ADS5440
www.ti.com
SLAS467A – JULY 2005 – REVISED DECEMBER 2005
13-BIT 210 MSPS ANALOG-TO-DIGITAL CONVERTER
FEATURES
APPLICATIONS
13-Bit Resolution
210 MSPS Sample Rate
SNR = 69 dBc at 100-MHz IF and 210 MSPS
SFDR = 76 dBc at 100-MHz IF and 210 MSPS
SNR = 68.1 dBc at 230-MHz IF and 210 MSPS
SFDR = 74 dBc at 230-MHz IF and 210 MSPS
2.2 VPP Differential Input Voltage
Fully Buffered Analog Inputs
5 V Analog Supply Voltage
LVDS Compatible Outputs
Total Power Dissipation: 2 W
Offset Binary Output Format
TQFP-80 PowerPAD™ Package
Pin Compatible with the ADS5444
Industrial Temperature Range = –40°C to 85°C
Test and Measurement
Software-Defined Radio
Multi-channel Basestation Receivers
Basestation Tx Digital Predistortion
Communications Instrumentation
RELATED PRODUCTS
ADS5424 - 14-bit, 105 MSPS ADC
ADS5423 - 14-bit, 80 MSPS ADC
ADS5444 - 13-bit, 250 MSPS ADC
DESCRIPTION
The ADS5440 is a 13-bit 210 MSPS analog-to-digital converter (ADC) that operates from a 5 V supply, while
providing LVDS-compatible digital outputs from a 3.3 V supply. The ADS5440 input buffer isolates the internal
switching of the onboard track and hold (T&H) from disturbing the signal source. An internal reference generator
is also provided to further simplify the system design. The ADS5440 has outstanding low noise and linearity over
input frequency.
AVDD
AIN
AIN
A1
TH1
TH2
Σ
A2
TH3
ADC1
DAC1
Reference
A3
ADC3
VREF
Σ
DVDD
ADC2
5
DAC2
5
5
Digital Error Correction
CLK
CLK
Timing
OVR
OVR
DRY
DRY
D[12:0]
GND
B0061-01
The ADS5440 is available in an 80-pin TQFP PowerPAD™ package. The ADS5440 is built on a state of the art
Texas Instruments complementary bipolar process (BiCom3X) and is specified over the full industrial
temperature range (–40°C to 85°C).
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas
Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
PowerPAD is a trademark of Texas Instruments.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 2005, Texas Instruments Incorporated
ADS5440
www.ti.com
This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with
appropriate precautions. Failure to observe proper handling and installation procedures can cause damage.
ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more
susceptible to damage because very small parametric changes could cause the device not to meet its published specifications.
PACKAGING/ORDERING INFORMATION (1)
Product
ADS5440
(1)
(2)
PackageLead
Package
Designator
HTQFP-80 (2)
PowerPAD
(1)
PFP
Specified
Temperature
Range
Package
Marking
–40°C to 85°C
ADS5440IPFP
Ordering
Number
Transport
Media,
Quantity
ADS5440IPFP
Tray, 96
ADS5440IPFPR
Tape and Reel, 1000
For the most current product and ordering information, see the Package Option Addendum located at the end of this data sheet.
Thermal pad size: 7,5 mm x 7,5 mm (typ)
ABSOLUTE MAXIMUM RATINGS
over operating free-air temperature range (unless otherwise noted) (1)
VALUE / UNIT
Supply voltage
AVDD to GND
6V
DRVDD to GND
5V
Analog input to GND
–0.3 V to AVDD+0.3 V
Clock input to GND
CLK to CLK
±2.5 V
Digital data output to GND
–0.3 V to DRVDD+0.3 V
Operating temperature range
–40°C to 85°C
Maximum junction temperature
150°C
Storage temperature range
–65°C to 150°C
ESD Human Body Model (HBM)
(1)
2.5 kV
Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may
degrade device reliability. These are stress ratings only and functional operation of the device at these or any other conditions beyond
those specified is not implied.
THERMAL CHARACTERISTICS (1)
PARAMETER
θJA
θJC
(1)
2
TYP
UNIT
Soldered slug, no airflow
TEST CONDITIONS
21.7
°C/W
Soldered slug, 250-LFPM airflow
15.4
°C/W
50
°C/W
Unsoldered slug, 250-LFPM airflow
43.4
°C/W
Bottom of package (heatslug)
2.99
°C/W
Unsoldered slug, no airflow
Using 36 thermal vias (6 x 6 array). See the Application Section.
Submit Documentation Feedback
ADS5440
www.ti.com
RECOMMENDED OPERATING CONDITIONS
MIN
NOM
MAX
UNIT
4.75
5
5.25
V
3
3.3
3.6
V
SUPPLIES
AVDD
Analog supply voltage
DRVDD
Output driver supply voltage
ANALOG INPUT
VCM
Differential input range
2.2
VPP
Input common mode
2.4
V
CLOCK INPUT
1/tC
ADCLK input sample rate (sine wave)
10
210
Clock amplitude, differential sine wave
Clock duty cycle
TA
MSPS
3
Vpp
50%
Open free air temperature
–40
85
°C
ELECTRICAL CHARACTERISTICS
MIN, TYP, and MAX values at TA = 25°C, full temperature range is TMIN = –40°C to TMAX = 85°C, sampling rate = 210 MSPS,
50% clock duty cycle, AVDD = 5 V, DRVDD = 3.3 V, –1 dBFS differential input, and 3 VPP differential clock, unless otherwise
noted
PARAMETER
TEST CONDITIONS
MIN
Resolution
TYP
MAX
UNIT
13
Bits
2.2
Vpp
1
kΩ
ANALOG INPUTS
Differential input resistance (DC)
Differential input capacitance
1.5
pF
Analog input bandwidth
800
MHz
2.4
V
INTERNAL REFERENCE VOLTAGE
VREF
Reference voltage
DYNAMIC ACCURACY
No missing codes
Assured
DNL
Differential linearity error
fIN = 10 MHz
-1
±0.4
1
LSB
INL
Integral linearity error
fIN = 10 MHz
-2.2
±0.9
2.2
LSB
Offset error
-11
Offset temperature coefficient
0.0005
Gain error
–5
Gain temperature coefficient
PSRR
11
100-MHz supply
frequency
mV
mV/°C
5
%FS
-0.02
∆%/°C
1
mV/V
POWER SUPPLY
IAVDD
Analog supply current
IDRVDD
Output buffer supply current
VIN = full scale, fIN = 100 MHz, FS = 210 MSPS
Power dissipation
340
390
mA
80
100
mA
2
2.28
W
3
ADS5440
www.ti.com
ELECTRICAL CHARACTERISTICS (continued)
noted
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
DYNAMIC AC CHARACTERISTICS
fIN = 10 MHz
69.8
fIN = 70 MHz
69.2
fIN = 100 MHz
SNR
Signal-to-noise ratio
TA = 25°C
Full Temp Range
67.5
67
fIN = 170 MHz
fIN = 230 MHz
68
fIN = 300 MHz
66.9
fIN = 400 MHz
65
fIN = 10 MHz
84
fIN = 100 MHz
HD2
HD3
Spurious free dynamic range
Second harmonic
Third harmonic
Worst other harmonic/spur (other than
HD2 and HD3)
4
69
68.3
fIN = 70 MHz
SFDR
69
dBc
77
TA = 25°C
70
76
Full Temp Range
68
76
fIN = 170 MHz
74
fIN = 230 MHz
74
fIN = 300 MHz
69
fIN = 400 MHz
64
fIN = 10 MHz
96
fIN = 70 MHz
83
fIN = 100 MHz
87
fIN = 170 MHz
76
fIN = 230 MHz
76
fIN = 300 MHz
69
fIN = 400 MHz
64
fIN = 10 MHz
84
fIN = 70 MHz
77
fIN = 100 MHz
76
fIN = 170 MHz
74
fIN = 230 MHz
74
fIN = 300 MHz
73
fIN = 400 MHz
70
fIN = 10 MHz
92
fIN = 70 MHz
92
fIN = 100 MHz
87
fIN = 170 MHz
87
fIN = 230 MHz
83
fIN = 300 MHz
83
fIN = 400 MHz
80
dBc
dBc
dBc
dBc
ADS5440
www.ti.com
noted
PARAMETER
SINAD
TEST CONDITIONS
MIN
fIN = 10 MHz
69.6
fIN = 70 MHz
68.8
fIN = 100 MHz
68
fIN = 170 MHz
66.8
fIN = 230 MHz
66
fIN = 300 MHz
64
fIN = 400 MHz
ENOB
TYP
Effective number of bits
fIN = 10 MHz
RMS idle channel noise
Inputs tied to common-mode
MAX
UNIT
dBc
60
11.4
Bits
0.4
LSB
DIGITAL CHARACTERISTICS – LVDS DIGITAL OUTPUTS
Differential output voltage
0.247
Output offset voltage
1.125
1.25
0.452
V
1.375
V
5
ADS5440
www.ti.com
TIMING CHARACTERISTICS
tA
N+3
N
AIN
N+1
N+2
tCLK
CLK, CLK
tCLKH
N+1
N
N+4
tCLKL
N+2
N+3
N+4
tC_DR
D[12:0],
OVR, OVR
N−3
tr
N−2
tf
tsu_c
N−1
th_c
N
th_DR
tsu_DR
DRY, DRY
tDR
T0073-01
Figure 1. Timing Diagram
Min, Typ, Max over full temperature range, 50% clock duty cycle, sampling rate = 210 MSPS, AVDD = 5 V, DRVDD = 3.3 V
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
tA
Aperature delay
500
ps
tJ
Clock slope independent aperture uncertainty (jitter)
150
fs RMS
4
cycles
Latency
Clock Input
tCLK
Clock period
4.76
ns
tCLKH
Clock pulsewidth high
2.38
ns
tCLKL
Clock pulsewidth low
2.38
ns
Clock to DataReady (DRY)
tDR
Clock rising to DataReady falling
tC_DR
Clock rising to DataReady rising
1.1
Clock duty cycle = 50%
(1)
3.1
3.5
ns
3.9
ns
Clock to DATA, OVR (2)
tr
Data rise time (20% to 80%)
0.6
ns
tf
Data fall time(80% to 20%)
0.6
ns
tsu_c
Data valid to clock (setup time)
3.5
ns
th_c
Clock to invalid Data (hold time)
0.2
ns
DataReady (DRY)/DATA, OVR (2)
tsu(DR)
Data valid to DRY
2.1
2.4
ns
th(DR)
DRY to invalid Data
0.9
1.3
ns
(1)
(2)
6
tC_DR = tDR + tCLKH for clock duty cycles other than 50%
Data is updated with clock falling edge or DRY rising edge.
ADS5440
www.ti.com
DEVICE INFORMATION
PFP PACKAGE
(TOP VIEW)
D5
D5
D6
D6
GND
DVDD
D7
D7
D8
D8
D9
D9
D10
D10
D11
D11
D12
D12
DRY
DRY
61
39
60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41
40
1 2 3
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
4 5
6
GND
38
37
36
35
34
33
32
31
30
29
28
27
26
25
24
23
22
21
7 8 9 10 11 12 13 14 15 16 17 18 19 20
DVDD
GND
AVDD
NC
NC
VREF
GND
AVDD
GND
CLK
CLK
GND
AVDD
AVDD
GND
AIN
AIN
GND
AVDD
GND
D4
D4
D3
D3
D2
D2
D1
D1
GND
DVDD
D0
D0
NC
NC
NC
NC
NC
NC
OVR
OVR
GND
AVDD
GND
AVDD
GND
AVDD
GND
NC
GND
AVDD
GND
NC
GND
AVDD
GND
AVDD
GND
AVDD
GND
AVDD
P0027-01
TERMINAL FUNCTIONS
TERMINAL
NAME
AVDD
DVDD
GND
NO.
DESCRIPTION
3, 8, 13, 14, 19, 21,
23, 25, 27, 31, 35, 37, Analog power supply
39
1, 51, 66
Output driver power supply
2, 7, 9, 12, 15, 18, 20,
22, 24, 26, 28, 30, 32, Ground
34, 36, 38, 40, 52, 65
VREF
6
Reference voltage
CLK
10
Differential input clock (positive). Conversion initiated on rising edge
CLK
11
Differential input clock (negative)
AIN
16
Differential input signal (positive)
AIN
17
Differential input signal (negative)
7
ADS5440
www.ti.com
DEVICE INFORMATION (continued)
TERMINAL FUNCTIONS (continued)
TERMINAL
NAME
NO.
DESCRIPTION
OVR, OVR
42, 41
Over range indicator LVDS output. A logic high signals an analog input in excess of the
full-scale range.
D0, D0
50, 49
LVDS digital output pair, least-significant bit (LSB)
D1–D6, D1–D6
53–64
LVDS digital output pairs
D7–D11, D7–D11
67–76
D12, D12
78, 77
LVDS digital output pair, most-significant bit (MSB)
DRY, DRY
80, 79
Data ready LVDS output pair
NC
4, 5, 29, 33, 43–48
No connect
DEFINITION OF SPECIFICATIONS
Analog Bandwidth The analog input frequency at which the power of the fundamental is reduced by 3 dB with respect to the
low frequency value.
Aperture Delay The delay in time between the rising edge of the input sampling clock and the actual time at which the
sampling occurs.
Aperture Uncertainty (Jitter) The sample-to-sample variation in aperture delay.
Clock Pulse Width/Duty Cycle The duty cycle of a clock signal is the ratio of the time the clock signal remains at a logic
high (clock pulse width) to the period of the clock signal. Duty cycle is typically expressed as a percentage. A
perfect differential sine wave clock results in a 50% duty cycle.
Maximum Conversion Rate The maximum sampling rate at which certified operation is given. All parametric testing is
performed at this sampling rate unless otherwise noted.
Minimum Conversion Rate The minimum sampling rate at which the ADC functions.
Differential Nonlinearity (DNL) An ideal ADC exhibits code transitions at analog input values spaced exactly 1 LSB apart.
The DNL is the deviation of any single step from this ideal value, measured in units of LSB.
Integral Nonlinearity (INL) The INL is the deviation of the ADCs transfer function from a best fit line determined by a least
squares curve fit of that transfer function. The INL at each analog input value is the difference between the
actual transfer function and this best fit line, measured in units of LSB.
Gain Error
The gain error is the deviation of the ADCs actual input full-scale range from its ideal value. The gain error is
given as a percentage of the ideal input full-scale range.
Offset Error
Offset error is the deviation of output code from mid-code when both inputs are tied to common-mode.
Temperature Drift Temperature drift (with respect to gain error and offset error) specifies the change from the value at the
nominal temperature to the value at TMIN or TMAX. It is computed as the maximum variation the parameters
over the whole temperature range divided by TMIN– TMAX.
Signal-to-Noise Ratio (SNR) SNR is the ratio of the power of the fundamental (PS) to the noise floor power (PN), excluding
the power at dc and the first five harmonics.
P
SNR 10log
S
10 P
N
(1)
SNR is either given in units of dBc (dB to carrier) when the absolute power of the fundamental is used as the
reference, or dBFS (dB to full scale) when the power of the fundamental is extrapolated to the converter’s
full-scale range.
Signal-to-Noise and Distortion (SINAD) SINAD is the ratio of the power of the fundamental (PS) to the power of all the other
spectral components including noise (PN) and distortion (PD), but excluding dc.
P
SINAD 10log
S
10 P P
N
D
(2)
SINAD is either given in units of dBc (dB to carrier) when the absolute power of the fundamental is used as the
full-scale range.
8
ADS5440
www.ti.com
DEFINITION OF SPECIFICATIONS (continued)
Effective Resolution Bandwidth The highest input frequency where the SNR (dB) is dropped by 3 dB for a full-scale input
amplitude.
Total Harmonic Distortion (THD) THD is the ratio of the power of the fundamental (PS) to the power of the first five
harmonics (PD).
THD 10log
P
S
10 P
D
(3)
THD is typically given in units of dBc (dB to carrier).
Two-Tone Intermodulation Distortion IMD3 is the ratio of the power of the fundamental (at frequencies f1, f2) to the power
of the worst spectral component at either frequency 2f1– f2 or 2f2– f1). IMD3 is either given in units of dBc (dB
to carrier) when the absolute power of the fundamental is used as the reference or dBFS (dB to full scale)
when the power of the fundamental is extrapolated to the converter’s full-scale range.
9
ADS5440
www.ti.com
TYPICAL CHARACTERISTICS
Spectral Performance
(FFT For 10-MHz Input Signal)
(FFT For 100-MHz Input Signal)
SFDR = 83 dBc
SNR = 69.9 dBc
THD = 81.4 dBc
SINAD = 69.6 dBc
−20
−40
Amplitude − dB
Amplitude − dB
−20
SFDR = 76 dBc
SNR = 69 dBc
THD = 74.8 dBc
SINAD = 67.9 dBc
−60
−80
−100
−40
−60
−80
−100
−120
−120
40
50
60
70
80
90 100
f − Frequency − MHz
30
40
50
60
70
80
90 100
f − Frequency − MHz
G001
G002
Figure 2.
Figure 3.
(FFT For 170-MHz Input Signal)
(FFT For 230-MHz Input Signal)
SFDR = 74 dBc
SNR = 68.3 dBc
THD = 71.5 dBc
SINAD = 66.8 dBc
−20
−40
Amplitude − dB
Amplitude − dB
−20
SFDR = 74 dBc
SNR = 67.9 dBc
THD = 70.3 dBc
SINAD = 65.9 dBc
−60
−80
−100
−40
−60
−80
−100
−120
−120
40
50
60
70
80
90 100
f − Frequency − MHz
40
50
60
G003
Figure 4.
10
70
80
90 100
f − Frequency − MHz
G004
Figure 5.
ADS5440
www.ti.com
TYPICAL CHARACTERISTICS (continued)
(FFT For 300-MHz Input Signal)
(FFT For 400-MHz Input Signal)
SFDR = 69 dBc
SNR = 66.9 dBc
THD = 67.1 dBc
SINAD = 63.9 dBc
−20
−40
Amplitude − dB
Amplitude − dB
−20
SFDR = 63.3 dBc
SNR = 64.9 dBc
THD = 62.1 dBc
SINAD = 60.1 dBc
−60
−80
−100
−40
−60
−80
−100
−120
−120
40
50
60
70
80
90 100
f − Frequency − MHz
30
40
50
60
70
80
90 100
f − Frequency − MHz
G005
G006
Figure 6.
Figure 7.
(FFT For 51.5-MHz and 52.5 MHz Input Signals)
FIN1 = 51.5 MHz, −7 dBFS
FIN2 = 52.5 MHz, −7 dBFS
IMD3 = 89.3 dBFS
−20
−40
Amplitude − dB
Amplitude − dB
−20
FIN1 = 51.5 MHz, −16 dBFS
FIN2 = 52.5 MHz, −16 dBFS
IMD3 = 97.4 dBFS
−60
−80
−100
−40
−60
−80
−100
−120
−120
40
50
60
70
80
90 100
f − Frequency − MHz
40
50
60
70
80
90 100
f − Frequency − MHz
G007
Figure 8.
G008
Figure 9.
11
ADS5440
www.ti.com
(FFT For 151-MHz and 152 MHz Input Signals)
FIN1 = 151 MHz, −7 dBFS
FIN2 = 152 MHz, −7 dBFS
IMD3 = 87.9 dBFS
−20
−40
Amplitude − dB
Amplitude − dB
−20
FIN1 = 151 MHz, −16 dBFS
FIN2 = 152 MHz, −16 dBFS
IMD3 = 99.4 dBFS
−60
−80
−100
−40
−60
−80
−100
−120
−120
40
50
60
70
80
90 100
f − Frequency − MHz
30
40
50
60
70
80
90 100
f − Frequency − MHz
G009
G010
Figure 10.
Figure 11.
(FFT For 254-MHz and 255 MHz Input Signals)
FIN1 = 254 MHz, −7 dBFS
FIN2 = 255 MHz, −7 dBFS
IMD3 = 80.5 dBFS
−20
−40
Amplitude − dB
Amplitude − dB
−20
FIN1 = 254 MHz, −16 dBFS
FIN2 = 255 MHz, −16 dBFS
IMD3 = 93.9 dBFS
−60
−80
−100
−40
−60
−80
−100
−120
−120
40
50
60
70
80
90 100
f − Frequency − MHz
40
50
60
G011
Figure 12.
12
70
80
90 100
f − Frequency − MHz
G012
Figure 13.
ADS5440
www.ti.com
(FFT For 355-MHz and 356 MHz Input Signals)
FIN1 = 355 MHz, −7 dBFS
FIN2 = 356 MHz, −7 dBFS
IMD3 = 79.7 dBFS
−20
−40
Amplitude − dB
Amplitude − dB
−20
FIN1 = 355 MHz, −16 dBFS
FIN2 = 356 MHz, −16 dBFS
IMD3 = 96.8 dBFS
−60
−80
−100
−40
−60
−80
−100
−120
−120
40
50
60
70
80
90 100
f − Frequency − MHz
30
40
50
60
70
80
90 100
f − Frequency − MHz
G013
G014
Figure 14.
Figure 15.
WCDMA Carrier
(fIN = 70 MHz)
WCDMA Carrier
(fIN = 140 MHz)
fS = 184.32 MSPS
fIN = 70 MHz
ACPR Adj Top = 73 dB
ACPR Adj Low = 72.7 dB
−20
−20
−40
Amplitude − dB
−40
Amplitude − dB
fS = 184.32 MSPS
fIN = 140 MHz
ACPR Adj Top = 72.1 dB
ACPR Adj Low = 72.1 dB
−60
−80
−60
−80
−100
−100
−120
−120
−140
−140
40
50
60
70
80
90
f − Frequency − MHz
10
40
50
60
70
80
90
f − Frequency − MHz
G015
Figure 16.
G016
Figure 17.
13
ADS5440
www.ti.com
Input Bandwidth
0.4
−1
Differential Nonlinearity − LSB
−2
Input Amplitude − dB
fS = 210 MSPS
fIN = 10 MHz
0.3
−3
−4
−5
−6
−7
−8
−9
1
0.1
0.0
−0.1
−0.2
−0.3
fS = 210 MSPS
AIN = −1 dBFS
−10
0.2
−0.4
10
100
fIN − Input Frequency − MHz
1k
1024 2048 3072 4096 5120 6144 7168 8192
Code
G017
G018
Figure 18.
Figure 19.
Noise Histogram With Inputs Shorted
45
0.8
40
0.6
35
0.4
Percentage − %
INL − Integral Nonlinearity − LSB
1.0
0.2
0.0
−0.2
−0.4
30
25
10
−0.6
−0.8
5
fS = 210 MSPS
fIN = 10 MHz
−1.0
4101
Code
G019
Figure 20.
14
4102
4103
4104
4106
G020
Figure 21.
4105
Code Number
ADS5440
www.ti.com
AC Performance
vs
Input Amplitude
AC Performance
vs
Input Amplitude
100
100
SFDR (dBFS)
80
SNR (dBFS)
60
40
Performance − dB
Performance − dB
80
SFDR (dBFS)
SFDR (dBc)
SNR (dBFS)
60
SFDR (dBc)
40
SNR (dBc)
SNR (dBc)
fS = 210 MSPS
fIN = 100 MHz
−20
−100 −90 −80 −70 −60 −50 −40 −30 −20 −10
fS = 210 MSPS
fIN = 230 MHz
−20
Input Amplitude − dBFS
G021
G022
Figure 22.
Figure 23.
Two-Tone Spurious Free Dynamic Range
vs
Input Amplitude
vs
Clock Duty Cycle
80.0
SFDR − Spurious-Free Dynamic Range − dBc
120
SFDR (dBFS)
100
80
60
SFDR (dBc)
40
90 dBFS Line
fS = 210 MSPS
f1 = 151 MHz
f2 = 152 MHz
−20
−110−100 −90 −80 −70 −60 −50 −40 −30 −20 −10
fS = 210 MSPS Square Wave
77.5
75.0
fIN = 100.33 MHz
72.5
fIN = 230.13 MHz
70.0
67.5
65.0
62.5
60.0
45
50
55
60
Duty Cycle − %
G023
Figure 24.
G024
Figure 25.
15
ADS5440
www.ti.com
vs
Clock Level
vs
Clock Level
70
fS = 210 MSPS
fIN = 100.33 MHz
76
69
SNR − Signal-to-Noise Ratio − dBc
78
74
72
fIN = 230.13 MHz
70
68
66
64
62
0.5
1.0
1.5
2.0
2.5
3.0
3.5
67
fIN = 230.13 MHz
66
65
64
63
62
60
0.0
4.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
Clock Amplitude − VP−P
Figure 26.
Figure 27.
Performance
vs
Clock Common Mode Level
vs
AVDD Across Temperature
4.0
G026
G025
84
80
SFDR
70
SNR
60
Performance − dBc
68
61
60
0.0
50
40
30
fs = 210 MSPS
fin = 100 MHz
2
3
4
82
fS = 210 MSPS
fIN = 100 MHz
80
76
TA = 25°C
TA = 0°C
74
TA = 85°C
72
TA = −40°C
70
4.65
5
TA = 65°C
78
Clock Common-Mode Voltage − V
G027
Figure 28.
16
fIN = 100.33 MHz
fS = 210 MSPS
4.75
4.85
4.95
5.05
Figure 29.
5.15
AVDD − Supply Voltage − V
5.25
5.35
G028
ADS5440
www.ti.com
vs
vs
DRVDD Across Temperature
70
80
68
69
TA = 65°C
TA = −40°C
TA = 85°C
TA = 25°C
67
66
fS = 210 MSPS
fIN = 100 MHz
65
4.70
4.80
4.90
5.00
5.10
5.20
fS = 210 MSPS
fIN = 100 MHz
79
TA = 65°C
78
TA = 25°C
77
76
TA = 0°C
75
74
TA = 85°C
73
TA = −40°C
72
71
70
2.9
5.30
3.1
3.3
3.5
DRVDD − Supply Voltage − V
G029
Figure 30.
3.7
G030
Figure 31.
vs
70
TA = 0°C
TA = 0°C
69
TA = 65°C
TA = 85°C
68
TA = −40°C
TA = 25°C
67
66
fS = 210 MSPS
fIN = 100 MHz
65
3.0
3.1
3.2
3.3
3.4
3.5
3.6
3.7
G031
Figure 32.
17
ADS5440
www.ti.com
SNR
vs
Input Frequency and Sampling Frequency
240
69
220
68
fS − Sampling Frequency − MHz
200
65
66
180
160
67
140
68
69
69
65
120
66
67
100
80
66
60
67
40
68
10
65
68
69
67
66
50
65
66
65
63
100
62
150
200
64
62
61
60
63
64
64
63
62
250
60
59
58
300
61
58
350
59
57 56
400
54
56
58
60
62
64
SNR − dBc
Figure 33.
18
66
68
70
M0048−01
ADS5440
www.ti.com
SFDR
vs
240
72
220
76
200
72
74
70
78
180
66
68
78
80
74
76
66
160
82
140
120
60
72
84
100
80
80
82
68
70
62
74
84
86
80
84
76
82
84
78
82
84
40
10
64
84
82
80
82
82
50
66
100
150
78
76
72
74
200
250
70
68
300
64
62
350
60
58
400
55
60
65
70
75
SFDR − dBc
80
85
M0048−02
Figure 34.
19
ADS5440
www.ti.com
APPLICATION INFORMATION
Theory of Operation
The ADS5440 is a 13 bit, 210 MSPS, monolithic pipeline analog to digital converter. Its bipolar analog core
operates from a 5 V supply, while the output uses a 3.3 V supply to provide LVDS compatible outputs. The
conversion process is initiated by the rising edge of the external input clock. At that instant, the differential input
signal is captured by the input track and hold (T&H) and the input sample is sequentially converted by a series of
small resolution stages, with the outputs combined in a digital correction logic block. Both the rising and the
falling clock edges are used to propagate the sample through the pipeline every half clock cycle. This process
results in a data latency of four clock cycles, after which the output data is available as a 13 bit parallel word,
coded in offset binary format.
Input Configuration
The analog input for the ADS5440 consists of an analog differential buffer followed by a bipolar track-and-hold.
The analog buffer isolates the source driving the input of the ADC from any internal switching. The input common
mode is set internally through a 500 Ω resistor connected from 2.4 V to each of the inputs. This results in a
differential input impedance of 1 kΩ.
For a full-scale differential input, each of the differential lines of the input signal (pins 16 and 17) swings
symmetrically between 2.4 +0.55 V and 2.4 -0.55 V. This means that each input has a maximum signal swing of
1.1 VPP for a total differential input signal swing of 2.2 VPP. The maximum swing is determined by the internal
reference voltage generator eliminating the need for any external circuitry for this purpose.
The ADS5440 obtains optimum performance when the analog inputs are driven differentially. The circuit in
Figure 35 shows one possible configuration using an RF transformer with termination either on the primary or on
the secondary of the transformer. If voltage gain is required, a step up transformer can be used. For voltage
gains that would require an impractical transformer turn ratio, a single-ended amplifier driving the transformer is
shown in Figure 36).
R0
50
Z0
50
AIN
1:1
R
50
AC S ignal
Source
ADS5440
AIN
AD T 1−1W T
Figure 35. Converting a Single-Ended Input to a Differential Signal Using RF Transformers
5V
VIN
−5 V
RS
100 Ω
OPA695
0.1 µF
1000 µF
RIN
1:1
RT
100 Ω
RIN
R1
400 Ω
R2
57.5 Ω
AV = 8V/V
(18 dB)
Figure 36. Using the OPA695 With the ADS5440
AIN
CIN
ADS5440
AIN
ADS5440
www.ti.com
Application Information (continued)
From VIN
50 Ω
Source
100 Ω
348 Ω
13-Bit
210 MSPS
+5V
78.9 Ω
49.9 Ω
0.22 µF
18 pF
100 Ω
49.9 Ω
THS4509
AIN
ADS5440
AIN
VREF
CM
49.9 Ω
0.22 µF
78.9 Ω
49.9 Ω
0.22 µF
0.1 µF
0.1 µF
348 Ω
Figure 37. Using the THS4509 With the ADS5440
Besides the OPA695, Texas Instruments offers a wide selection of single-ended operational amplifiers that can
be selected depending on the application. An RF gain block amplifier, such as Texas Instrument's THS9001, can
also be used with an RF transformer for high input frequency applications. For applications requiring dc-coupling
with the signal source, a differential input/differential output amplifier like the THS4509 (see Figure 37) is a good
solution as it minimizes board space and reduces the number of components.
In this configuration, the THS4509 amplifier circuit provides 10 dB of gain, converts the single-ended input to
differential, and sets the proper input common-mode voltage to the ADS5440.
The 50 Ω resistors and 18 pF capacitor between the THS4509 outputs and ADS5440 inputs (along with the input
capacitance of the ADC) limit the bandwidth of the signal to about 70 MHz (-3 dB).
Input termination is accomplished via the 78.9 Ω resistor and 0.22 µF capacitor to ground in conjunction with the
input impedance of the amplifier circuit. A 0.22 µF capacitor and 49.9 Ω resistor is inserted to ground across the
78.9 Ω resistor and 0.22 µF capacitor on the alternate input to balance the circuit.
Gain is a function of the source impedance, termination, and 348 Ω feedback resistor. See the THS4509 data
sheet for further component values to set proper 50 Ω termination for other common gains.
Since the ADS5440 recommended input common-mode voltage is +2.4 V, the THS4509 is operated from a
single power supply input with VS+ = +5 V and VS- = 0 V (ground). This maintains maximum headroom on the
internal transistors of the THS4509.
Clock Inputs
The ADS5440 clock input can be driven with either a differential clock signal or a single-ended clock input, with
little or no difference in performance between both configurations. In low input frequency applications, where jitter
may not be a big concern, the use of single-ended clock (see Figure 38) could save some cost and board space
without any trade-off in performance. When driven on this configuration, it is best to connect CLK to ground with
a 0.01 µF capacitor, while CLK is ac-coupled with a 0.01 µF capacitor to the clock source, as shown in
Figure 38.
Square Wave or
Sine Wave
CLK
0.01 µF
ADS5440
CLK
0.01 µF
Figure 38. Single-Ended Clock
21
ADS5440
www.ti.com
0.1 µF
Clock
Source
1:4
CLK
MA3X71600LCT−ND
ADS5440
CLK
Figure 39. Differential Clock
Nevertheless, for jitter sensitive applications, the use of a differential clock has some advantages (as with any
other ADC) at the system level. The first advantage is that it allows for common-mode noise rejection at the PCB
level.
A differential clock also allows for the use of bigger clock amplitudes without exceeding the absolute maximum
ratings. In the case of a sinusoidal clock, this results in higher slew rates and reduces the impact of clock noise
on jitter. See Clocking High Speed Data Converters (SLYT075) for more detail.
Figure 39 shows this approach. The back-to-back Schottky diodes can be added to limit the clock amplitude in
cases where this would exceed the absolute maximum ratings, even when using a differential clock.
100 nF
MC100EP16DT
100 nF
D
D
CLK
VBB Q
499
100 nF
Q
100 nF
ADS5440
CLK
499
50 Ω
50 Ω
100 nF
113 Ω
Figure 40. Differential Clock Using PECL Logic
Another possibility is the use of a logic based clock, such as PECL. In this case, the slew rate of the edges will
most likely be much higher than the one obtained for the same clock amplitude based on a sinusoidal clock. This
solution would minimize the effect of the slope dependent ADC jitter. Using logic gates to square a sinusoidal
clock may not produce the best results as logic gates may not have been optimized to act as comparators,
adding too much jitter while squaring the inputs.
The common-mode voltage of the clock inputs is set internally to 2.4 V using internal 1 kΩ resistors. It is
recommended to use ac coupling, but if this scheme is not possible due to, for instance, asynchronous clocking,
the ADS5440 features good tolerance to clock common-mode variation.
Additionally, the internal ADC core uses both edges of the clock for the conversion process. Ideally, a 50% duty
cycle clock signal should be provided.
Digital Outputs
The ADC provides 13 data outputs (D12 to D0, with D12 being the MSB and D0 the LSB), a data-ready signal
(DRY), and an over-range indicator (OVR) that equals a logic high when the output reaches the full-scale limits.
The output format is offset binary. It is recommended to use the DRY signal to capture the output data of the
ADS5440.
22
ADS5440
www.ti.com
The ADS5440 digital outputs are LVDS compatible.
Power Supplies
The use of low noise power supplies with adequate decoupling is recommended. Linear supplies are the
preferred choice versus switched ones, which tend to generate more noise components that can be coupled to
the ADS5440.
The ADS5440 uses two power supplies. For the analog portion of the design, a 5 V AVDD is used, while for the
digital outputs supply (DRVDD) we recommend the use of 3.3 V. All the ground pins are marked as GND,
although AGND pins and DRGND pins are not tied together inside the package.
Layout Information
The evaluation board represents a good guideline of how to layout the board to obtain the maximum
performance out of the ADS5440. General design rules as the use of multilayer boards, single ground plane for
ADC ground connections and local decoupling ceramic chip capacitors should be applied. The input traces
should be isolated from any external source of interference or noise, including the digital outputs as well as the
clock traces. The clock signal traces should also be isolated from other signals, especially in applications where
low jitter is required as high IF sampling.
Besides performance oriented rules, care has to be taken when considering the heat dissipation out of the
device. The thermal heat sink should be soldered to the board as described in the PowerPad Package section.
PowerPAD PACKAGE
The PowerPAD package is a thermally enhanced standard size IC package designed to eliminate the use of
bulky heatsinks and slugs traditionally used in thermal packages. This package can be easily mounted using
standard printed circuit board (PCB) assembly techniques, and can be removed and replaced using standard
repair procedures.
The PowerPAD package is designed so that the leadframe die pad (or thermal pad) is exposed on the bottom of
the IC. This provides an extremely low thermal resistance path between the die and the exterior of the package.
The thermal pad on the bottom of the IC can then be soldered directly to the printed circuit board (PCB), using
the PCB as a heatsink.
Assembly Process
1. Prepare the PCB top-side etch pattern including etch for the leads as well as the thermal pad as illustrated in
the Mechanical Data section.
2. Place a 6-by-6 array of thermal vias in the thermal pad area. These holes should be 13 mils in diameter. The
small size prevents wicking of the solder through the holes.
3. It is recommended to place a small number of 25 mil diameter holes under the package, but outside the
thermal pad area to provide an additional heat path.
4. Connect all holes (both those inside and outside the thermal pad area) to an internal copper plane (such as a
ground plane).
5. Do not use the typical web or spoke via connection pattern when connecting the thermal vias to the ground
plane. The spoke pattern increases the thermal resistance to the ground plane.
6. The top-side solder mask should leave exposed the terminals of the package and the thermal pad area.
7. Cover the entire bottom side of the PowerPAD vias to prevent solder wicking.
8. Apply solder paste to the exposed thermal pad area and all of the package terminals.
For more detailed information regarding the PowerPAD package and its thermal properties, see either the
SLMA004 Application Brief PowerPAD Made Easy or the SLMA002 Technical Brief PowerPAD Thermally
Enhanced Package.
23
PACKAGE OPTION ADDENDUM
www.ti.com
10-Dec-2020
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
(3)
Device Marking
(4/5)
(6)
ADS5440IPFP
ACTIVE
HTQFP
PFP
80
96
RoHS & Green
NIPDAU
Level-4-260C-72 HR
-40 to 85
ADS5440IPFP
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
