogenous material. Also BFR /CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts  TE Part # ADP-RPSM-SMAF TE Part # ADP-RPSM-SMAF-G TE Part # ADP-SMAF-BNCM TE Part # ADP-SMAF-MCXM RP-SMA Plug to SMA Jack RP-SMA Plug to SMA Jack SMA Jack to BNC Plug SMA Jack to MCX Plug TE Part # ADP-SMAF-MMXM TE Part # ADP-SMAF-NF-B-W TE Part # ADP-SMAF-NM TE Part # ADP-SMAF-SMAF SMA Jack to MMCX Plug SMA Jack to N Jack SMA Jack to N Type Plug SMA Jack to SMA Jack TE Part # ADP-SMAF-SMAF-B-G TE Part # ADP-SMAF-SMAF-F-G TE Part # ADP-SMAF-SMAF-G TE Part # L9000001-01 SMA Jack to SMA Jack Bulkhead SMA Jack to SMA Jack Flange SMA Jack to SMA Jack SMA Jack to SMA Jack Bulkhead For support call+1 800 522 6752 01/03/2024 12:00AM | Page 3 CONSMA007-G SMA RF Interface, Plug, 50 Ω, RG 188 / RG 174 / RG 316, Threaded, 18 GHz Operating Frequency, 1 Position, Wire & Cable, Cable Mount (Free-Hanging) TE Part # ADP-SMAF-SMBF-G TE Part # ADP-SMAF-SMBM-G TE Part # ADP-SMAF-SMPF-G TE Part # ADP-SMAF-SMPM-SSB SMA Jack to SMB Jack SMA Jack to SMB Plug SMA Jack to SMP Jack SMA Jack to SMP Plug Bulkhead TE Part # ADP-SMAF-TNCF-B TE Part # ADP-SMAF-UFLM TE Part # ADP-SMAM-SMAF-T-G TE Part # L9000351-01 SMA Jack to TNC Jack Bulkhead SMA Jack to U.FL/MHF1 Plug SMA Plug to SMA Jack (2) Tee Magnetic Base RPS Jack MR195 1M SMA Plug Customers Also Bought TE Part #414946-1 TE Part #213932-3 TE Part #4-1633738-3 TE Part #CONREVSMA012-R58 PLUG ASSY,STR,SMB M-SERIES KIT,V.35,34P,UNASSM CRIMPER, WIRE F RP-SMA RA Plug 50 Ohm PCB Cable Crimp TE Part #L9000266-01 TE Part #CONSMA011-G TE Part #CSD-SMAM-610-NM TE Part #1803419-6 SMA Jack 50 Ohm .062 PCB Edge Mount SMA Jack 50 Ohm Cable Crimp SMA to SMA 610mm RG58 DEPRESSOR, SHEAR TE Part #1803747-1 HOLDER, SHEAR Documents  Product Drawings For support call+1 800 522 6752 01/03/2024 12:00AM | Page 4 CONSMA007-G SMA RF Interface, Plug, 50 Ω, RG 188 / RG 174 / RG 316, Threaded, 18 GHz Operating Frequency, 1 Position, Wire & Cable, Cable Mount (Free-Hanging) Product Drawings SMA Plug 50 Ohm Cable Crimp English Datasheets & Catalog Pages Standard vs. Reverse Polarity (RP) SMA Connectors English The FCC Road Part 15 From Concept to Approval English RF Coaxial Connector Gender Naming English RF 101 Information for the RF Challenged English SMA CABLE END CRIMP FOR RD-174 CABLE English  For support call+1 800 522 6752 01/03/2024 12:00AM | Page 5
CONSMA007-G 价格&库存
很抱歉,暂时无法提供与“CONSMA007-G”相匹配的价格&库存,您可以联系我们找货
