2SA1774R
2SA1774R
    DOESHARE(德芯)
    SOT-523-3
    晶体管类型:-;集射极击穿电压(Vceo):-;集电极电流(Ic):-;功率(Pd):-;直流电流增益(hFE@Ic,Vce):-;
2SA1774R 数据手册
2SA1774 2SA1774Q / 2SA1774R / 2SA1774S SOT-523 Silicon General Purpose Transistor (PNP) General description SOT-523 Silicon General Purpose Transistor (PNP) FEATURES • Low Cob = 3.5pF (Typical) • Low Vce(sat) < 0.5V • RoHS Compliant • Green EMC • Matte Tin(Sn) Lead Finish • Weight: approx. 0.002g Electrical Symbol: . Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified). Symbol Parameter Limits Test Condition Min Typ Unit Max V(BR)CBO Collector-Base Breakdown Voltage IC=-50uA, IE=0A -50 Volts V(BR)CEO Collector-Emitter Breakdown Voltage IC=-1mA, IB=0A -50 Volts V(BR)EBO Emitter-Base Breakdown Voltage IE=-50uA, IC=0A -5 Volts ICBO Collector Cut-off Current VCB=-50V, IE=0A -0.1 µA IEBO Emitter Cut-off Current VEB=-5V, IC=0A -0.1 µA hFE DC Current Gain 2SA1774Q VCE=-6V, IC=-1mA 120 270 --- 2SA1774R VCE=-6V, IC=-1mA 180 390 --- 2SA1774S VCE=-6V, IC=-1mA 270 560 --- VCE(sat) Collector-Emitter Saturation Voltage IC=-50mA, IB=-5mA -0.5 Volts VBE(sat) Base-Emitter Saturation Voltage IC=-50mA, IB=-5mA -1.2 Volts www.doeshare.net 2SA1774 Symbol Parameter Limits Test Condition Min fT COB Typ Unit Max Transition Frequency VCE =-5V, IC=-10mA f=30MHz 230 MHz Collector Output Capacitance VCB =-12V, IE =0A, f=1MHz 3.5 pF Classification of hFE & Marking Code: Rank hFE Range Classification of hFE Marking SOT-523 PACKAGE OUTLINE www.doeshare.net 2SA1774Q 2SA1774R 2SA1774S 120 - 270 180 - 390 270 - 560 FQ FR FS 2SA1774 Important Notice and Disclaimer DOESHARE has used reasonable care in preparing the information included in this document, but DOESHARE does not warrant that such information is error free. DOESHARE assumes no liability whatsoever for any damages incurred by you resulting from errors in or omissions from the information included herein. DOESHARE no warranty, representation or guarantee regarding the documents, circuits and products specification, DOESHARE reservation rights to make changes for any documents, products, circuits and specifications at any time without notice. Purchasers are solely responsible for the choice, selection and use of the DOESHARE products and services described herein, and DOESHARE assumes no liability whatsoever relating to the choice, selection or use of the products and services described herein. No license, express or implied, by implication or otherwise under any intellectual property rights of DOESHARE. Resale of DOESHARE products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by DOESHARE for the DOESHARE product or service described herein and shall not create or extend in any manner whatsoever, any liability of DOESHARE. www.doeshare.net
2SA1774R 价格&库存
很抱歉,暂时无法提供与“2SA1774R”相匹配的价格&库存,您可以联系我们找货
