CMD5N50/CMU5N50
500V N-Channel MOSFET
Product Summary
General Description
The 5N50 have been fabricated using an
advanced high voltage MOSFET process
BVDSS
RDSON
ID
500V
1.5Ω
4.5A
that is designed to deliver high levels of
performance and robustness in popular
TO-252 / 251 Pin Configuration
AC-DC applications.
D
Features
G
G
S
Fast switching
D
TO-252
(CMD5N50)
100% avalanche tested
S
TO-251
(CMU5N50)
Improved dv/dt capability
Absolute Maximum Ratings
Symbol
VDSS
ID
TC = 25℃ unless otherwise noted
Paramet er
Drain-Source Voltage
- Continuous (TC = 25℃ )
Drain Current
- Continuous (TC = 100℃ )
IDM
Drain Current
VGSS
Gate-Source Voltage
EAS
Single Pulsed Avalanche Energy
PD
Power Dissipation (TC = 25℃ )
TJ, TSTG
Operating and Storage Temperature Range
Maximum lead temperature for soldering purposes,
1/8�from case for 5 seconds
TL
- Pulsed
(Note 1)
(Note 2)
CMD5N50/CMU5N50
500
Units
V
4.5
A
2.9
15
A
±30
V
202
mJ
A
50
W
- 55 t o +150
300
CMD5N50/CMU5N50
2.6
Units
℃ /W
62.5
℃ /W
Thermal Characteristics
Symbol
RθJC
P arameter
Thermal Resistance, Junction-to-Case Max.
RθJA
Thermal Resistance, Junction-to-Ambient Max.
CA01P1
www.cmosfet.com
Page 1 of 2
CMD5N50/CMU5N50
Electrical Characteristic (TC=25℃ unless otherwise noted)
Symbol
Parameter
Test Conditions
Min
Typ
Ma x
Units
Off Characteristics
BVDSS
Drain-Source Breakdown Voltage
VGS = 0 V, ID = 250 µA
500
V
IDSS
Zero Gate Voltage Drain Current
VDS = 500 V, VGS = 0 V
1
µA
IGSSF
Gate-Body Leakage Current, Forward
VGS = 30 V, VDS = 0 V
100
nA
IGSSR
Gate-Body Leakage Current, Reverse
VGS = -30 V, VDS = 0 V
-100
nA
2.0
4.5
V
On Characteristics
VGS(th)
Gate Threshold Voltage
VDS = VGS, ID = 250 µA
RDS(on)
Static Drain-Source
On-Resistance
VGS = 10 V, ID = 2.2A
1.5
Ω
gFS
Forward Transconductance
VDS = 40 V, ID = 1.5A
3.5
S
VDS = 25 V, VGS = 0 V,
f = 1.0 MHz
750
pF
80
pF
15
pF
15
ns
40
ns
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Switching Characteristics
td(on)
Turn-On Delay Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDD = 250 V, ID = 4.5 A,
RG = 25 Ω
85
ns
45
ns
18
30
nC
3
nC
8
nC
Maximum Continuous Drain-Source Diode Forward Current
4.5
A
Maximum Pulsed Drain-Source Diode Forward Current
VGS = 0 V, IS = 1A
15
A
1.4
V
270
ns
2
µC
VDS = 400 V, ID = 4.5 A,
VGS = 10 V
Drain-Source Diode Characteristics and Maximum Ratings
IS
ISM
VSD
Drain-Source Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
R e v e r se R e c o v e r y C h a r g e
VGS = 0 V, IS = 4.5 A,
dIF / dt = 100 A/µs
Notes:
1. Repetitive Rating : Pulse width limited by maximum junction temperature
2. L = 5 mH, IAS = 9 A, VDD = 50V, Starting TJ = 25℃
This product has been designed and qualified for the counsumer market.
Cmos assumes no liability for customers' product design or applications.
Cmos reserver the right to improve product design ,functions and reliability wihtout notice.
CA01P1
www.cmosfet.com
Page 2 of 2
很抱歉,暂时无法提供与“CMD5N50”相匹配的价格&库存,您可以联系我们找货
