NP36N10
100V N-Channel Enhancement Mode MOSFET
Description
Schematic diagram
The NP36N10 uses advanced trench technology
to provide excellent R DS(ON) and low gate charge.It
can be used in a wide variety of applications.
D
G
General Features
V DS =100V I D =36A
R DS(ON) (Typ.)=32mΩ @V GS =10V
R DS(ON) (Typ.)=38mΩ @V GS =4.5V
High density cell design for ultra low Rdson
Fully characterized avalanche voltage and
current
Good stability and uniformity with high E AS
Excellent package for good heat dissipation
Special process technology for high ESD
capability
S
Marking and pin assignment
TO-252-2L
(Top View)
Application
Automotive applications
Hard switched and high frequency circuits
Uninterruptible power supply
Package
100% UIS TESTED!
100% ∆Vds TESTED!
TO-252-2L
Ordering Information
Part Number
Storage Temperature
Package
Devices Per Reel
NP36N10G
-55°C to +150°C
TO-252-2L
2500
Absolute Maximum Ratings (TA=25℃ unless otherwise noted)
parameter
symbol
limit
unit
Drain-source voltage
V DS
100
V
Gate-source voltage
V GS
±20
V
TC=25°C
Continuous Drain Current
TC=100°C
ID
36
26
A
Pulsed Drain Current
I DP
144
A
Avalanche energy( L=0.5mH)
E AS
55
mJ
PD
50
W
Tj
-55—150
Maximum power dissipation
TC=25°C
Operating junction Temperature range
Rev.1.0 —Oct. 26. 2017
1
www.natlinear.com
NP36N10
Electrical Characteristics (TA=25℃ unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
100
V
T J =25°C
1
T J =85°C
30
Static Characteristics
Drain-source breakdown voltage
BV DSS
V GS =0V, I D =250µA
Zero gate voltage drain current
I DSS
V DS =100V,
GS =0V
Gate Leakage Current
I GSS
V DS =0V, V GS =±20V
±100
nA
Gate threshold voltage
V GS(th)
V DS =V GS , I D =250µA
1
1.6
2.5
V
Drain-source on-state resistance1
R DS(ON)
V GS =10V, I D =30A
32
42
V GS =4.5V, I D =10A
38
48
36
A
36
A
32
ns
200
nC
1630
100
On Status Drain Current
I D(ON)
VDS=100V, VGS=10V
µA
mΩ
Diode Characteristics
Diode Continuous Forward Current
IS
Reverse Recovery Time
trr
Reverse Recovery Charge
Qrr
IF=10A,
dI/dt=500A/us
Dynamic Characteristics2
Input capacitance
C ISS
V GS =0V ,V DS =50V
f=1.0MHz
Output capacitance
C OSS
Reverse transfer capacitance
C RSS
50
Turn-on delay time
t D(ON)
7
Turn-on Rise time
tr
7
Turn-off delay time
t D(OFF)
29
7
34
Turn-off Fall time
tf
Total gate charge
Qg
Gate-source charge
Q gs
Gate-drain charge
Q gd
V GS =10V, V DS =50V, R L =5Ω,
R GEN =3Ω
V GS =10V,I D =10A
V DS =50V
pF
ns
nC
6
9
0.8
1.1
Drain-Source Diode Characteristics
Diode forward voltage
V SD
ISD=10A,VGS=0V
Note: 1:Pulse test; pulse width ≦ 300ns, duty cycle ≦ 2%.
2:Guaranteed by design, not subject to production testing.
2
www.natlinear.com
V
NP36N10
Typical Performance Characteristics
3
www.natlinear.com
NP36N10
4
www.natlinear.com
NP36N10
5
www.natlinear.com
NP36N10
Package Information
TO-252-2L
6
www.natlinear.com
很抱歉,暂时无法提供与“NP36N10G”相匹配的价格&库存,您可以联系我们找货
