CY54FCT541T, CY74FCT541T
8-BIT BUFFERS/LINE DRIVERS
WITH 3-STATE OUTPUTS
SCCS072 – OCTOBER 2001
D
D
D
D
D
D
D
OEA
D0
D1
D2
D3
D4
D5
D6
D7
GND
1
19
3
18
4
17
5
16
6
15
7
14
8
13
9
12
10
11
VCC
OEB
O0
O1
O2
O3
O4
O5
O6
O7
CY54FCT541T . . . L PACKAGE
(TOP VIEW)
D2
D3
D4
D5
D6
4
3 2 1 20 19
18
5
17
6
16
7
15
8
14
9 10 11 12 13
O0
O1
O2
O3
O4
D7
GND
O7
O6
O5
description
OEB
D
CY54FCT541T . . . D PACKAGE
CY74FCT541T . . . P, Q, OR SO PACKAGE
(TOP VIEW)
OEA
VCC
D
Function, Pinout, and Drive Compatible
With FCT and F Logic
Reduced VOH (Typically = 3.3 V) Versions
of Equivalent FCT Functions
Edge-Rate Control Circuitry for
Significantly Improved Noise
Characteristics
Ioff Supports Partial-Power-Down Mode
Operation
ESD Protection Exceeds JESD 22
– 2000-V Human-Body Model (A114-A)
– 200-V Machine Model (A115-A)
– 1000-V Charged-Device Model (C101)
Matched Rise and Fall Times
Fully Compatible With TTL Input and
Output Logic Levels
CY54FCT541T
– 48-mA Output Sink Current
– 12-mA Output Source Current
CY74FCT541T
– 64-mA Output Sink Current
– 32-mA Output Source Current
3-State Outputs
D1
D0
D
The ’FCT541T noninverting buffers/line drivers
can be employed as memory address drivers,
clock drivers, and bus-oriented transmitters/receivers. These devices provide speed and drive capabilities
equivalent to their fastest bipolar-logic counterparts, while reducing power dissipation. The input and output
voltage levels allow direct interface with TTL, NMOS, and CMOS devices without external components.
These devices are fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the
outputs, preventing damaging current backflow through the device when it is powered down.
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of
Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
Copyright 2001, Texas Instruments Incorporated
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of Texas Instruments
standard warranty. Production processing does not necessarily include
testing of all parameters.
On products compliant to MIL-PRF-38535, all parameters are tested
unless otherwise noted. On all other products, production
processing does not necessarily include testing of all parameters.
POST OFFICE BOX 655303
• DALLAS, TEXAS 75265
1
ORDERING INFORMATION
QSOP – Q
TOP-SIDE
MARKING
4.1
CY74FCT541CTQCT
Tube
4.1
CY74FCT541CTSOC
Tape and reel
4.1
CY74FCT541CTSOCT
DIP – P
Tube
4.8
CY74FCT541ATPC
CY74FCT541ATPC
QSOP – Q
Tape and reel
4.8
CY74FCT541ATQCT
FCT541A
Tube
4.8
CY74FCT541ATSOC
Tape and reel
4.8
CY74FCT541ATSOCT
SOIC – SO
SOIC – SO
–55°C to 125°C
ORDERABLE
PART NUMBER
Tape and reel
SOIC – SO
–40°C to 85°C
SPEED
(ns)
PACKAGE†
TA
Tube
8
CY74FCT541TSOC
Tape and reel
8
CY74FCT541TSOCT
CY54FCT541CTDMB
CDIP – D
Tube
4.6
CDIP – D
Tube
8
LCC – L
Tube
8
FCT541C
FCT541C
FCT541A
FCT541
CY54FCT541TDMB
CY54FCT541TLMB
† Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available
at www.ti.com/sc/package.
FUNCTION TABLE
INPUTS
D
OUTPUT
O
OEA
OEB
L
L
L
L
L
L
H
H
H
H
X
Z
H = High logic level, L = Low logic level,
X = Don’t care, Z = High-impedance state
logic diagram (positive logic)
OEA
OEB
D0
1
19
2
18
To Seven Other Channels
2
O0
absolute maximum rating over operating free-air temperature range (unless otherwise noted)†
Supply voltage range to ground potential . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 7 V
DC input voltage range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 7 V
DC output voltage range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 7 V
DC output current (maximum sink current/pin) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 120 mA
Package thermal impedance, θJA (see Note 1): P package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69°C/W
Q package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 68°C/W
SO package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 58°C/W
Ambient temperature range with power applied, TA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 135°C
Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C
† Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and
functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied.
Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
NOTE 1: The package thermal impedance is calculated in accordance with JESD 51-7.
recommended operating conditions (see Note 2)
CY54FCT541T
CY74FCT541T
MIN
NOM
MAX
MIN
NOM
MAX
4.5
5
5.5
4.75
5
5.25
UNIT
VCC
VIH
Supply voltage
VIL
IOH
Low-level input voltage
0.8
0.8
V
High-level output current
–12
–32
mA
IOL
TA
Low-level output current
48
64
mA
85
°C
High-level input voltage
2
Operating free-air temperature
–55
2
125
–40
V
V
NOTE 2: All unused inputs of the device must be held at VCC or GND to ensure proper device operation.
3
electrical characteristics over recommended operating free-air temperature range (unless
otherwise noted)
PARAMETER
VIK
VOH
CY54FCT541T
TYP† MAX
TEST CONDITIONS
VCC = 4.5, V
VCC = 4.75 V,
IIN = –18 mA
IIN = –18 mA
VCC =4.5 V,
IOH = –12 mA
IOH = –32 mA
VCC = 4
4.75
75 V
MIN
–0.7
–1.2
–0.7
2.4
2.4
Vhys
All inputs
II
VCC = 5.5 V,
VCC = 5.25 V,
VIN = VCC
VIN = VCC
5
IIH
VCC = 5.5 V,
VCC = 5.25 V,
VIN = 2.7 V
VIN = 2.7 V
±1
IIL
VCC = 5.5 V,
VCC = 5.25 V,
VIN = 0.5 V
VIN = 0.5 V
±1
IOZH
VCC = 5.5 V,
VCC = 5.25 V,
VOUT = 2.7 V
VOUT = 2.7 V
10
IOZL
VCC = 5.5 V,
VCC = 5.25 V,
VOUT = 0.5 V
VOUT = 0.5 V
–10
IOS‡
VCC = 5.5 V,
VCC = 5.25 V,
VOUT = 0 V
VOUT = 0 V
VCC = 0 V,
VCC = 5.5 V,
VOUT = 4.5 V
VIN ≤ 0.2 V,
∆ICC
0.3
0.3
0.2
0.55
0.2
±1
±1
10
–10
–120
–225
–60
–120
±1
VIN ≥ VCC – 0.2 V
VIN ≥ VCC – 0.2 V
0.1
0.5
V
V
5
VIN ≤ 0.2 V,
VCC = 5.5 V, VIN = 3.4 V§, f1 = 0, Outputs open
VCC = 5.25 V,
3.3
0.55
IOL = 64 mA
–60
V
V
2
IOH = –15 mA
IOL = 48 mA
VCC = 4.5 V,
VCC = 4.75 V,
ICC
–1.2
UNIT
3.3
VOL
Ioff
CY74FCT541T
TYP† MAX
MIN
–225
±1
0.2
0.1
0.2
0.5
2
µA
µA
µA
µA
µA
mA
µA
mA
2
mA
VCC = 5.25 V, VIN = 3.4 V§, f1 = 0, Outputs open
VCC = 5.5 V, 50% duty cycle, Outputs open,
One bit switching at f1 = 10 MHz,
0.06
0.12
OEA = OEB = GND or OEA = GND and OEB = VCC,
VIN ≤ 0.2 V or VIN ≥ VCC – 0.2 V
mA/
ICCD¶
MHz
VCC = 5.25 V, 50% duty cycle, Outputs open,
0.06
0.12
† Typical values are at VCC = 5 V, TA = 25°C.
‡ Not more than one output should be shorted at a time. Duration of short should not exceed one second. The use of high-speed test apparatus and/or
sample-and-hold techniques are preferable to minimize internal chip heating and more accurately reflect operational values. Otherwise, prolonged
shorting of a high output can raise the chip temperature well above normal and cause invalid readings in other parametric tests. In any sequence
of parameter tests, IOS tests should be performed last.
§ Per TTL-driven input (VIN = 3.4 V); all other inputs at VCC or GND
¶ This parameter is derived for use in total power-supply calculations.
4
otherwise noted) (continued)
PARAMETER
CY54FCT541T
TYP† MAX
TEST CONDITIONS
VCC = 5.5 V,
Outputs
Out
uts o
open
en,
OEA = OEB =
GND or
OEA = GND and
OEB = VCC
One bit switching
at f1 = 10 MHz
at 50% duty cycle
VCC = 5.25 V,
Out
uts o
en,
Outputs
open
OEA = OEB =
GND or
OEA = GND and
OEB = VCC
One bit switching
at f1 = 10 MHz
at 50% duty cycle
IC#
Eight bits switching
at f1 = 2.5 MHz
at 50% duty cycle
MIN
VIN ≤ 0.2 V or
VIN ≥ VCC – 0.2 V
VIN = 3.4 V or GND
VIN ≤ 0.2 V or
VIN ≥ VCC – 0.2 V
VIN = 3.4 V or GND
VIN ≤ 0.2 V or
VIN ≥ VCC – 0.2 V
0.7
1.4
1
2.4
1.3
2.6||
3.3
10.6||
CY74FCT541T
TYP† MAX
MIN
UNIT
mA
0.7
1.4
1
2.4
1.3
2.6||
3.3
10.6||
Ci
5
10
pF
Co
9
12
pF
at f1 = 2.5 MHz
at 50% duty cycle
VIN = 3.4 V or GND
VIN ≤ 0.2 V or
VIN ≥ VCC – 0.2 V
VIN = 3.4 V or GND
# IC
= ICC + ∆ICC × DH × NT + ICCD (f0/2 + f1 × N1)
Where:
IC
= Total supply current
ICC = Power-supply current with CMOS input levels
∆ICC = Power-supply current for a TTL high input (VIN = 3.4 V)
DH
= Duty cycle for TTL inputs high
NT
= Number of TTL inputs at DH
ICCD = Dynamic current caused by an input transition pair (HLH or LHL)
f0
= Clock frequency for registered devices, otherwise zero
f1
= Input signal frequency
N1
= Number of inputs changing at f1
All currents are in milliamperes and all frequencies are in megahertz.
|| Values for these conditions are examples of the ICC formula.
5
switching characteristics over operating free-air temperature range (see Figure 1)
PARAMETER
FROM
(INPUT)
TO
(OUTPUT)
tPLH
tPHL
D
O
tPZH
tPZL
OE
O
tPHZ
tPLZ
OE
O
CY54FCT541T
CY54FCT541CT
MIN
MAX
MIN
MAX
1.5
8
1.5
4.6
1.5
8
1.5
4.6
1.5
10.5
1.5
6.5
1.5
10.5
1.5
6.5
1.5
10
1.5
5.7
1.5
10
1.5
5.7
UNIT
ns
ns
ns
6
PARAMETER
FROM
(INPUT)
TO
(OUTPUT)
tPLH
tPHL
D
O
tPZH
tPZL
OE
O
tPHZ
tPLZ
OE
O
CY74FCT541T
CY74FCT541AT
CY74FCT541CT
MIN
MAX
MIN
MAX
MIN
MAX
1.5
8
1.5
4.8
1.5
4.1
1.5
8
1.5
4.8
1.5
4.1
1.5
10
1.5
6.2
1.5
5.8
1.5
10
1.5
6.2
1.5
5.8
1.5
9.5
1.5
5.6
1.5
5.2
1.5
9.5
1.5
5.6
1.5
5.2
UNIT
ns
ns
ns
PARAMETER MEASUREMENT INFORMATION
7V
From Output
Under Test
From Output
Under Test
Test
Point
CL = 50 pF
(see Note A)
Open
TEST
GND
CL = 50 pF
(see Note A)
500 Ω
S1
500 Ω
S1
Open
7V
Open
tPLH/tPHL
tPLZ/tPZL
tPHZ/tPZH
500 Ω
LOAD CIRCUIT FOR
3-STATE OUTPUTS
LOAD CIRCUIT FOR
TOTEM-POLE OUTPUTS
3V
1.5 V
Timing Input
0V
tw
tsu
3V
1.5 V
Input
1.5 V
th
3V
1.5 V
Data Input
1.5 V
0V
0V
VOLTAGE WAVEFORMS
PULSE DURATION
VOLTAGE WAVEFORMS
SETUP AND HOLD TIMES
3V
1.5 V
Input
1.5 V
0V
tPLH
tPHL
1.5 V
1.5 V
VOL
tPHL
Out-of-Phase
Output
tPLZ
≈3.5 V
1.5 V
tPZH
VOH
1.5 V
VOL
VOLTAGE WAVEFORMS
PROPAGATION DELAY TIMES
INVERTING AND NONINVERTING OUTPUTS
1.5 V
0V
Output
Waveform 1
(see Note B)
tPLH
1.5 V
1.5 V
tPZL
VOH
In-Phase
Output
3V
Output
Control
Output
Waveform 2
(see Note B)
VOL + 0.3 V
VOL
tPHZ
1.5 V
VOH – 0.3 V
VOH
≈0 V
VOLTAGE WAVEFORMS
ENABLE AND DISABLE TIMES
LOW- AND HIGH-LEVEL ENABLING
NOTES: A. CL includes probe and jig capacitance.
B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control.
Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control.
C. The outputs are measured one at a time with one input transition per measurement.
Figure 1. Load Circuit and Voltage Waveforms
7
PACKAGE OPTION ADDENDUM
www.ti.com
18-Nov-2023
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
Samples
(4/5)
(6)
5962-9223701M2A
ACTIVE
LCCC
FK
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
59629223701M2A
CY54FCT
541TLMB
5962-9223701MRA
ACTIVE
CDIP
J
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
5962-9223701MR
A
CY54FCT541TDMB
5962-9223705MRA
ACTIVE
CDIP
J
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
5962-9223705MR
A
CY54FCT541TDMB
ACTIVE
CDIP
J
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
5962-9223701MR
A
CY54FCT541TDMB
CY54FCT541TLMB
ACTIVE
LCCC
FK
Non-RoHS
& Green
SNPB
N / A for Pkg Type
-55 to 125
59629223701M2A
CY54FCT
541TLMB
CY74FCT541ATPC
ACTIVE
PDIP
N
RoHS &
Non-Green
NIPDAU
N / A for Pkg Type
-40 to 85
CY74FCT541ATPC
Samples
CY74FCT541ATQCT
ACTIVE
SSOP
DBQ
RoHS & Green
NIPDAU
Level-2-260C-1 YEAR
-40 to 85
FCT541A
Samples
CY74FCT541ATSOC
ACTIVE
SOIC
DW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
FCT541A
Samples
CY74FCT541ATSOCT
ACTIVE
SOIC
DW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
FCT541A
Samples
CY74FCT541CTQCT
ACTIVE
SSOP
DBQ
RoHS & Green
NIPDAU
Level-2-260C-1 YEAR
-40 to 85
FCT541C
Samples
CY74FCT541CTSOC
ACTIVE
SOIC
DW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
FCT541C
Samples
CY74FCT541CTSOCT
ACTIVE
SOIC
DW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
FCT541C
Samples
CY74FCT541TQCT
ACTIVE
SSOP
DBQ
RoHS & Green
NIPDAU
Level-2-260C-1 YEAR
-40 to 85
FCT541
Samples
CY74FCT541TSOC
ACTIVE
SOIC
DW
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
FCT541
Samples
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
Addendum-Page 1
Samples
Samples
Samples
Samples
Samples
www.ti.com
18-Nov-2023
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
