CMD50N10/CMU50N10
100V N-Channel MOSFET
General Description
Product Summary
The 50N10 uses advanced trench
BVDSS
RDSON
ID
100V
17mΩ
50A
technology and design to provide
excellent RDS(ON). This device is
Applications
ideal for PWM, load switching and
DC-DC Converters
general purpose applications.
Power switching application
TO-252/251 Pin Configuration
Features
D
Low On-Resistance
High Reliability Capability with Passivation
G
S
100% avalanche tested
TO-252
(CMD50N10)
RoHS Compliant
G
D
S
TO-251
(CMU50N10)
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
100
V
VGS
Gate-Sou ce Voltage
±25
V
ID@TC=25℃
Continuous Drain Current
50
A
ID@TC=100℃
38
A
IDM
Pulsed Drain Current
150
A
EAS
Single Pulse Avalanche Energy1
200
mJ
PD@TC=25℃
Total Power Dissipation
100
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Thermal Data
Symbol
Parameter
R θJA
Thermal Resistance Junction-ambient (PCB mount)
R θJC
CA01Q2
Thermal Resistance Junction -Case
www.cmosfet.com
Typ.
Max.
Unit
62
℃/ W
1.5
℃/ W
Page 1 of 4
CMD50N10/CMU50N10
Electrical Characteristics (TJ=25℃ , unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
Min.
Typ.
Max.
Unit
V
VGS=0V , ID=250uA
100
VGS=10V , ID=25A
14
17
VGS=4.5V , ID=10A
18
25
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
VGS=VDS , ID =250uA
1
3
V
IDSS
Drain-Source Leakage Current
VDS= 100V, VGS=0V , TJ=25℃
1
uA
IGSS
Gate-Source Leakage Current
VGS ±25V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=15V, ID=20A
15
S
VDS=0V , VGS=0V , f=1MHz
2.3
Ω
50
10
Rg
Gate Resistance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Td(on)
Tr
Td(off)
Tf
Gate-Drain Charge
VDD=80V , ID=50A
VGS =0 to 10V
Turn-On Delay Time
8
10
Rise Time
VDD=20V , VGS=10V , I D =50A
5
Turn-Off Delay Time
RG =3.5Ω
30
mΩ
nC
ns
Fall Time
5
Ciss
Input Capacitance
3600
Coss
Output Capacitance
730
Crss
Reverse Transfer Capacitance
65
Min.
Typ.
Max.
Unit
50
A
VDS=25V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
Parameter
Continuous Source Current
Conditions
VG=VD=0V , Force Current
ISM
Pulsed Source Current
150
A
VSD
Diode Forward Voltage
VGS=0V , IS=25A
1.2
V
trr
Reverse Recovery Time
97
A
Reverse Recovery Charge
IF = 8A , VR=50V
diF / dt = 100 A/μs
Qrr
178
V
Note :
1.The test condition is VDD=50V,VGS=10V,L=0.5mH,I D=28A
This product has been designed and qualified for the counsumer market.
Cmos assumes no liability for customers' product design or applications.
Cmos reserver the right to improve product design ,functions and reliability wihtout notice.
CA01Q2
www.cmosfet.com
Page 2 of 4
CMD50N10/CMU50N10
Typical Characteristics
10V
5V
160
ID=f(VDS ); Tj =25°C
160
4.5V
120
80
4V
40
3.5V
3
4
5
25℃
175℃
80
1
2
V DS , Drain-to-Source Voltage (V)
3
4
5
V GS (V)
Output Characteristics
30
-55℃
40
3V
1
ID=f(VGS); VDS=6V
120
I D (A)
I D , Drain Current (A)
200
Transfer characteristics
50
RDS(on) =f(Tj );ID=25A;VGS=10V
3.5V
25
4V
RDS(on) =f(ID); Tj =25℃
3V
40
4.5V
15
5
-60
5V
-20
100
140
10
180
10V
Tj (℃)
300μA
60μA
1.5
IF, (A)
VGS (th) (V)
10
VGS (th) =f(Tj);VGS=VDS
2.0
120
160
ID(A)
Dra i n -s ou rce o n - state resi stance
Drain-Source on-state resistance v
2.5
80
1.0
10
3
IF=f(VSD)
2
175℃ 25℃
10
1
0.5
0.0
-60
-20
100
140
180
T j (℃)
gat e t h resh o l d vol t a ge
CA01Q2
10
0.2
0.4
0.6
0.8
1.0
1.2
1.4
VSD , (V)
Forward characteristics of reverse diode
www.cmosfet.com
Page 3 of 4
CMD50N10/CMU50N10
4
10
30
Capacitance (pF)
R DS(on)- On-Resistance (mΩ)
40
VGS=4.5V
VGS=10V
10
50
40
Ciss
3
10
Coss
10
2
10
1
Crss
C=f(VDS); VGS=0V; f=1MHZ
5
60
50
10μS
40
ID (A )
ID (A )
1μS
100μS
10
30
Typ.Characteristics
ID =f(VDS ); TC =25°C;D=0
100
25
VDS (Volts)
ID - Drain Current (A)
On-Resistance vs. Drain Current
1000
15
ID=f(TC);VGS≥6V
30
1mS
10
1
0.1
1
10
50
100
V DS (V)
Safe operating area
120
Drain current
Ptot =f(TC);VGS≥6V
Z t hJC(K/W)
Pt ot (W)
80
60
40
10
1
10
Z thJC =f(tp)
-1
0.5
0.1
0.05
0.01
10
Single Pulse
-3
50
100
150
200
10
-6
10
TC (°C)
Po w er d i s s i p at i o n
CA01Q2
200
TC ( ℃)
100
www.cmosfet.com
10
-5
10
-4
-3
-2
-1
10
10
10
10
t p(s)
M ax . t r an s i en t t h er m al i m p ed an c e
Page 4 of 4
很抱歉,暂时无法提供与“CMD50N10”相匹配的价格&库存,您可以联系我们找货
