CONSMA003.062-G
CONSMA003.062-G
    LINXTECHNOLOGIES(灵思)
    SMA 连接器 插座,母插槽 50 欧姆 板边缘,末端装入式 焊接
CONSMA003.062-G 数据手册
CONSMA003.062-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] CONSMA003.062-G  ACTIVE TE Internal #: L9000267-01 SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] View on TE.com > Connectors > RF Connectors > Coax Connectors RF Interface: SMA RF Connector Style: Jack Impedance: 50 Ω RF Connector Coupling Mechanism: Threaded Operating Frequency: 0 – 18 GHz Features Product Type Features Connector Product Type Connector Assembly RF Interface SMA RF Connector Style Jack Sealable No Connector & Contact Terminates To Printed Circuit Board Configuration Features PCB Mount Orientation Edge Number of Positions 1 Number of Coaxial Contacts 1 Electrical Characteristics Impedance 50 Ω Body Features Cable Connector Orientation Straight Body Material Brass Body Material Finish Plated Body Plating Material Gold Contact Features RF Connector Center Contact Plating Material  RF800 Connector For support call+1 522 6752 Center Contact Material Gold Beryllium Copper 01/03/2024 12:25AM | Page 1 CONSMA003.062-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] RF Connector Center Contact Plating Material Gold RF Connector Center Contact Material Beryllium Copper Termination Features Termination Method to Wire & Cable Solder Mechanical Attachment RF Connector Coupling Mechanism Threaded Connector Mounting Type Board Mount RF Contact Captivation Method Mechanical Detent Without Usage Conditions Operating Temperature Range -65 – 165 °C[-85 – 329 °F] Operation/Application Operating Frequency 0 – 18 GHz Circuit Application Signal Packaging Features Packaging Quantity 100 Packaging Method Tray Other Dielectric Material PTFE Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Not Yet Reviewed China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer  For support call+1 800 522 6752 01/03/2024 12:25AM | Page 2 CONSMA003.062-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked.Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulations, TE’s information on SVHC in articles for this part number is still based on the European Chemical Agency (ECHA) ‘Guidance on requirements for substances in articles’(Version: 2, April 2011), applying the 0.1% weight on weight concentration threshold at the finished product level. TE is aware of the European Court of Justice ruling of September 10th, 2015 also known as O5A (Once An Article Always An Article) stating that, in case of ‘complex object’, the threshold for a SVHC must be applied to both the product as a whole and simultaneously to each of the articles forming part of its composition. TE has evaluated this ruling based on the new ECHA “Guidance on requirements for substances in articles” (June 2017, version 4.0) and will be updating its statements accordingly. Compatible Parts TE Part # L9000274-01 SMA Plug 50 Ohm .031 PCB Edge Mount Customers Also Bought  TE Part #1462052-6 TE Part #1-796640-0 TE Part #794228-1 TE Part #1532187-2 HF6 56=50OHM140MW12V MONO 10 POS 5.0 MM R/A PLUG,TRM BLK MINI UMNL2 PIN 22-18 AWG SN LP M83513/02-AC, MCKS-C2-B-9SS TE Part #1532188-2 TE Part #9-2176304-9 TE Part #1-2176305-1 TE Part #7-2176304-7 M83513/02-BC, MCKS-C2-B-15SS RP 1E 0.1W 105R 0.1% 25PPM 5K RL RP 1E 0.1W 137R 0.1% 25PPM 5K RL RP 1E 0.1W 61R9 0.1% 25PPM 5K RL For support call+1 800 522 6752 01/03/2024 12:25AM | Page 3 CONSMA003.062-G SMA RF Interface, Jack, 50 Ω, Threaded, 0 – 18 GHz Operating Frequency, 1 Position, Printed Circuit Board, Board Mount, -65 – 165 °C [-85 – 329 °F] TE Part #8-2176304-3 TE Part #YDTS20W11-02PNV001 RP 1E 0.1W 71R5 0.1% 25PPM 5K RL RECP ASSY Documents Product Drawings SMA Jack 50 Ohm .062 PCB Edge Mount gold English Datasheets & Catalog Pages SMA FEMALE EDGE MOUNT FOR 0.062 INCH THICK BOARD English  For support call+1 800 522 6752 01/03/2024 12:25AM | Page 4
CONSMA003.062-G 价格&库存
很抱歉,暂时无法提供与“CONSMA003.062-G”相匹配的价格&库存,您可以联系我们找货
