深圳市航顺芯片技术研发有限公司
航顺浩瀚处理器(广州)有限公司
国家高新技术企业 深圳龙华2017年八大重点签约引进企业
航顺芯片32位通用MCU之M0 M3 M4世界级超低功耗
性能超稳定 开发工具全兼容进口 软硬件全兼容进口
做中国自主知识产权核心处理器
MCU/DSP/CPU芯片级大脑领导者
HK73XX
250mA Low Power LDO
Low Power Consumption LDO HK73XX Series
General Description
Features
The HK73XX series are a group of positive voltage
z Ultra low quienscent current: 3.0uA(typ)
z High input voltage (up to 12v)
z Low dropout voltage :80mV@Iout=40mA
(Vout=3.3v)
z Output voltage accuracy: ±2%
z Maximum output current:250mA
(within max.power dissipation,Vout=3.3V)
z Low temperature coefficient
z Package :SOT23-3 、TO-92 、SOT89-3
output,three –pin regulator,that provide a high
current even when the input/output Voltage
differerntial is small.Low power consumption and
high accuracy is achieved through CMOS
technology.They allow input voltages as high as
12V.
Typical Application
z
z
z
z
z
HK
Cameras, video recorders
Voltage regulator for microprocessor
Voltage regulator for LAN cards
Wireless communication equipment
Audio/Video equipment
25-2.5V
30-3.0V
33-3.3V
36-3.6V
44-4.4V
50-5.0V
HK
http://www.hsxp8888.com
深圳市航顺芯片技术研发有限公司
航顺浩瀚处理器(广州)有限公司
做中国自主知识产权核心处理器
MCU/DSP/CPU芯片级大脑领导者
HK73XX
73XX
73XX
73XX
Pin Assignment
HK73XX
Pin Number
SOT89-3/TO-92
SOT23-3
1
1
2
3
3
2
Pin Name
Functions
VSS
VIN
VOUT
Ground
Input
Output
Absolute Maximum Ratings
Parameter
Input Voltage
Output Voltage
Output Current
Operating Temperature Range
Storage Temperature Range
SOT89-3
Power Dissipation TO-92
SOT23-3
Ratings
18
Vss-0.3~VIN +0.3
250
-40~+85
-40~+125
500
500
300
Symbol
VIN
VOUT
Iout
TOPR
TSTG
PD
Units
V
V
mA
mW
深圳市航顺芯片技术研发有限公司
航顺浩瀚处理器(广州)有限公司
做中国自主知识产权核心处理器
MCU/DSP/CPU芯片级大脑领导者
HK73XX
Block Diagram
Electrical Characteristics
HK7330
(VIN= VOUT+1.0V,CIN=CL=10uF,Ta=25OC, unless otherwise noted)
Parameter
Output Voltage
Symbol
VOUT(E)
IOUT=40mA,
(Note 2)
VIN=Vout+1V
Input Voltage
VIN
Maximum Output Voltage
IOUT _max
Load Regulation
Dropout Voltage
(Note 3)
Supply Current
Line Regulations
△VOUT/△Ta
Conditions
∆VOUT
VIN=Vout+1V
VIN=Vout+1V,
1mA≤IOUT≤60mA
Min.
X 0.98
Typ.
VOUT (T)
(Note 1)
Max.
Units
X 1.02
V
18
V
250
mA
15
40
mV
Vdif
IOUT =40mA
80
ISS
VIN=Vout+1V
3
4
μA
∆VOUT
IOUT =40mA
∆VIN ×VOUT
Vout+1V ≤VIN≤18V
0.1
0.2
%/V
Temperature
VIN=Vout+1V, IOUT =40mA
Coefficient
-40℃
很抱歉,暂时无法提供与“HK7350-A”相匹配的价格&库存,您可以联系我们找货
