AS0130KA
N-Channel Enhancement Mode Power MOSFET
Product Summary
V(BR)DSS
RDS(on)MAX
ID
100V
32mΩ@10V
30A
Feature
Application
High density cell design for ultra low Rdson
Power switching application
Fully characterized avalanche voltage and current
Hard switched and high frequency circuits
Good stability and uniformity with high EAS
Uninterruptible power supply
Excellent package for good heat dissipation
Package
Circuit diagram
TO-252AB
Marking
S0130KA
Page 1
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3150168
2003/03/08
2012/05/16
D
6
AS0130KA
Absolute maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
100
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
ID
30
A
Pulsed Drain Current
IDM
70
A
Power Dissipation
PD
85
W
Thermal Resistance,Junction-to-Case
RθJC
1.8
℃/W
Single pulse avalanche energy
EAS
256
mJ
TJ
150
TSTG
-55 ~ +150
Junction Temperature
Storage Temperature
o
Electrical characteristics (TA=25 C, unless otherwise noted)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
Static Characteristics
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID =250µA
Zero gate voltage drain current
IDSS
VDS =100V,VGS = 0V
1
µA
Gate-body leakage current
IGSS
VGS =±20V, VDS = 0V
±100
nA
2.5
V
32
mΩ
Gate threshold voltage
100
V
VGS(th)
VDS =VGS, ID =250µA
1)
RDS(on)
VGS =10V, ID =10A
25
1)
gFS
VDS =5V, ID =10A
15
Drain-source on-resistance
Forward transconductance
1.3
S
2)
Dynamic characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
83.3
Total Gate Charge
Qg
61.7
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
16.7
Turn-on delay time
td(on)
7
Turn-on rise time
tr
Turn-off delay time
td(off)
Turn-off fall time
2356
VDS =50V,VGS =0V,f =1MHz
pF
94
VDS =50V,VGS =10V,ID =10A
8.3
nC
7
VDD=50V,VGS=10V,
RL=5Ω,RGEN=3Ω
nS
29
tf
7
Source-Drain Diode characteristics
1)
Diode Forward Current
IS
Diode Forward voltage
VDS
Reverse Recovery Time
trr
Reverse Recovery Charge
Qrr
VGS =0V, IS=10A
TJ = 25°C, IF =10A
1)
di/dt = 100A/μs
30
A
1.2
V
32
nS
53
nC
Notes:
1)
Pulse Test: Pulse Width < 300µs, Duty Cycle ≤2%.
2)
Guaranteed by design, not subject to production testing.
Page 2
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3150168
2003/03/08
2012/05/16
D
6
AS0130KA
Test Circuit
1) E AS test Circuit
2) Gate charge test Circuit
3) Switch Time Test Circuit
Page 3
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3150168
2003/03/08
2012/05/16
D
6
AS0130KA
Typical Characteristics
Page 4
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3150168
2003/03/08
2012/05/16
D
6
AS0130KA
Page 5
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3150168
2003/03/08
2012/05/16
D
6
AS0130KA
TO-252AB Package Information
Page 6
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3150168
2003/03/08
2012/05/16
D
6
很抱歉,暂时无法提供与“AS0130KA”相匹配的价格&库存,您可以联系我们找货
